TijuanaKez wrote:Thanks for the replies guys but I wasn't trying to flash the device, just use it with the stock firmware and communicate with it via an Arduino.
This was working fine and I was able to issue AT commands and use ITEADLIB_Arduino_WeeESP8266 Library to receive UDP packets.
At some stage I issued the AT+RST command though and since then I get no response from the AT command or any others.
Are you saying AT+RST wipes the firmware?
No, AT+RST does not wipe the firmware.
Sorry, I misunderstood your message, and thought you where loading an Arduino program on the ESP (well, this is the ESP8266 Arduino Platform section, after all). What I do not understand now is how are your devices connected, and how are you sending AT commands and reading the output.
