I have some BMP280 modules like this (robotdyn)
And can't connect it to any esp. I have no that problem with any other BMP280 module. How to connect it? Help me pleese.
I use NodeMCU with Arduino IDE.
NodeMCU - BMP280
3V-------------3V
GND----------GND
D1-------------SCK
D2-------------SDI
3V-------------CS
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP280.h>
#include <SPI.h>
#include <ArduinoJson.h>
Adafruit_BMP280 bmp; // I2C
// Replace with your network details
const char* ssid = "ssid";
const char* password = "pwd";
float t, p;
char temperatureString[6];
char pressureString[7];
StaticJsonBuffer<300> JSONbuffer;
JsonObject& JSONencoder = JSONbuffer.createObject();
// Web Server on port 80
WiFiServer server(80);
// only runs once on boot
// Initializing serial port for debugging purposes
delay(10);
//Wire.begin(0, 2);
Wire.begin(5, 4); delay(10);
Wire.setClock(100000);
// Connecting to WiFi network
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
// Starting the web server
server.begin();
Serial.println("Web server running. Waiting for the ESP IP...");
delay(10000);
// Printing the ESP IP address
Serial.println(F("BMP280 test"));
if (!bmp.begin()) {
Serial.println("Could not find a valid BMP280 sensor, check wiring!");
while (1);
void getWeather() {
t = bmp.readTemperature();
p = (bmp.readPressure() * 7.5006e-3);
dtostrf(t, 5, 1, temperatureString);
dtostrf(p, 6, 1, pressureString);
delay(100);
// runs over and over again
// Listenning for new clients
//StaticJsonBuffer<300> JSONbuffer;
//JsonObject& JSONencoder = JSONbuffer.createObject();
if (client) {
Serial.println("New client");
// bolean to locate when the http request ends
boolean blank_line = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
if (c == '\n' && blank_line) {
getWeather();
JSONencoder["Place"] = "Mub, 7";
JSONencoder["Snum"] = "1";
JSONencoder["Temp"] = temperatureString;
JSONencoder["Pres"] = pressureString;
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println();
// your actual web page that displays temperature
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.println("<head><meta http-equiv=\"Content-Type\" content=\"text/html; charset=utf-8\"></head>");
client.println("<body>");
String out;
JSONencoder.printTo(out);
client.println(out);
client.println("</body></html>");
break;
if (c == '\n') {
// when starts reading a new line
blank_line = true;
else if (c != '\r') {
// when finds a character on the current line
blank_line = false;
// closing the client connection
delay(1);
client.stop();
Serial.println("Client disconnected.");
} And I get in console
Connecting to ssid
WiFi connected
192.168.0.114
BMP280 test
Soft WDT reset
ctx: cont
sp: 3ffef760 end: 3ffef950 offset: 01b0
>>>stack>>>
3ffef910: 3ffe84c4 3ffee838 3ffef990 4020244c
3ffef920: 3ffe89e8 7200a8c0 feefeffe feefeffe
3ffef930: 3fffdad0 00000000 3ffee920 40204990
3ffef940: feefeffe feefeffe 3ffee930 40100718
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
tail 8
chksum 0x2d
csum 0x2d
v00000000
~ldThank you.
