I am in a desperate need for help. I posted this on Arduino forum too but here might be more appropriate.
What I want to do:
I have two ESP8266s, two Arduino UNOs, one ADXL335 Accelerometer.
1) I want to get 3 readings (x, y, z) from the accelerometer (which is connected to Arduino),
2) send the data via the client ESP8266 to the server ESP8266 via wifi (local network and not though the Internet),
3)Print the data of the 3 readings on the Serial Monitor on my computer, which is connected to an Arduino (which is connected to the server ESP8266, which is getting the data wirelessly from the client ESP8266).
I used this ( https://robotzero.one/sending-data-esp8266-to-esp8266/ ) tutorial to do this project.
The problem I'm having:
1) The 2nd and the 3rd readings (for y and z axis) are not changing on the server side's Serial Monitor. It's completely static (e.g. printing out 100-200-ish number all the time). The 1st reading (input of the x-axis of the accelerometer) is being communicated to the server successfully, and I can see it changing on the Serial Monitor.
2) Having said this, the changing of the 1st number (reading of x) being printed out on the Serial Monitor is extremely slow, and sometimes gets stuck on the same value for a long time even I tilt on the x-axis (which I want it to change the numbers immediately). It worked fine when I experimented with just one analog input (e.g. potentiometer, using just the x-input of the accelerometer...).
My code:
I have 3 codes below - I'm putting everything here because I'm such a noob and am not sure what's causing the issue.
However, I'm guessing - what's causing the issue could be to do with
1) How I'm structuring the URI - the bit around "String url = "/data/";" on the client side
2) How I'm using server.hasArg on the server side
3) How I'm using server.arg on the server side
4) 'HTTP GET' requests on the client side
But this is just my guess, and I don't know how to fix it.
How can I solve these issues? :'(
I would really appreciate your help!!
Server / Access Point ESP8266 Code:
#include <ESP8266WebServer.h>
const char *ssid = "ESP";
ESP8266WebServer server(80);
void handleSentVar() {
if (server.hasArg("sensor_reading")) {
Serial.print(server.arg("sensor_reading")); //THIS CHANGES EVEN IT'S SUPER SLOW
Serial.print(",");
Serial.print(server.arg("sensor_reading1")); //THIS DOESN'T CHANGE
Serial.print(",");
Serial.println(server.arg("sensor_reading2")); //THIS DOESN'T CHANGE
server.send(200); //200 = OK
delay(1);
delay(1000);
Serial.begin(9600);
Serial.print("Configuring access point...");
WiFi.softAP(ssid);
Serial.print("AP IP address: ");
Serial.println(myIP);
server.on("/data/", HTTP_GET, handleSentVar);
server.begin();
server.handleClient();
}Client / Station Arduino Code:
#include <SoftwareSerial.h>
SoftwareSerial ESPserial(2,3); // RX | TX
const int ap1 = A5;
const int ap2 = A4;
const int ap3 = A3;
const int numReadings = 30;
int inByte = 0; // incoming serial byte
int readingsX[numReadings];
int readingsY[numReadings];
int readingsZ[numReadings];
int readIndexX = 0;
int readIndexY = 0;
int readIndexZ = 0;
int totalX = 0;
int totalY = 0;
int totalZ = 0;
int averageX = 0;
int averageY = 0;
int averageZ = 0;
Serial.begin(9600); //This must always be 9600
ESPserial.begin(9600); //This must match the baud rate of the Serial.begin for ESP8266
for (int thisReading = 0; thisReading < numReadings; thisReading++) {
readingsX[thisReading] = 0;
readingsY[thisReading] = 0;
readingsZ[thisReading] = 0;
// X------------------------------
// subtract the last reading:
totalX = totalX - readingsX[readIndexX];
// read from the sensor:
int calx = 347; //CALIBRATE X
int x = analogRead(ap1)-calx;
x = abs(x);
int xMapped = map(x,0,50,0,50);
readingsX[readIndexX] = xMapped;
// add the reading to the total:
totalX = totalX + readingsX[readIndexX];
// advance to the next position in the array:
readIndexX = readIndexX + 1;
// if we're at the end of the array...
if (readIndexX >= numReadings) {
// ...wrap around to the beginning:
readIndexX = 0;
// calculate the average:
averageX = totalX / numReadings;
// send it to the computer as ASCII digits
ESPserial.write(averageX);
ESPserial.write(",");
delay(1); // delay in between reads for stability
... SAME SET OF CODES FOR Y AND Z...
}//------End of Loop-----Client / Station ESP8266 Code (for ESP8266):
int outputValue = 0; // value sent to server
int outputValue1 = 0; // value sent to server
int outputValue2 = 0; // value sent to server
byte data;
byte data1;
byte data2;
Serial.begin(9600);
delay(1000);
/* Explicitly set the ESP8266 to be a WiFi-client */
WiFi.mode(WIFI_STA);
WiFi.begin(ssid);
char inData[15];
char outData[3];
byte index = 0;
if(Serial.available()){ //When there is data from Arduino available...
char aChar = Serial.read();
if(aChar == '\n') {
// End of record detected. Time to parse
char *p = inData; //making p point to the string "x,y,z"
char *str; // declaring str
int counter = 0; //initialise the counter
while ((str = strtok_r(p, ",", &p))) {// delimiter is the comma. NULL is the terminator
outData[counter] = *str; //use the counter as an index to add each value to the array. data[0]=x, data[1]=y...
counter++; //increment the counter
p = NULL;
data = outData[0];
data1 = outData[1];
data2 = outData[2];
index = 0;
inData[index] = NULL;
} else {
inData[index] = aChar; //Store current character. inData[current index] = current character
index++; //move onto next index untill \n
inData[index] = '\0'; // Keep the string NULL terminated
} //---end of parsing---
outputValue = data; //int = byte
outputValue1 = data1;
outputValue2 = data2;
char intToPrint[5];
itoa(outputValue, intToPrint, 10);
char intToPrint1[5];
itoa(outputValue1, intToPrint1, 10);
char intToPrint2[5];
itoa(outputValue2, intToPrint2, 10);
//^integer to string conversion. itoa(int val, Char s, int redix/base).
//buffer (intToPrint) must have sufficient storage.
WiFiClient client;
const char * host = "192.168.4.1";
const int httpPort = 80;
return;
// We now create a URI for the request
url += "?sensor_reading="; //send key-value pairs by adding "?", followed by 'key=value'
url += intToPrint;
url += "&sensor_reading1=";
url += intToPrint1; //THIS DOESN'T CHANGE ON SERVER'S SERIAL MONITOR
url += "&sensor_reading2=";
url += intToPrint2; //THIS DOESN'T CHANGE ON SERVER'S SERIAL MONITOR
// This will send the GET request to the server
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
unsigned long timeout = millis();
while (client.available() == 0) {
if (millis() - timeout > 5000) {
Serial.println(">>> Client Timeout !");
client.stop();
return;
delay(1);
