Wemos -> NRF24
D8 -> CSN
D7 -> MOSI
D6 -> MISO
D5 -> SCK
D0 -> CE
+5v -> VCC - adapter
I am checkng the connection with the program:
// 18 Mar 2018 - simple program to verify connection between Arduino
// and nRF24L01+
// This program does NOT attempt any communication with another nRF24
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include <printf.h>
#define CE_PIN 0
#define CSN_PIN 8
const byte thisSlaveAddress[5] = {'R','x','A','A','A'};
RF24 radio(CE_PIN, CSN_PIN);
char dataReceived[10]; // this must match dataToSend in the TX
bool newData = false;
Serial.begin(9600);
//printf_begin();
Serial.println("CheckConnection Starting");
Serial.println("FIRST WITH THE DEFAULT ADDRESSES after power on");
Serial.println(" Note that RF24 does NOT reset when Arduino resets - only when power is removed");
Serial.println(" If the numbers are mostly 0x00 or 0xff it means that the Arduino is not");
Serial.println(" communicating with the nRF24");
radio.begin();
radio.printDetails();
Serial.println("AND NOW WITH ADDRESS AAAxR 0x41 41 41 78 52 ON P1");
Serial.println(" and 250KBPS data rate");
radio.openReadingPipe(1, thisSlaveAddress);
radio.setDataRate( RF24_250KBPS );
}Test result:
19:02:33.993 -> ?0⸮⸮⸮h>⸮@f⸮CheckConnection Starting
19:02:34.126 ->
19:02:34.126 -> FIRST WITH THE DEFAULT ADDRESSES after power on
19:02:34.210 -> Note that RF24 does NOT reset when Arduino resets - only when power is removed
19:02:34.258 -> If the numbers are mostly 0x00 or 0xff it means that the Arduino is not
19:02:34.358 -> communicating with the nRF24
19:02:34.358 ->
This test result is NOT ok.
The NRF24 works fine with the same test (adapted) on an Arduino UNO.
Have tried with different CE-PIN numbers.
So, I don't suspect the hardware.
Could it be a specific library which is causing problems?
Has anyone got the NRF24 to work with the Wemos D1 mini?
