With external power 5V its work perfect on Arduino Uno, but same not work properly in ESP8266.
Neoway M590:
edge 1 - 5V external,
2 - gnd external+gnd esp8266,
7 - gsm TX->gpio 12
8 - gsm RX->gpio 13
At commands ok, register in network ok, sometime send sms )
but not receive sms and after some time module not respond or unregister network.
Tried connect TTL 5V->3.3V on RX/TX, but in this case not work even at commands.
Any ideas? May be somebody already solve all problems by this module?
Softwareserial library in attach.
+70001111111 replace on your phone.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(12, 13); // RX, TX (7 tx->12) (8 rx -> 13)
Serial.begin(9600); //скорость порта
Serial.println("GSM tester v1.0");
mySerial.begin(9600);
String str;
if (mySerial.available()) { //если GSM модуль что-то послал нам, то
str = mySerial.readStringUntil('\n');
Serial.println(str);
if (Serial.available() > 0) {
str = Serial.readStringUntil('\n');
if (str =="send sms") {
send_sms("+70001111111", "test sms");
} else {
//Serial.println("at command");
mySerial.println(str);
//Serial.println(str);
void send_sms(String phone, String text) {
mySerial.println("AT+CMGS=\"" + phone + "\"");
mySerial.print(text);
mySerial.print((char)26);
readModem();
Serial.println("SMS send complete");
delay(2000);
void readModem() {
String str;
