My problem concerns existing code that I wrote a while ago which no longer compiles.
The code (attached) restores 10 files from SPIFFS. It just copies files. This compiled fine & worked fine until today when I updated everything. It seems that [i]file[/i].readBytes & [i]file[/i].write are now mutually incompatible(?)
I can't seem to get away from:
invalid conversion from 'byte* {aka unsigned char*}' to 'char*' [-fpermissive]
Whatever I try
This is the code:
[code][code
void recover()
Serial.println("In recover"); //debug
byte ibuffer[64]; //declare a buffer - hopefully this speeds things up...
const String source[] = {"/indexCopy.htm", "/gaugesCopy.htm", "/faviconCopy.ico", "/Mback15Copy.jpg", "/nakedCopy.jpg", "/odCopy.jpg", "/styleCopy.css", "/xmlCopy.js", "/gaugeCopy.js", "/helpCopy.html"};
// above are backup files
const String dest[] = {"/index.htm", "/gauges.htm", "/favicon.ico", "/Mback15.jpg", "/naked.jpg", "/od.jpg", "/style.css", "/xml.js", "/gauge.js", "/help.html"};
// above are where the backup files will go
for (int i = 0; i < 10; ++i) //restore all 10 files
File f1 = SPIFFS.open(source[i], "r"); //open source file to read
if (!f1) {
Serial.println("file open" + source[i] + " failed"); //debug
File f2 = SPIFFS.open(dest[i], "w"); //open destination file to write
if (!f2) {
Serial.println("file open" + dest[i] + " failed"); //debug
while (f1.available() > 0)
byte i = f1.readBytes(ibuffer, 64); // i = number of bytes placed in buffer from file f1
f2.write(ibuffer, i); // write i bytes from buffer to file f2
f2.close(); // done, close the destination file
Serial.println("Done copying" + dest[i]); //debug
f1.close(); // done, close the source file
server.send(200, "text/plain", "Recovery complete");
[/code]Thoughts appreciated.
Ian
