When the ESP8266 is just started it receives the multicast traffic ok, but after a few seconds nothing is received anymore. But when sending a packet with unicast to the ESP8266 then it is received and displayed on the serial console.
Here is the default example code I found and use to test multicast (btw the ssid and key are stored in eeprom so not defined in the example below):
* 31 mar 2015
* This sketch display UDP packets coming from an UDP client.
* On a Mac the NC command can be used to send UDP. (nc -u 192.168.1.101 2390).
* Configuration : Enter the ssid and password of your Wifi AP. Enter the port number your server is listening on.
13 apr 2015. Partly working. Packets are received and displayed, but the confirmation packet is not received by the client.
Tested with Mac as cleint using netcat (nc -u 192.168.1.101 2390)
#include <WiFiUDP.h>
int status = WL_IDLE_STATUS;
unsigned int localPort = 2390; // local port to listen for UDP packets
byte packetBuffer[512]; //buffer to hold incoming and outgoing packets
// A UDP instance to let us send and receive packets over UDP
WiFiUDP Udp;
// Multicast declarations
IPAddress ipMulti(239, 255, 255, 250);
unsigned int portMulti = 1900; // local port to listen on
void setup()
// Open serial communications and wait for port to open:
// setting up Station AP
WiFi.begin();
// Wait for connect to AP
Serial.print("[Connecting]");
// Serial.print(ssid);
int tries=0;
Serial.print(".");
tries++;
if (tries > 30){
break;
Serial.println("Connected to wifi");
Serial.print("Udp Multicast server started at : ");
Serial.print(ipMulti);
Serial.print(":");
Serial.println(portMulti);
Udp.beginMulticast(WiFi.localIP(), ipMulti, portMulti);
void loop()
int noBytes = Udp.parsePacket();
if ( noBytes ) {
Serial.print(millis() / 1000);
Serial.print(":Packet of ");
Serial.print(noBytes);
Serial.print(" received from ");
Serial.print(Udp.remoteIP());
Serial.print(":");
Serial.println(Udp.remotePort());
// We've received a packet, read the data from it
Udp.read(packetBuffer,noBytes); // read the packet into the buffer
// display the packet contents in HEX
for (int i=1;i<=noBytes;i++){
Serial.print(packetBuffer[i-1],HEX);
if (i % 32 == 0){
else Serial.print(' ');
} // end for
// send a reply, to the IP address and port that sent us the packet we received
Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
Udp.write("UDP packet received");
Udp.endPacket();
} // end if
Here are the linux commands for sending the multicast traffic (although there is already SSDP traffic in this setup to receive):
echo "MULTICASTTEST" | netcat -4u -w1 239.255.255.250 1900And I use this linux command for sending unicast traffic to the esp8266:
echo 'UNICASTTEST' | netcat -4u -w1 172.20.0.155 1900
