By zeropanic
#61508 Trying to get a sensor set up in Cayenne using the NodeMCU by following this gent's code here:
https://www.hackster.io/kuncono/easy-ai ... 135-300391
It compiles just fine on the 1.8 IDE but the ESP seems to be stuck in a reboot loop with "rst cause:4, boot mode:(3,0)"
Tried all the common tricks - power, capacitors, powering the sensor on its own, etc. but nothing seems to work...
Am I really that dense in missing something really stupidly simple since this apparently has worked for others?
Thanks.
