Summary
RF Calibration cannot be turned off after 2.0.0 in wake from deepSleep causing current spike and longer boot
Hardware
Hardware: Wemos D1 mini and ESP-12S, 470uf cap between Vcc and Ground
Core Version: 2.0.0 (works - No RF Calibration current spike), 2.3.0 (Not working, current spike)
Test equipment: Rigol Scope, 1ohm current shunt, "fuzz" is because I didn't do calibration on scope but traces are accurate.
Description
Using identical code function ESP.deepSleep(6000000, WAKE_NO_RFCAL); in 2.0.0 ESP can wakeup without large current spike from RF_CAL, however after 2.0.0 RF_CAL executes causing large current spike and longer run time. Please see attached current traces. Correct data is sent in both instances, only different is current spike, which appears to be RF_CAL executing.
Sketch sends simple beacon using wifi_send_pkt_freedom. GPIO16 connected to reset.
WAKE_RF_DISABLED does behave as expected in both 2.0.0 and 2.3.0
Also
system_deep_sleep_set_option(2); // Option 2 is WAKE_NO_RFCAL
//system_deep_sleep(6000000);
system_deep_sleep_instant(6000000); // Trims 98ms off go to sleephas same characteristics in that it cannot turn off RF_CAL
Settings in IDE
Module: WeMos D1 Mini & ESP-12S
Flash Size: 4MB
CPU Frequency: 80Mhz
Flash Mode: qio
Upload Using: SERIAL
Images
Version 2.0.0 without RF_CAL current spike at head
Version 2.3.0 with RF_CAL current spike at head
Sketch
#include <WiFiClient.h>
extern "C" {
#include "user_interface.h"
// (Commented out code below for 2.0.0 to expose send_pkt_freedom, not needed in 2,3.0
// typedef void (*freedom_outside_cb_t)(uint8 status);
// int wifi_register_send_pkt_freedom_cb(freedom_outside_cb_t cb);
// void wifi_unregister_send_pkt_freedom_cb(void);
// int wifi_send_pkt_freedom(uint8 *buf, int len, bool sys_seq);
void system_deep_sleep_instant(uint32 time_in_us);
byte channel;
byte RandomMac = 1;
byte SequenceLSB = 0;
byte SequenceMSB = 0;
// Packet I am sending
uint8_t packet[128] = { ...... 68 bytes,,,, }; // Obscured for example
delay(2); // in this group was all 50
wifi_set_opmode(STATION_MODE);
delay(2);
wifi_promiscuous_enable(1); // need
delay(2);
system_phy_set_max_tpw(20); //the maximum value of RF Tx Power, unit : 0.25dBm, range [0, 82] 19dBm = 76, 10dBm = 40, 14 dBm = 56
delay(2);
wifi_set_channel(1);
delay(2); // Delay in MS, was 20
wifi_send_pkt_freedom(packet, 68, 0);
//Increment fragment
//Set fragment
packet[22] = (SequenceLSB + 1);
delay(10); // Delay in MS
SequenceLSB = (SequenceLSB & 0xF0);
packet[22] = SequenceLSB;
wifi_set_channel(6);
//Set fragment
wifi_set_channel(11);
delay(2);
/// ESP.deepSleep(microseconds, mode) will put the chip into deep sleep. mode is one of WAKE_RF_DEFAULT, WAKE_RFCAL, WAKE_NO_RFCAL, WAKE_RF_DISABLED.
ESP.deepSleep(6000000, WAKE_NO_RFCAL); // Sleep for 6 seconds,
//system_deep_sleep_set_option(2);
//system_deep_sleep_instant(6000000);
