Platform
Hardware: ESP-12
Core Version: 2.4.2
Development Env: Arduino IDE
Operating System: Windows
Settings in IDE
Module: Generic ESP8266 Module
Flash Mode: DIO
Flash Size: 4MB/1mb
lwip Variant: v2 Lower Memory
Reset Method: ck
Flash Frequency: 40Mhz
CPU Frequency: 80Mhz
Upload Using: SERIAL
Upload Speed: 256000
Problem Description
I have been running the ESP-12 in a deployed environment where it will wake up and send a sensor reading once every 30 minutes. This had been going well until the modules stopped responding after anywhere between 15-30 days. They would constantly reboot once they connected to the wifi network.
I had read the fix was to set WiFi.persistent(false) at the top of the sketch before calling Wifi.begin(), however this does not work, module will still reboot once connected to wifi.
The code below still causes the corrupted module to reboot. Is there any fix to restore this module?
I have also tried static IP with no change..
Debug info attached below.
Is the wifi flash corrupt now?
does the WiFi.persistent(false) need to be set before flash becomes corrupt?
Will this only work on a new module?
Cannot get even this sample code to work, reboots when connects to Wifi:
ADC_MODE(ADC_VCC); //vcc read
#define LEDPINOUT 2 // GPIO2 of ESP8266
#define ESPDEEPSLEEPSECONDS 1000000
void setup()
//setup serial outputs
Serial.setDebugOutput(true);
WiFi.printDiag(Serial);
WiFi.persistent(false);
WiFi.mode(WIFI_STA);
//WiFi.forceSleepBegin();
//turn on wifi and connect
// WiFi.forceSleepWake();
//WiFi.config({192, 168, 0, 66}, {192, 168, 0, 1}, {255, 255, 255, 0}, {192, 168, 0, 1});
if (WiFi.status() != WL_CONNECTED)
WiFi.begin("ssid", "pwd"); //connect to wifi
delay (500);
}//end setup loop
void loop()
Serial.print(".");
delay(100);
} //end main loopdebug:
Mode: STA+AP
PHY mode: N
Channel: 1
AP id: 0
Status: 1
Auto connect: 1
SSID (5): XXXXX
Passphrase (8): XXXXXXXX
BSSID set: 0
Connecting to bcn 0
del if1
mode : sta(xx:xx:xx:xx:xx:xx)
scandone
........................scandone
state: 0 -> 2 (b0)
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld
