For illustration, the application supports a command-line interface and an fdump command that seeks to the specified offset of a file and hex dumps the specified number of bytes in 16-byte chunks. The output showing the problem is below:\
>fdump /report.log 26564
000067C4: FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000067D4: 73 FD C9 A2 04 23 17 17 17 70 02 00 00 00 00 EF
000067E4: read failed (0 bytes returned)
000067F4: read failed (0 bytes returned)readBytes(my16ByteBuffer,16) fails for everything between file offsets 0x67DF (26591) and 0x69E4 (27108), but works for everything outside this range
>fdump /report.log 27072
000069C0: read failed (0 bytes returned)
000069D0: read failed (0 bytes returned)
000069E0: read failed (0 bytes returned)
000069F0: 67 76 6A EF 1F 17 00 00 F0 4B 00 3F 00 00 00 00The directory and file information reports the file size as 75888 and the fdump function works right up to the end of the file.
