Im trying to use the callback function in PubSubClient so I can subscribe to a mqtt topic but it fails to compile.
My code is a tweaked version of the callback example PubSubClient provides.
#include <PubSubClient.h>
// Update these with values suitable for your network.
const char* ssid = ".";
const char* password = "";
char* server = "";
// Callback function header
void callback(char* topic, byte* payload, unsigned int length);
WiFiClient wifiClient;
PubSubClient client(server, 1883, callback, wifiClient);
void callback(char* topic, byte* payload, unsigned int length) {
// In order to republish this payload, a copy must be made
// as the orignal payload buffer will be overwritten whilst
// constructing the PUBLISH packet.
// Allocate the correct amount of memory for the payload copy
byte* p = (byte*)malloc(length);
// Copy the payload to the new buffer
memcpy(p,payload,length);
client.publish("outTopic", p, length);
// Free the memory
free(p);
void setup()
delay(100);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
if (client.connect("esp8266Client"))
Serial.println("Connected to MQTT broker");
if (client.publish("outTopic","hello world"))
Serial.println("Publish ok");
Serial.println("Publish failed");
client.subscribe("inTopic");
Serial.println("MQTT connect failed");
Serial.println("Will reset and try again...");
abort();
void loop()
client.loop();
}the errors I get are
Arduino: 1.6.1 (Windows 8.1), Board: "Generic ESP8266 board"
Build options changed, rebuilding all
Using library ESP8266WiFi in folder: C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\libraries\ESP8266WiFi
Using library PubSubClient in folder: C:\Users\user\Desktop\arduino-ESP8266\libraries\PubSubClient (legacy)
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\libraries\ESP8266WiFi\src -IC:\Users\user\Desktop\arduino-ESP8266\libraries\PubSubClient C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\mqtt_publish_in_callback.cpp -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\mqtt_publish_in_callback.cpp.o
mqtt_publish_in_callback.ino:23:16: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
mqtt_publish_in_callback.ino: In function 'void callback(char*, byte*, unsigned int)':
mqtt_publish_in_callback.ino:41:39: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
mqtt_publish_in_callback.ino: In function 'void setup()':
mqtt_publish_in_callback.ino:68:37: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
mqtt_publish_in_callback.ino:71:48: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
mqtt_publish_in_callback.ino:79:31: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\libraries\ESP8266WiFi\src -IC:\Users\user\Desktop\arduino-ESP8266\libraries\PubSubClient C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\libraries\ESP8266WiFi\src\ESP8266WiFi.cpp -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\ESP8266WiFi\ESP8266WiFi.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\libraries\ESP8266WiFi\src -IC:\Users\user\Desktop\arduino-ESP8266\libraries\PubSubClient C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\libraries\ESP8266WiFi\src\WiFiClient.cpp -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\ESP8266WiFi\WiFiClient.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\libraries\ESP8266WiFi\src -IC:\Users\user\Desktop\arduino-ESP8266\libraries\PubSubClient C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\libraries\ESP8266WiFi\src\WiFiServer.cpp -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\ESP8266WiFi\WiFiServer.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\libraries\ESP8266WiFi\src -IC:\Users\user\Desktop\arduino-ESP8266\libraries\PubSubClient C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\libraries\ESP8266WiFi\src\WiFiUdp.cpp -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\ESP8266WiFi\WiFiUdp.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\libraries\ESP8266WiFi\src -IC:\Users\user\Desktop\arduino-ESP8266\libraries\PubSubClient -IC:\Users\user\Desktop\arduino-ESP8266\libraries\PubSubClient\utility C:\Users\user\Desktop\arduino-ESP8266\libraries\PubSubClient\PubSubClient.cpp -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\PubSubClient\PubSubClient.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-as -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\cont.S.o C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266\cont.S
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -MMD -std=c99 -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266\cont_util.c -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\cont_util.c.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -MMD -std=c99 -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266\core_esp8266_noniso.c -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\core_esp8266_noniso.c.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -MMD -std=c99 -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266\core_esp8266_wiring.c -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\core_esp8266_wiring.c.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -MMD -std=c99 -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266\core_esp8266_wiring_analog.c -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\core_esp8266_wiring_analog.c.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -MMD -std=c99 -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266\core_esp8266_wiring_digital.c -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\core_esp8266_wiring_digital.c.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -MMD -std=c99 -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266\core_esp8266_wiring_pulse.c -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\core_esp8266_wiring_pulse.c.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-gcc -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -MMD -std=c99 -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266\core_esp8266_wiring_shift.c -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\core_esp8266_wiring_shift.c.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266\abi.cpp -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\abi.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266\core_esp8266_main.cpp -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\core_esp8266_main.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266\HardwareSerial.cpp -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\HardwareSerial.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266\i2c.cpp -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\i2c.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266\IPAddress.cpp -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\IPAddress.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266\Print.cpp -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\Print.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266\Stream.cpp -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\Stream.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266\Tone.cpp -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\Tone.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266\WMath.cpp -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\WMath.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -IC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//include -c -Os -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266 -IC:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\variants\esp01 C:\Users\user\Desktop\arduino-ESP8266\hardware\esp8266com\esp8266\cores\esp8266\WString.cpp -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\WString.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-ar cru C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp/core.a C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\cont.S.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-ar cru C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp/core.a C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\cont_util.c.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-ar cru C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp/core.a C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\core_esp8266_noniso.c.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-ar cru C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp/core.a C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\core_esp8266_wiring.c.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-ar cru C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp/core.a C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\core_esp8266_wiring_analog.c.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-ar cru C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp/core.a C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\core_esp8266_wiring_digital.c.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-ar cru C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp/core.a C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\core_esp8266_wiring_pulse.c.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-ar cru C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp/core.a C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\core_esp8266_wiring_shift.c.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-ar cru C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp/core.a C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\abi.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-ar cru C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp/core.a C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\core_esp8266_main.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-ar cru C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp/core.a C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\HardwareSerial.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-ar cru C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp/core.a C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\i2c.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-ar cru C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp/core.a C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\IPAddress.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-ar cru C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp/core.a C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\Print.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-ar cru C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp/core.a C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\Stream.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-ar cru C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp/core.a C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\Tone.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-ar cru C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp/core.a C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\WMath.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-ar cru C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp/core.a C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\WString.cpp.o
C:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-gcc -nostdlib -Wl,--no-check-sections -u call_user_start -Wl,-static -LC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//lib -LC:\Users\user\Desktop\arduino-ESP8266/hardware/tools/esp8266/sdk//ld -Teagle.app.v6.ld -o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp/mqtt_publish_in_callback.cpp.elf -Wl,--start-group C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\mqtt_publish_in_callback.cpp.o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\ESP8266WiFi\ESP8266WiFi.cpp.o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\ESP8266WiFi\WiFiClient.cpp.o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\ESP8266WiFi\WiFiServer.cpp.o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\ESP8266WiFi\WiFiUdp.cpp.o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp\PubSubClient\PubSubClient.cpp.o C:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp/core.a -lc -lgcc -lhal -lphy -lnet80211 -llwip -lwpa -lmain -lpp -Wl,--end-group -LC:\Users\user\AppData\Local\Temp\build5653019635830876368.tmp
c:/users/user/desktop/arduino-esp8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/lib\libc.a(lib_a-mallocr.o):(.literal+0x2c): undefined reference to `_sbrk_r'
c:/users/user/desktop/arduino-esp8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/lib\libc.a(lib_a-mallocr.o): In function `malloc_extend_top':
d:\ivan\projects\arduinoesp\toolchain\dl\esp-newlib\build\xtensa-lx106-elf\newlib\libc\stdlib/../../../../../newlib/libc/stdlib/mallocr.c:2165: undefined reference to `_sbrk_r'
d:\ivan\projects\arduinoesp\toolchain\dl\esp-newlib\build\xtensa-lx106-elf\newlib\libc\stdlib/../../../../../newlib/libc/stdlib/mallocr.c:2202: undefined reference to `_sbrk_r'
c:/users/user/desktop/arduino-esp8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/lib\libc.a(lib_a-freer.o): In function `_malloc_trim_r':
d:\ivan\projects\arduinoesp\toolchain\dl\esp-newlib\build\xtensa-lx106-elf\newlib\libc\stdlib/../../../../../newlib/libc/stdlib/mallocr.c:3325: undefined reference to `_sbrk_r'
d:\ivan\projects\arduinoesp\toolchain\dl\esp-newlib\build\xtensa-lx106-elf\newlib\libc\stdlib/../../../../../newlib/libc/stdlib/mallocr.c:3332: undefined reference to `_sbrk_r'
c:/users/user/desktop/arduino-esp8266/hardware/tools/esp8266/xtensa-lx106-elf/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/lib\libc.a(lib_a-freer.o):d:\ivan\projects\arduinoesp\toolchain\dl\esp-newlib\build\xtensa-lx106-elf\newlib\libc\stdlib/../../../../../newlib/libc/stdlib/mallocr.c:3340: more undefined references to `_sbrk_r' follow
collect2.exe: error: ld returned 1 exit status
Error compiling.Thanks
TotalRetribution
