Exception (28):
epc1=0x40202704 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000049 depc=0x00000000
I don't know what to do anymore... Please help me ! I'm accepting even a code that works only to know that the problem isn't my shield
Explore... Chat... Share...
ESP8266 Blink by Simon Peter
Blink the blue LED on the ESP-01 module
This example code is in the public domain
The blue LED on the ESP-01 module is connected to GPIO1
(which is also the TXD pin; so we cannot use Serial.print() at the same time)
Note that this sketch uses LED_BUILTIN to find the pin with the internal LED
pinMode(LED_BUILTIN, OUTPUT); // Initialize the LED_BUILTIN pin as an output
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, LOW); // Turn the LED on (Note that LOW is the voltage level
// but actually the LED is on; this is because
// it is active low on the ESP-01)
delay(1000); // Wait for a second
digitalWrite(LED_BUILTIN, HIGH); // Turn the LED off by making the voltage HIGH
delay(2000); // Wait for two seconds (to demonstrate the active low LED)
}It takes about 20-25 seconds for home assistant c[…]
