int s = 0;In fact any declaration of variable s (String, long, int, byte) causes a compile error.
Explore... Chat... Share...
int s = 0;/home/martin/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//lib/liblwip.a(dhcpserver.o):(.bss+0x10): multiple definition of `s'
/tmp/build2476085467671613982.tmp/Sketch_Buffet.cpp.o:/home/martin/arduino/arduino-1.6.5/Sketch_Buffet.ino:113: first defined here
/home/martin/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/1.20.0-26-gb404fb9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld: Warning: size of symbol `s' changed from 4 in /tmp/build2476085467671613982.tmp/Sketch_Buffet.cpp.o to 2 in /home/martin/.arduino15/packages/esp8266/hardware/esp8266/1.6.5-947-g39819f0/tools/sdk//lib/liblwip.a(dhcpserver.o)
