I tried the pi calculation performance test I found here http://forum.arduino.cc/index.php?topic=138802.msg1042841#msg1042841.
I did some minor modification, but the code crashes everytime.
// Pi_2
// Steve Curd
// December 2012
// This program approximates pi utilizing the Newton's approximation. It quickly
// converges on the first 5-6 digits of precision, but converges verrrry slowly
// after that. For example, it takes over a million iterations to get to 7-8
// significant digits.
// http://forum.arduino.cc/index.php?topic=138802.0
#define ITERATIONS 1000000L // number of iterations
#define FLASH 10000 // blink LED every 1000 iterations
pinMode(2, OUTPUT); // Initialize the BUILTIN_LED pin as an output
delay(1000);
unsigned long start, time;
unsigned long niter=ITERATIONS;
int LEDcounter = 0;
boolean alternate = false;
unsigned long i, count=0;
float x = 1.0;
float temp, pi=1.0;
Serial.print("Beginning ");
Serial.print(niter);
Serial.println(" iterations...");
start = millis();
for ( i = 2; i < niter; i++) {
x *= -1.0;
pi += x / (2.0f*(float)i-1.0f);
if (LEDcounter++ > FLASH) {
LEDcounter = 0;
if (alternate) {
digitalWrite(2, HIGH);
alternate = false;
} else {
digitalWrite(2, LOW);
alternate = true;
temp = 40000000.0 * pi;
// module.setDisplayToDecNumber( temp, 0x80);
time = millis() - start;
pi = pi * 4.0;
Serial.print("# of trials = ");
Serial.println(niter);
Serial.print("Estimate of pi = ");
Serial.println(pi, 10);
Serial.print("Time: "); Serial.print(time); Serial.println(" ms");
delay(2000);
The message on the serial interface is
Beginning 1000000 iterations...
ctx: cont
sp: 3ffe9b00 end: 3ffe9cf0 offset: 01b0
>>>stack>>>
3ffe9cb0: 000004c6 000016df 00000001 402010a3
3ffe9cc0: 3fffdc20 00000000 3ffe9d14 3ffe9d1c
3ffe9cd0: 3fffdc20 00000000 3ffe9d14 4020184a
3ffe9ce0: 00000000 00000000 3ffe8cd0 40100118
<<<stack<<<
ets Jan 8 2013,rst cause:1, boot mode:(3,7)
load 0x4010f000, len 1264, room 16
tail 0
chksum 0x42
csum 0x42
~ld
After commenting out this single line with the float calculation
pi += x / (2.0f*(float)i-1.0f);the program doesn't crash anymore.
The code is running fine on an Arduino Uno.
Any idea?
Reinhard
