I am trying with an ESP-01 and a sensor ds18b20 to check temp and share the variable with rest API,
Here my sketch
#include <aREST.h>
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 2
#define TEMPERATURE_PRECISION 9 // Lower resolution
#define LISTEN_PORT 80 // listen port API
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Create aREST instance
aREST rest = aREST();
// WiFi parameters
const char* ssid = "ozne";
const char* password = "*****";
WiFiServer server(LISTEN_PORT);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
int numberOfDevices; // Number of temperature devices found
float tempC; // Temperature
DeviceAddress tempDeviceAddress; // We'll use this variable to store a found device address
void setup(void)
// start serial port
Serial.println("Open temperature on the API");
rest.variable("temperature",&tempC);
rest.set_id("1");
rest.set_name("sonde1");
//init
Serial.println("Init wifi");
WiFi.mode(WIFI_STA);
WiFi.disconnect();
// Connect to WiFi
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
// Start the server
server.begin();
// Print the IP address
// Start up the library
sensors.begin();
// Grab a count of devices on the wire
numberOfDevices = sensors.getDeviceCount();
// locate devices on the bus
Serial.print("Locating devices...");
Serial.print("Found ");
Serial.print(numberOfDevices, DEC);
Serial.println(" devices.");
// report parasite power requirements
Serial.print("Parasite power is: ");
if (sensors.isParasitePowerMode()) Serial.println("ON");
else Serial.println("OFF");
// Loop through each device, print out address
for(int i=0;i<numberOfDevices; i++)
// Search the wire for address
if(sensors.getAddress(tempDeviceAddress, i))
Serial.print("Found device ");
Serial.print(i, DEC);
Serial.print(" with address: ");
//printAddress(tempDeviceAddress);
Serial.print("Setting resolution to ");
Serial.println(TEMPERATURE_PRECISION, DEC);
// set the resolution to TEMPERATURE_PRECISION bit (Each Dallas/Maxim device is capable of several different resolutions)
sensors.setResolution(tempDeviceAddress, TEMPERATURE_PRECISION);
Serial.print("Resolution actually set to: ");
Serial.print(sensors.getResolution(tempDeviceAddress), DEC);
}else{
Serial.print("Found ghost device at ");
Serial.print(" but could not detect address. Check power and cabling");
// function to print the temperature for a device
void printTemperature(DeviceAddress deviceAddress)
// method 1 - slower
//Serial.print("Temp C: ");
//Serial.print(sensors.getTempC(deviceAddress));
//Serial.print(" Temp F: ");
//Serial.print(sensors.getTempF(deviceAddress)); // Makes a second call to getTempC and then converts to Fahrenheit
// method 2 - faster
tempC = sensors.getTempC(deviceAddress);
Serial.print(tempC);
void loop(void)
// Handle REST calls
if (!client) {
return;
while(!client.available()){
delay(1);
rest.handle(client);
// call sensors.requestTemperatures() to issue a global temperature
// request to all devices on the bus
Serial.print("Requesting temperatures...");
sensors.requestTemperatures(); // Send the command to get temperatures
Serial.println("DONE");
// Loop through each device, print out temperature data
// Output the device ID
Serial.print("Temperature for device: ");
Serial.println(i,DEC);
// It responds almost immediately. Let's print out the data
printTemperature(tempDeviceAddress); // Use a simple function to print out the data
}else {
Serial.print("Ghost");
//else ghost device! Check your power requirements and cabling
//Wait 10 second before check Temp again
delay(20000);
}But when my esp start i have full exception :
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
load 0x4010f000, len 1264, room 16
tail 0
chksum 0x42
csum 0x42
~ld
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
Exception (4):
epc1=0x4010204b epc2=0x00000000 epc3=0x00000000 excvaddr=0x16491044 depc=0x00000000
ctx: sys
sp: 3ffe9770 end: 3fffffb0 offset: 01a0
>>>stack>>>
3ffe9910: 00000000 16491044 00000000 400005e1
3ffe9920: 401021fc 3fffc100 00000000 00000000
3ffe9930: 00000000 402141e0 00000000 00000000
3ffe9940: 402141e0 00000030 00000016 00000000
3ffe9950: 40102261 00000000 0007a120 00000007
3ffe9960: 00000000 60000e18 60000e00 00000007
3ffe9970: 00000000 00000018 04000102 00000000
3ffe9980: 16491044 00000000 00000000 00000000
3ffe9990: 00000000 00000000 00000000 00000000
3ffe99a0: 00000000 00000000 00000000 00000000
3ffe99b0: 00000000 00000000 00000000 00000000
3ffe99c0: 00000000 00000000 00000000 00000000
3ffe99d0: 00000000 00000000 00000000 00000000
3ffe99e0: 00000000 00000000 00000000 00000000
3ffe99f0: 00000000 00000000 00000000 00000000
3ffe9a00: 00000000 40102239 00000000 16491044
3ffe9a10: 00000000 00000000 00000000 00000000
3ffe9a20: 40240f60 402116cf 00000000 00000000
3ffe9a30: 16491044 00000000 00000000 00000000
3ffe9a40: 00000002 0000001c 402116cf 00000000
3ffe9a50: 00000000 16491044 00000000 400005e1
3ffe9a60: 401021fc 3fffc100 00000000 0000001c
3ffe9a70: 0000001c 402116cf 00000000 00000000
3ffe9a80: 402116cf 00000030 00000016 00000000
3ffe9a90: 40101a42 16491044 00000000 00000001
3ffe9aa0: fbf8ffff 04000002 3feffe00 000000a0
3ffe9ab0: 0000001a 00000018 04000102 00000000
3ffe9ac0: 16491044 00000000 00000000 0000001c
3ffe9ad0: 00000000 00000000 00000000 00000000
3ffe9ae0: 00000000 00000000 00000000 00000000
3ffe9af0: 00000000 00000000 00000000 00000000
3ffe9b00: 00000000 00000000 00000000 00000000
3ffe9b10: 00000000 00000000 00000000 00000000
3ffe9b20: 00000000 00000000 00000000 00000000
3ffe9b30: 00000000 00000000 00000000 00000000
3ffe9b40: 00000000 00000000 00000000 00000000
3ffe9b50: 00000000 00000000 00000000 00000000
3ffe9b60: 00000000 00000000 00000000 00000000
3ffe9b70: 00000000 00000000 00000000 00000000
3ffe9b80: 00000000 00000000 00000000 00000000
3ffe9b90: 00000000 00000000 00000000 00000000
3ffe9ba0: 00000000 00000000 00000000 00000000
3ffe9bb0: 00000000 00000000 00000000 00000000
3ffe9bc0: 00000000 00000000 00000000 00000000
3ffe9bd0: 00000000 00000000 00000000 00000000
3ffe9be0: 00000000 40102229 00000000 16491044
3ffe9bf0: 00000000 00000000 00000000 00000000
3ffe9c00: 40240f40 00000000 00000001 fbf8ffff
3ffe9c10: 04000002 3feffe00 00000000 00000000
3ffe9c20: 00000000 00000000 00000000 00000000
3ffe9c30: 00000000 00000000 00000000 400005e1
3ffe9c40: 401021fc 3fffc100 00000000 00000000
3ffe9c50: 00000000 402141f7 00000000 00000000
3ffe9c60: 402141f7 00000030 00000016 00000000
3ffe9c70: 402141f7 0003b1a1 00000000 00000000
3ffe9c80: 00000000 60000e18 60000e00 00000007
3ffe9c90: 00000000 00000018 04000102 01090cc8
3ffe9ca0: 16491044 00000000 00000000 00000000
3ffe9cb0: 00000000 00000000 00000000 00000000
3ffe9cc0: 00000000 00000000 00000000 00000000
3ffe9cd0: 00000000 00000000 00000000 00000000
3ffe9ce0: 00000000 00000000 00000000 00000000
3ffe9cf0: 00000000 00000000 00000000 00000000
3ffe9d00: 00000000 00000000 00000000 00000000
3ffe9d10: 00000000 00000000 00000000 00000000
3ffe9d20: 00000000 40102239 00000000 16491044
3ffe9d30: 00000000 00000000 00000000 00000000
3ffe9d40: 40240f60 402116cf 00000000 00000000
3ffe9d50: 16491044 00000000 00000000 00000000
3ffe9d60: 40102261 0000001c 16491044 00000000
3ffe9d70: 00000000 16491044 00000000 400005e1
3ffe9d80: 401021fc 3fffc100 00000000 0000001c
3ffe9d90: 0000001c 402116cf 00000000 00000000
3ffe9da0: 402116cf 00000030 00000016 00000000
3ffe9db0: 40101a42 16491044 0000001c 00000001
3ffe9dc0: fbf8ffff 04000002 3feffe00 000000a0
3ffe9dd0: 0000001a 00000018 04000102 00000000
3ffe9de0: 16491044 00000000 00000000 0000001c
3ffe9df0: 00000000 00000000 00000000 00000000
3ffe9e00: 00000000 00000000 00000000 00000000
3ffe9e10: 00000000 00000000 00000000 00000000
3ffe9e20: 00000000 00000000 00000000 00000000
3ffe9e30: 00000000 00000000 00000000 00000000
3ffe9e40: 00000000 00000000 00000000 00000000
3ffe9e50: 00000000 00000000 00000000 00000000
3ffe9e60: 00000000 00000000 00ff0000 00000000
3ffe9e70: 00000000 00000000 00000000 00000000
3ffe9e80: 00000000 00000000 00000000 00000000
3ffe9e90: 00000000 00000000 00000000 00000000
3ffe9ea0: 00000000 00000000 00000000 00000000
3ffe9eb0: 00000000 00000000 00000000 00000000
3ffe9ec0: 00000000 00000000 00000000 00000000
3ffe9ed0: 00000000 00000000 00000000 00000000
3ffe9ee0: 00000000 00000000 00000000 00000000
3ffe9ef0: 00000000 00000000 00000000 00000000
3ffe9f00: 00000000 40102229 00000000 16491044
3ffe9f10: 00000000 00000000 00000000 00000000
3ffe9f20: 40240f40 0000001c 00000001 fbf8ffff
3ffe9f30: 04000002 3feffe00 00000000 00000000
3ffe9f40: 00000000 00000000 00000000 00000000
3ffe9f50: 00000000 00000000 00000000 400005e1
3ffe9f60: 401021fc 3fffc100 00000000 0000001c
3ffe9f70: 0000001c 402116cf 00000000 00000000
3ffe9f80: 402116cf 00000030 00000016 00000000
3ffe9f90: 40101a42 16491044 00000000 00000001
3ffe9fa0: fbf8ffff 04000002 3feffe00 000000a0
3ffe9fb0: 0000001a 00000018 04000102 00000000
3ffe9fc0: 16491044 00000000 00000000 0000001c
3ffe9fd0: 00000000 00000000 00000000 00000000
3ffe9fe0: 00000000 00000000 00000000 00000000
3ffe9ff0: 00000000 00000000 00000000 00000000
3ffea000: 00000000 00000000 00000000 00000000
3ffea010: 00000000 00000000 00000000 00000000
3ffea020: 00000000 00000000 00000000 00000000
3ffea030: 00000000 00000000 00000000 00000000
3ffea040: 00000000 00000000 00000000 00000000
3ffea050: 00000000 00000000 00000000 00000000
3ffea060: 00000000 00000000 00000000 00000000
3ffea070: 00000000 00000000 00000000 00000000
3ffea080: 00000000 00000000 00000000 00000000
3ffea090: 00000000 00000000 00000000 00000000
3ffea0a0: 00000000 00000000 00000000 00000000
3ffea0b0: 00000000 00000000 00000000 00000000
3ffea0c0: 00000000 00000000 00000000 00000000
3ffea0d0: 00000000 00000000 00000000 00000000
3ffea0e0: 00000000 40102229 00000000 16491044
3ffea0f0: 00000000 00000000 00000000 00000000
3ffea100: 40240f40 00000000 00000001 fbf8ffff
3ffea110: 04000002 3feffe00 00000000 00000000
3ffea120: 00000000 00000000 00000000 00000000
3ffea130: 00000000 00000000 00000000 400005e1
3ffea140: 401021fc 3fffc100 00000000 00000000
3ffea150: 00000000 402141f7 00000000 00000000
3ffea160: 402141f7 00000030 00000016 00000000
3ffea170: 402141f7 0003b156 00000000 00000000
3ffea180: 00000000 60000e18 60000e00 00000007
3ffea190: 00000000 00000018 04000102 01090cc8
3ffea1a0: 16491044 00000000 00000000 00000000
3ffea1b0: 00000000 3ffe8f88 00000000 00000000
3ffea1c0: 00000000 00000000 011f1a7b 011e1a30
3ffea1d0: 40201454 00000000 00000000 00000000
3ffea1e0: 00000000 00000000 00000000 00000000
3ffea1f0: 00000000 00000000 00000000 00000000
3ffea200: 00000000 00000000 00000000 00000000
3ffea210: 00000000 00000000 00000000 00000000
3ffea220: 00000000 40102239 00000000 16491044
3ffea230: 00000000 00000000 00000000 00000000
3ffea240: 40240f60 402116cf 00000000 00000000
3ffea250: 16491044 00000000 00000000 00000000
3ffea260: 40102261 0000001c 16491044 00000000
3ffea270: 00000000 16491044 00000000 400005e1
3ffea280: 401021fc 3fffc100 00000000 0000001c
3ffea290: 0000001c 402116cf 00000000 00000000
3ffea2a0: 402116cf 00000030 00000016 00000000
3ffea2b0: 40101a42 16491044 00000000 00000001
3ffea2c0: fbf8ffff 04000002 3feffe00 000000a0
3ffea2d0: 0000001a 00000018 04000102 00000000
3ffea2e0: 16491044 00000000 00000000 0000001c
3ffea2f0: 00000000 00000000 00000000 00000000
3ffea300: 00000000 00000000 00000000 00000000
3ffea310: 00000000 00000000 00000000 00000000
3ffea320: 40100380 3fffff8c 00000000 00000000
3ffea330: 3ffeb340 00000000 00000000 feefeffe
3ffea340: 00000000 00000000 00000000 00000000
3ffea350: 00000000 00000000 00000000 00000000
3ffea360: 00000000 00000000 00000000 00000000
3ffea370: 00000000 00000000 00000000 00000000
3ffea380: 00000000 00000000 00000000 00000000
3ffea390: 00000000 00000000 00000000 00000000
3ffea3a0: 00000000 00000000 00000000 00000000
3ffea3b0: 00000000 00000000 00000000 00000000
3ffea3c0: 00000000 00000000 00000000 00000000
3ffea3d0: 00000000 00000000 00000000 00000000
3ffea3e0: 00000000 00000000 00000000 00000000
3ffea3f0: 00000000 00000000 00000000 00000000
3ffea400: 00000000 40102229 00000000 16491044
3ffea410: 00000000 00000000 00000000 00000000
3ffea420: 40240f40 00000000 00000001 fbf8ffff
3ffea430: 04000002 3feffe00 00000000 00000000
3ffea440: 00000000 00000000 00000000 00000000
3ffea450: 00000000 00000000 00000000 400005e1
3ffea460: 401021fc 3fffc100 00000000 00000000
3ffea470: 00000000 402141f7 00000000 00000000
3ffea480: 402141f7 00000030 00000016 00000000
3ffea490: 402141f7 0003b11d 00000000 00000007
3ffea4a0: 00000000 60000e18 60000e00 00000007
3ffea4b0: 00000000 00000018 04000102 01090cc8
3ffea4c0: 16491044 00000000 00000000 00000000
3ffea4d0: 00000000 00000000 00000000 00000000
3ffea4e0: 00000000 00000000 00000000 00000000
3ffea4f0: 00000000 00000000 00000000 00000000
3ffea500: 00000000 00000000 00000000 00000000
3ffea510: 00000000 00000000 00000000 00000000
3ffea520: 00000000 00000000 00000000 00000000
3ffea530: 00000000 00000000 00000000 00000000
3ffea540: 00000000 40102239 00000000 16491044
3ffea550: 00000000 00000000 00000000 00000000
3ffea560: 40240f60 402141f7 00000000 00000000
3ffea570: 16491044 00000000 00000000 00000000
3ffea580: 00000000 00000000 00000000 00000000
3ffea590: 00000000 16491044 00000000 400005e1
3ffea5a0: 401021fc 3fffc100 00000000 00000000
3ffea5b0: 00000000 402141f7 00000000 00000000
3ffea5c0: 402141f7 00000030 00000016 00000000
3ffea5d0: 402141f7 0003b0f7 00000000 00000000
3ffea5e0: 00000000 60000e18 60000e00 00000007
3ffea5f0: 00000000 00000018 04000102 01090cc8
3ffea600: 16491044 00000000 00000000 00000000
3ffea610: 00000000 00000000 00000000 00000000
3ffea620: 00000000 00000000 00000000 00000000
3ffea630: 00000000 00000000 00000000 00000000
3ffea640: 00000000 00000000 00000000 00000000
3ffea650: 00000000 00000000 00000000 00000000
3ffea660: 00000000 00000000 00000000 00000000
3ffea670: 00000000 00000000 00000000 00000000
3ffea680: 00000000 40102239 00000000 16491044
3ffea690: 00000000 00000000 00000000 00000000
3ffea6a0: 40240f60 402116cf 00000000 00000000
3ffea6b0: 16491044 00000000 00000000 00000000
3ffea6c0: 40102261 0000001c 16491044 00000000
3ffea6d0: 00000000 16491044 00000000 400005e1
3ffea6e0: 401021fc 3fffc100 00000000 0000001c
3ffea6f0: 0000001c 402116cf 00000000 00000000
3ffea700: 402116cf 00000030 00000016 00000000
3ffea710: 40101a42 16491044 00000000 00000001
3ffea720: fbf8ffff 04000002 3feffe00 000000a0
3ffea730: 0000001a 00000018 04000102 00000000
3ffea740: 00000008 00000000 00000000 0000001c
3ffea750: 00000000 00000000 00000000 00000000
3ffea760: 00000000 00000000 00000000 00000000
3ffea770: 00000000 00000000 00000000 00000000
3ffea780: 00000000 00000000 00000000 00000000
3ffea790: 00000000 00000000 00000000 00000000
3ffea7a0: 00000000 00000000 00000000 00000000
3ffea7b0: 00000000 00000000 00000000 00000000
3ffea7c0: 00000000 00000000 00000000 00000000
3ffea7d0: 00000000 00000000 00000000 00000000
3ffea7e0: 00000000 00000000 00000000 00000000
3ffea7f0: 00000000 00000000 00000000 00000000
3ffea800: 00000000 00000000 00000000 00000000
3ffea810: 00000000 00000000 00000000 00000000
3ffea820: 00000000 00000000 00000000 00000000
3ffea830: 00000000 00000000 00000000 00000000
3ffea840: 00000000 00000000 00000000 00000000
3ffea850: 00000000 00000000 00000000 00000000
3ffea860: 00000000 40102229 00000000 00000008
3ffea870: 00000000 00000000 00000000 00000000
3ffea880: 40240f40 00000000 00000001 fbf8ffff
3ffea890: 04000002 3feffe00 00000000 00000000
3ffea8a0: 00000000 00000000 00000000 00000000
3ffea8b0: 00000000 00000000 00000000 400005e1
3ffea8c0: 401021fc 3fffc100 00000000 00000000
3ffea8d0: 00000000 402141ff 00000000 00000000
3ffea8e0: 402141ff 00000030 00000016 00000000
3ffea8f0: 5ffffe00 0003b0ba 00000000 00000000
3ffea900: 00000000 60000e18 60000e00 00000007
3ffea910: 00000000 00000018 04000102 01090cc8
3ffea920: 0003b0ba 00000000 00000700 00000000
3ffea930: 00000000 00000000 00000000 00000000
3ffea940: 00000000 00000000 00000000 00000000
3ffea950: 00000000 00000000 00000000 00000000
3ffea960: 00000000 00000000 00000000 00000000
3ffea970: 00000000 00000000 00000000 00000000
3ffea980: 00000000 00000000 00000000 00000000
3ffea990: 00000000 00000000 00000000 00000000
3ffea9a0: 00000000 40102239 00000000 00000008
3ffea9b0: 00000000 00000000 00000000 00000000
3ffea9c0: 40240f60 402141e3 00000000 00000000
3ffea9d0: 00000008 00000000 00000000 00000000
3ffea9e0: 40102261 0000001d 00000008 00000000
3ffea9f0: 00000000 00000008 00000000 400005e1
3ffeaa00: 401021fc 3fffc100 00000000 0000001d
3ffeaa10: 0000001d 402141e3 00000000 00000000
3ffeaa20: 402141e3 00000030 00000016 00000000
3ffeaa30: 00000000 00000000 0007a120 00000007
3ffeaa40: 00000000 60000e18 60000e00 00000007
3ffeaa50: 00000000 00000018 04000102 00000000
3ffeaa60: 00000008 00000000 00000000 0000001d
3ffeaa70: 00000000 00000000 00000000 00000000
3ffeaa80: 00000000 00000000 00000000 00000000
3ffeaa90: 00000000 00000000 00000000 00000000
3ffeaaa0: 00000000 00000000 00000000 00000000
3ffeaab0: 00000000 00000000 00000000 00000000
3ffeaac0: 00000000 00000000 00000000 00000000
3ffeaad0: 00000000 00000000 00000000 00000000
3ffeaae0: 00000000 40102239 00000000 00000008
3ffeaaf0: 00000000 00000000 00000000 00000000
3ffeab00: 40240f60 402141e3 00000000 00000000
3ffeab10: 00000008 00000000 00000000 00000000
3ffeab20: 00000002 0000001d 402141e3 00000000
3ffeab30: 00000000 00000008 00000000 400005e1
3ffeab40: 401021fc 3fffc100 00000000 0000001d
3ffeab50: 0000001d 402141e3 00000000 00000000
3ffeab60: 402141e3 00000030 00000016 00000000
3ffeab70: 00000000 00000000 0007a120 00000007
3ffeab80: 00000000 60000e18 60000e00 00000007
3ffeab90: 00000000 00000018 04000102 00000000
3ffeaba0: 00000008 00000000 00000000 0000001d
3ffeabb0: 00000000 00000000 00000000 00000000
3ffeabc0: 00000000 00000000 00000000 00000000
3ffeabd0: 00000000 00000000 00000000 00000000
3ffeabe0: 00000000 00000000 00000000 00000000
3ffeabf0: 00000000 00000000 00000000 00000000
3ffeac00: 00000000 00000000 00000000 00000000
3ffeac10: 00000000 00000000 00000000 00000000
3ffeac20: 00000000 40102239 00000000 00000008
3ffeac30: 00000000 00000000 00000000 00000000
3ffeac40: 40240f60 402141e3 00000000 00000000
3ffeac50: 00000008 00000000 00000000 00000000
3ffeac60: 00000002 0000001d 402141e3 00000000
3ffeac70: 00000000 00000008 00000000 400005e1
3ffeac80: 401021fc 3fffc100 00000000 0000001d
3ffeac90: 0000001d 402141e3 00000000 00000000
3ffeaca0: 402141e3 00000030 00000016 00000000
3ffeacb0: 00000000 00000000 0007a120 00000007
3ffeacc0: 00000000 60000e18 60000e00 00000007
3ffeacd0: 00000000 00000018 04000102 00000000
3ffeace0: 02121bac 00000000 00000000 0000001d
3ffeacf0: 00000000 00000000 00000000 00000000
3ffead00: 00000000 00000000 00000000 00000000
3ffead10: 00000000 00000000 00000000 00000000
3ffead20: 00000000 00000000 00000000 00000000
3ffead30: 00000000 00000000 00000000 00000000
3ffead40: 00000000 00000000 00000000 00000000
3ffead50: 00000000 00000000 00000000 00000000
3ffead60: 00000000 40102239 00000000 02121bac
3ffead70: 00000000 00000000 00000000 00000000
3ffead80: 40240f60 402141f7 00000000 00000000
3ffead90: 02121bac 00000000 00000000 00000000
3ffeada0: 00000002 00000000 402141f7 00000000
3ffeadb0: 00000000 02121bac 00000000 400005e1
3ffeadc0: 401021fc 3fffc100 00000000 00000000
3ffeadd0: 00000000 402141f7 00000000 00000000
3ffeade0: 402141f7 00000030 00000016 00000000
3ffeadf0: 402141f7 0003b046 00000000 00000000
3ffeae00: 00000000 60000e18 60000e00 00000007
3ffeae10: 00000000 00000018 04000102 01090cc8
3ffeae20: 02121bac 00000000 00000000 00000000
3ffeae30: 00000000 00000000 00000000 00000000
3ffeae40: 00000000 00000000 00000000 00000000
3ffeae50: 00000000 00000000 00000000 00000000
3ffeae60: 00000000 00000000 00000000 00000000
3ffeae70: 00000000 00000000 00000000 00000000
3ffeae80: 00000000 00000000 00000000 00000000
3ffeae90: 00000000 00000000 00000000 00000000
3ffeaea0: 00000000 40102239 00000000 02121bac
3ffeaeb0: 00000000 00000000 00000000 00000000
3ffeaec0: 40240f60 402141f7 00000000 00000000
3ffeaed0: 02121bac 00000000 00000000 00000000
3ffeaee0: 40102261 00000000 02121bac 00000000
3ffeaef0: 00000000 02121bac 00000000 400005e1
3ffeaf00: 401021fc 3fffc100 00000000 00000000
3ffeaf10: 00000000 402141f7 00000000 00000000
3ffeaf20: 402141f7 00000030 00000016 00000000
3ffeaf30: 402141f7 0003b020 00000000 00000000
3ffeaf40: 00000000 60000e18 60000e00 00000007
3ffeaf50: 00000000 00000018 04000102 01090cc8
3ffeaf60: 02121bac 00000000 00000000 00000000
3ffeaf70: 00000000 00000000 00000000 00000000
3ffeaf80: 00000000 00000000 00000000 00000000
3ffeaf90: 00000000 00000000 00000000 00000000
3ffeafa0: 00000000 00000000 00000000 00000000
3ffeafb0: 00000000 00000000 00000000 00000000
3ffeafc0: 00000000 00000000 00000000 00000000
3ffeafd0: 00000000 00000000 00000000 00000000
3ffeafe0: 00000000 40102239 00000000 02121bac
3ffeaff0: 00000000 00000000 00000000 00000000
3ffeb000: 40240f60 4021420a 00000000 00000000
3ffeb010: 02121bac 00000000 00000000 00000000
3ffeb020: 40102261 0000001c 02121bac 00000000
3ffeb030: 00000000 02121bac 00000000 400005e1
3ffeb040: 401021fc 3fffc100 00000000 0000001c
3ffeb050: 0000001c 4021420a 00000000 00000000
3ffeb060: 4021420a 00000030 00000016 00000000
3ffeb070: 02121990 0003aff5 00000000 00000000
3ffeb080: 00000000 60000e18 60000e00 00000007
3ffeb090: 00000000 00000018 04000102 00ff0000
3ffeb0a0: 0003aff5 00000000 02121990 0000001c
3ffeb0b0: 00000000 00000000 00000000 00000000
3ffeb0c0: 00000000 00000000 00000000 00000000
3ffeb0d0: 00000000 00000000 00000000 00000000
3ffeb0e0: 00000000 00000000 00000000 00000000
3ffeb0f0: 00000000 00000000 00000000 00000000
3ffeb100: 00000000 00000000 00000000 00000000
3ffeb110: 00000000 00000000 00000000 00000000
3ffeb120: 00000000 40102239 00000000 16491044
3ffeb130: 00000000 00000000 00000000 00000000
3ffeb140: 40240f60 40206ba0 00000000 00000000
3ffeb150: 16491044 00000000 00000000 7fffffff
3ffeb160: 00000002 00000000 40206ba0 00000000
3ffeb170: 00000000 16491044 00000000 400005e1
3ffeb180: 401021fc 3fffc100 0000001c 00000000
3ffeb190: 00000000 40206ba0 401050f0 3fffc200
3ffeb1a0: 40206ba0 00000030 00000016 00000000
3ffeb1b0: 40206b99 00000000 402072f4 3fff4e00
3ffeb1c0: 0000000e 40003bbc 3fffc1e0 4000dc3c
3ffeb1d0: 60000818 ffff5f80 00000032 3fff4e00
3ffeb1e0: 00000001 0000001c 0001c200 00000000
3ffeb1f0: 00000001 0000001c 0001c200 00000030
3ffeb200: 00000000 00000000 00000000 00000000
3ffeb210: 00000000 00000000 00000000 00000000
3ffeb220: 00000000 00000000 00000000 00000000
3ffeb230: 00000000 00000000 00000000 00000000
3ffeb240: 00000000 00000000 00000000 00000000
3ffeb250: 00000000 00000000 00000000 00000000
3ffeb260: 00000000 00000000 00000000 00000000
3ffeb270: 00000000 00000000 00000000 00000000
3ffeb280: 00000000 00000000 00000000 00000000
3ffeb290: 40206b99 00000000 00000000 00000000
3ffeb2a0: 3fff4df0 40206d71 3fff4e00 40206e2e
3ffeb2b0: 00000000 00000000 00000000 00000000
3ffeb2c0: 00000000 00000000 00000000 3ffeb36c
3ffeb2d0: 0000001c 00000000 3ffeb398 40207036
3ffeb2e0: 0001c200 00000000 00000000 00000000
3ffeb2f0: 3fffdc20 00000000 3ffeb398 402025ac
3ffeb300: 00000000 00000000 00000000 00000000
3ffeb310: 00000000 00000000 00000000 3ffeb36c
3ffeb320: 3fffdc20 00000000 3ffeb364 40202047
3ffeb330: 00000000 00000000 3ffea320 40100378
3ffeb340: feefeffe 3ffea320 00000002 00000004
3ffeb350: 400046ea 00000000 00000000 16491044
3ffeb360: 00000000 00000000 0003af53 00000000
3ffeb370: 00000000 3ffe8f58 00000000 000003e8
3ffeb380: 00000000 00000001 00000000 00000000
3ffeb390: 00000000 00000000 3ffe8f58 00000000
3ffeb3a0: 000003e8 00000000 00000000 00000000
3ffeb3b0: 00000000 00000000 00000000 ffffffff
3ffeb3c0: 3ffe8f88 00000000 00000000 00000000
3ffeb3d0: 00000000 00000000 00000000 00000000
3ffeb3e0: 3ffeb3f0 3fff4818 00000000 00000000
3ffeb3f0: 00000000 00000000 00000000 00000000
3ffeb400: 00000000 00000000 00000000 00000000
3ffeb410: 00000000 00000000 00000000 00000000
3ffeb420: 00000000 00000000 00000000 00000000
3ffeb430: 00000000 00000000 00000000 00000000
3ffeb440: 00000000 00000000 00000000 00000000
3ffeb450: 00000000 00000000 00000000 00000000
3ffeb460: 00000000 00000000 00000000 00000000
3ffeb470: 00000000 00000000 00000000 00000000
3ffeb480: 00000000 00000000 00000000 00000000
3ffeb490: 00000000 00000000 00000000 00000000
3ffeb4a0: 00000000 00000000 00000000 00000000
3ffeb4b0: 00000000 00000000 00000000 00000000
3ffeb4c0: 00000000 00000000 00000000 00000000
3ffeb4d0: 00000000 00000000 00000000 00000000
3ffeb4e0: 00000000 00000000 00000000 00000000
3ffeb4f0: 00000000 00000000 00000000 00000000
3ffeb500: 00000000 00000000 00000000 00000000
3ffeb510: 00000000 00000000 00000000 00000000
3ffeb520: 00000000 00000000 00000000 00000000
3ffeb530: 00000000 00000000 00000000 00000000
3ffeb540: 00000000 00000000 00000000 00000000
3ffeb550: 00000000 00000000 00000000 00000000
3ffeb560: 00000000 00000000 00000000 00000000
3ffeb570: 00000000 00000000 00000000 00000000
3ffeb580: 00000000 00000000 00000000 00000000
3ffeb590: 00000000 00000000 00000000 00000000
3ffeb5a0: 00000000 00000000 00000000 00000000
3ffeb5b0: 00000000 00000000 00000000 00000000
3ffeb5c0: 00000000 00000000 00000000 00000000
3ffeb5d0: 00000000 00000000 00000000 00000000
3ffeb5e0: 00000000 00000000 00000000 00000000
3ffeb5f0: 00000000 00000000 00000000 00000000
3ffeb600: dede43d0 00000000 00000000 00000000
3ffeb610: 00000000 00000000 00000000 00000000
3ffeb620: 00000000 00000000 00000000 00000000
3ffeb630: 00000000 00000000 00000000 00000000
3ffeb640: 00000000 00000000 00000000 00000000
3ffeb650: 00000000 00000000 00000000 00000000
3ffeb660: 00000000 00000000 00000000 00000000
3ffeb670: 00000000 00000000 00000000 00000000
3ffeb680: 00000000 00000000 00000000 00000000
3ffeb690: 00000000 00000000 00000000 00000000
3ffeb6a0: 00000000 00000000 00000000 00000000
3ffeb6b0: 00000000 00000000 00000000 00000000
3ffeb6c0: 00000000 00000000 00000000 00000000
3ffeb6d0: 00000000 00000000 00000000 00000000
3ffeb6e0: 00000000 00000000 00000000 00000000
3ffeb6f0: 00000000 00000000 00000000 00000000
3ffeb700: 00000000 00000000 00000000 00000000
3ffeb710: 00000000 00000000 00000000 00000000
3ffeb720: 00000000 00000000 00000000 00000000
3ffeb730: 00000000 00000000 00000000 00000000
3ffeb740: 00000000 00000000 00000000 00000000
3ffeb750: 00000000 00000000 00000000 00000000
3ffeb760: 00000000 00000000 00000000 00000000
3ffeb770: 00000000 00000000 00000000 00000000
3ffeb780: 00000000 00000000 00000000 00000000
3ffeb790: 00000000 00000000 00000000 00000000
3ffeb7a0: 00000000 00000000 00000000 00000000
3ffeb7b0: 00000000 00000000 00000000 00000000
3ffeb7c0: 00000000 00000000 00000000 00000000
3ffeb7d0: 00000000 00000000 00000000 00000000
3ffeb7e0: 00000000 00000000 00000000 00000000
3ffeb7f0: 00000000 00000000 00000000 00000000
3ffeb800: 00000000 00000000 00000000 00000000
3ffeb810: 00000000 00000000 00000000 00000000
3ffeb820: 00000000 00000000 00000000 00000000
3ffeb830: 00000000 00000000 00000000 00000000
3ffeb840: 00000000 00000000 00000000 00000000
3ffeb850: 00000000 00000000 00000000 00000000
3ffeb860: 00000000 00000000 00000000 00000000
3ffeb870: 00000000 00000000 00000000 00000000
3ffeb880: 00000000 00000000 00000000 00000000
3ffeb890: 00000000 00000000 00000000 00000000
3ffeb8a0: 00000000 00000000 00000000 00000000
3ffeb8b0: 00000000 00000000 00000000 00000000
3ffeb8c0: 00000000 00000000 00000000 00000000
3ffeb8d0: 00000000 00000000 00000000 00000000
3ffeb8e0: 00000000 00000000 00000000 00000000
3ffeb8f0: 00000000 00000000 00000000 00000000
3ffeb900: 00000000 00000000 00000000 00000000
3ffeb910: 00000000 00000000 00000000 00000000
3ffeb920: 00000000 00000000 00000000 00000000
3ffeb930: 00000000 00000000 00000000 00000000
3ffeb940: 00000000 00000000 00000000 00000000
3ffeb950: 00000000 00000000 00000000 00000000
3ffeb960: 00000000 00000000 00000000 00000000
3ffeb970: 00000000 00000000 00000000 00000000
3ffeb980: 00000000 00000000 00000000 00000000
3ffeb990: 00000000 00000000 00000000 00000000
3ffeb9a0: 00000000 00000000 00000000 00000000
3ffeb9b0: 00000000 00000000 00000000 00000000
3ffeb9c0: 00000000 00000000 00000000 00000000
3ffeb9d0: 00000000 00000000 00000000 00000000
3ffeb9e0: 00000000 00000000 00000000 00000000
3ffeb9f0: 00000000 00000000 00000000 00000000
3ffeba00: 00000000 00000000 00000000 00000000
3ffeba10: 00000000 00000000 00000000 00000000
3ffeba20: 00000000 00000000 00000000 00000000
3ffeba30: 00000000 00000000 00000000 00000000
3ffeba40: 00000000 00000000 00000000 00000000
3ffeba50: 00000000 00000000 00000000 00000000
3ffeba60: 00000000 00000000 00000000 00000000
3ffeba70: 010000e0 020000e0 3fff4da8 00000000
3ffeba80: 00000000 00000000 00000000 00000000
3ffeba90: 00000000 00000000 00000000 00000000
3ffebaa0: 00000000 00000000 00000000 00000000
3ffebab0: 00000000 3fff4cf8 3fff4cf8 00000001
3ffebac0: 00000000 00000000 00000000 00000000
3ffebad0: 00000000 00000000 00000000 00000000
3ffebae0: 00000000 00000000 00000000 00000000
3ffebaf0: 00000000 00000000 00000000 00000000
3ffebb00: 00000000 00000000 00000000 00000000
3ffebb10: 00000000 00000000 00000059 3fff48b0
3ffebb20: 3fff4818 00000000 00000000 00000000
3ffebb30: 00000000 00000000 00000000 00000000
3ffebb40: 00000000 00000000 00000000 00000000
3ffebb50: 00000000 00000000 00000000 00000000
3ffebb60: 00000000 00000000 00000000 00000000
3ffebb70: 00000000 00000000 00000000 00000000
3ffebb80: 00000000 00000000 00000000 00000000
3ffebb90: 00000000 00000000 00000000 00000000
3ffebba0: 00000000 00000000 00000000 00000000
3ffebbb0: 00000000 00000000 00000000 00000000
3ffebbc0: 00000000 00000000 00000000 00000000
3ffebbd0: 00000000 00000000 00000000 00000000
3ffebbe0: 00000000 00000000 00000000 00000000
3ffebbf0: 00000000 00000000 00000000 00000000
3ffebc00: 00000000 00000000 00000000 00000000
3ffebc10: 00000000 00000000 00000000 00000000
3ffebc20: 00000000 00000000 00000000 00000000
3ffebc30: 00000000 00000000 00000000 00000000
3ffebc40: 00000000 00000000 00000000 00000000
3ffebc50: 00000000 00000000 00000000 00000000
3ffebc60: 00000000 00000000 00000000 00000000
3ffebc70: 00000000 00000000 00000000 00000000
3ffebc80: 00000000 00000000 00000000 00000000
3ffebc90: 00000000 00000000 00000000 00000000
3ffebca0: 00000000 00000000 00000000 00000000
3ffebcb0: 00000000 00000000 00000000 00000000
3ffebcc0: 00000000 00000000 00000000 00000000
3ffebcd0: 00000000 00000000 00000000 00000000
3ffebce0: 00000000 00000000 00000000 00000000
3ffebcf0: 00000000 00000000 00000000 00000000
3ffebd00: 00000000 00000000 00000000 00000000
3ffebd10: 00000000 00000000 00000000 00000000
3ffebd20: 00000000 00000000 00000000 00000000
3ffebd30: 00000000 00000000 00000000 00000000
3ffebd40: 00000000 00000000 00000000 00000000
3ffebd50: 00000000 00000000 00000000 00000000
3ffebd60: 00000000 00000000 00000000 00000000
3ffebd70: 00000000 00000000 00000000 00000000
3ffebd80: 00000000 00000000 00000000 00000000
3ffebd90: 00000000 00000000 00000000 00000000
3ffebda0: 00000000 00000000 00000000 00000000
3ffebdb0: 00000000 00000000 00000000 00000000
3ffebdc0: 00000000 00000000 00000000 00000000
3ffebdd0: 00000000 00000000 00000000 00000000
3ffebde0: 00000000 00000000 00000000 00000000
3ffebdf0: 00000000 00000000 00000000 00000000
3ffebe00: 00000000 00000000 00000000 00000000
3ffebe10: 00000000 00000000 00000000 00000000
3ffebe20: 00000000 00000000 00000000 00000000
3ffebe30: 00000000 00000000 00000000 00000000
3ffebe40: 00000000 00000000 00000000 00000000
3ffebe50: 00000000 00000000 00000000 00000000
3ffebe60: 00000000 00000000 00000000 00000000
3ffebe70: 00000000 00000000 00000000 00000000
3ffebe80: 00000000 00000000 00000000 00000000
3ffebe90: 00000000 00000000 00000000 00000000
3ffebea0: 00000000 00000000 00000000 00000000
3ffebeb0: 00000000 00000000 00000000 00000000
3ffebec0: 3fff4910 3fff4d48 00000000 00000000
3ffebed0: 3ffec26c 00000000 00000000 00000000
3ffebee0: 00000000 00000000 00000000 00000000
3ffebef0: 00000000 00000000 00000000 00000000
3ffebf00: 3fffbff0 000077f8 3fff4e10 00000000
3ffebf10: 000071e0 3fff4800 00000000 00000000
3ffebf20: 00000000 00000000 00000000 00000000
3ffebf30: 00000000 00000000 00000000 00000000
3ffebf40: 00000000 00000000 00000000 00000000
3ffebf50: 00000000 00000000 00000000 00000000
3ffebf60: 00000000 00000000 00000000 00000000
3ffebf70: 00000000 00000000 00000000 00000000
3ffebf80: 00000000 00000000 00000000 00000000
3ffebf90: 00000000 00000000 00000000 00000000
3ffebfa0: 00000000 00000000 00000000 00000000
3ffebfb0: 00000000 00000000 00000000 00000000
3ffebfc0: 00000000 00000000 00000000 00000000
3ffebfd0: 00000000 00000000 00000000 00000000
3ffebfe0: 00000000 00000000 00000000 00000000
3ffebff0: 00000000 00000000 00000000 00000000
3ffec000: 00000000 00000000 00000000 00000000
3ffec010: 00000000 00000000 00000000 402035f8
3ffec020: 00000000 40202004 00000002 00000004
3ffec030: 400046ea 00000000 00000000 16491044
3ffec040: 00000000 00000000 00000000 00000000
3ffec050: 00000000 00000000 00000000 00000000
3ffec060: 00000000 00000000 00000000 00000000
3ffec070: 00000000 00000000 00000000 00000000
3ffec080: 00000000 00000000 00000000 00000000
3ffec090: 00000000 00000000 00000000 00000000
3ffec0a0: 00000000 00000000 00000000 00000000
3ffec0b0: 00000000 00000000 00000000 00000000
3ffec0c0: 00000000 00000000 00000000 00000000
3ffec0d0: 00000000 00000000 00000000 00000000
3ffec0e0: 00000000 00000000 00000000 00000000
3ffec0f0: 00000000 00000000 00000000 00000000
3ffec100: 00000000 00000000 00000000 00000000
3ffec110: 00000000 00000000 00000000 00000000
3ffec120: 00000000 00000000 00000000 00000000
3ffec130: 00000000 00000000 00000000 00000000
3ffec140: 00000000 00000000 00000000 00000000
3ffec150: 00000000 00000000 00000000 00000000
3ffec160: 00000000 00000000 00000000 00000000
3ffec170: 00000000 00000000 00000000 00000000
3ffec180: 00000000 00000000 00000000 00000000
3ffec190: 00000000 00000000 00000000 00000000
3ffec1a0: 00000000 00000000 00000000 00000000
3ffec1b0: 00000000 00000000 00000000 00000000
3ffec1c0: 00000000 00000000 00000000 00000000
3ffec1d0: 00000000 00000000 00000000 00000000
3ffec1e0: 00000000 00000000 00000000 00000000
3ffec1f0: 00000000 00000000 00000000 00000000
3ffec200: 00000000 00000000 00000000 00000000
3ffec210: 00000000 00000000 00000000 00000000
3ffec220: 00000000 00000000 00000000 00000000
3ffec230: 00000000 00000000 00000000 00000000
3ffec240: 00000000 0104a8c0 00ffffff 0104a8c0
3ffec250: 00000000 00000000 00000000 d534fe1a
3ffec260: fe18e646 e646d534 00000019 3ffec564
3ffec270: 00011edd 00001e84 4020dd84 00000000
3ffec280: 00000001 00000000 00000000 00000000
3ffec290: 00000001 00000000 00000000 00000000
3ffec2a0: d534fe18 0000e646 00000000 00000000
3ffec2b0: 00000000 00000000 00000000 00000000
3ffec2c0: 00000008 00000200 00000200 092a0b0b
3ffec2d0: 0000092a 00000009 00000000 0fff015f
3ffec2e0: 00000000 00000000 00000000 00000000
3ffec2f0: 00000000 02020200 00000003 00000000
3ffec300: 00030000 00000000 000005e0 00000001
3ffec310: 00000000 00000000 03030201 00000004
3ffec320: 00000000 00000000 00000000 00000bc0
3ffec330: 00000000 00000000 00000000 04040302
3ffec340: 0000000a 00000000 00000000 00000000
3ffec350: 00000000 00000000 00000000 00000000
3ffec360: 04040703 0000000a 00000000 00000000
3ffec370: 00000000 00000000 00000000 00000000
3ffec380: 00000000 04040204 0000000a 00000000
3ffec390: 00000000 00000000 00000000 00000000
3ffec3a0: 00000000 00000000 00000000 00000000
3ffec3b0: 00000000 00000000 00000000 00000000
3ffec3c0: 00000000 00000000 00000000 00000000
3ffec3d0: 00000000 00000000 00000000 00000000
3ffec3e0: 00000000 00000000 00000000 00000000
3ffec3f0: 05050207 0000000a 00000000 00000000
3ffec400: 00000000 00000000 00000000 00000000
3ffec410: 00000000 00000000 00000000 00000000
3ffec420: 00000000 00000000 00000000 00000000
3ffec430: 00000000 00000000 000009c4 00000000
3ffec440: 0000000c 00000100 00000000 00000000
3ffec450: 00000000 00000000 00000bb8 00002328
3ffec460: ffffffff 00000000 00000000 40215d90
3ffec470: 00000000 ffffffff 00000000 00000000
3ffec480: 40215dd4 00000000 ffffffff 00000000
3ffec490: 00000000 40215e54 00000000 00000000
3ffec4a0: 00000000 00000000 00000000 00000000
3ffec4b0: 3ffea1c4 00036243 00000000 40215418
3ffec4c0: 00000000 ffffffff 00000000 00000000
3ffec4d0: 402150a0 00000000 00020002 00000001
3ffec4e0: 00000000 00000000 00000000 00000000
3ffec4f0: 00000000 00000000 00000000 00000000
3ffec500: 00000000 00000000 00000000 00000000
3ffec510: 00000000 00000000 00000000 00000000
3ffec520: 00000000 00000000 00000000 00000000
3ffec530: 00000000 00000000 00000000 0001000d
3ffec540: 00000000 ffffffff 00000000 00000000
3ffec550: 402168cc 00000000 00020002 00000000
3ffec560: 00000001 3fff3b10 00017827 00000000
3ffec570: 4021703c 00000000 00000000 00000001
3ffec580: 00000000 ffffffff 00000000 00000000
3ffec590: 40217820 00000000 00000000 00000000
3ffec5a0: 00000000 00000000 00000000 00000000
3ffec5b0: 00000000 00000000 00000000 00000000
3ffec5c0: 00000000 00000000 06050302 00000000
3ffec5d0: 3ffec5cc 00000000 01000007 00000000
3ffec5e0: 00000000 00000000 00000000 00000000
3ffec5f0: 3ffec5ec 00000000 01000007 00000000
3ffec600: 00000000 00000000 00000000 00000000
3ffec610: 3ffec60c 00000000 00000000 00000000
3ffec620: 00000000 00000000 00000000 00000000
3ffec630: 3ffec62c 00000000 00000000 00000000
3ffec640: 00000000 00000000 00000000 00000000
3ffec650: 3ffec64c 00000000 00000000 00000000
3ffec660: 00000000 00000000 00000000 00000000
3ffec670: 3ffec66c 00000000 00000000 00000000
3ffec680: 00000000 00000000 00000000 00000000
3ffec690: 3ffec68c 00000000 00000000 00000000
3ffec6a0: 00000000 00000000 00000000 00000000
3ffec6b0: 3ffec6ac 00000000 00000000 00000000
3ffec6c0: 00000000 00000000 00000000 00000000
3ffec6d0: 3ffec6cc 00000000 3ffec6d4 3fff1e30
3ffec6e0: 3fff1e50 3fff2128 3fff2080 0000006d
3ffec6f0: 402371b0 00000000 40233b58 4023f128
3ffec700: 00000000 40215b6c 40215c2c 00000000
ctx: sys
sp: 3ffe94e0 end°ÿÿ?à”þ?"<<<stackÀ”þ?À”þ?
wdt reset
tail 0
chksum 0x42
csum 0x42
~ld
Exception (4):
epc1=0x400046e7 epc2=0x00000000 epc3=0x00000000 excvaddr=0x40000f69 depc=0x00000000
the cabling is correct because i managed one time and the esp was able to connect on the wifi and sensor give me temp.
for the alimentation i have 2xAA battery - > ESP + DS18B20 -> and the ESP is connected to ftd232 in rx -tx to show data on arduino IDE
Maybe my alimentation is not correct ? in this case, how i can replace this ? i don't want the big chip for the breadboard, i want something small for production
