http://www.esp8266.com/viewtopic.php?f=6&t=3486&p=19890#p19890
Explore... Chat... Share...
torntrousers wrote:As an alternative to having the ESP send the email you could use the FRED NodeRed service - https://fred.sensetecnic.com/
Thats gives you a free cloud based NodeRed server instance and you can set up an http enpoint which an ESP can send data to and then have a Node Red flow that does things with the data like sending emails. There is a little learning curve to learn about NodeRed but its really quite easy.
tytower wrote:torntrousers wrote:As an alternative to having the ESP send the email you could use the FRED NodeRed service - https://fred.sensetecnic.com/
I had a better look at this now and I am sure it can be very useful.
It seems to me though that if you want to send an email in that system you have to give them your username and password ? Did I get that right ?
So, do you trust them ? After all they are doing that for free. There is also the fact that if they are storing your passwords their security will be a lot less than larger organisations so hacking is a distinct possibility
I also was looking at Ubidots. I don't know enough about that yet but sending an email from them does not require you to give out private details , just a recipent.
http://app.ubidots.com/ubi/insights/#/list
