By torntrousers
#19012 The ESP can read the supply voltage itself. For that to work the ADC pin must not be connected to anything. There is also a bug currently where it causes intermitent wdt reset crashes if the esp is in station mode.
extern "C" {
  uint16 readvdd33(void);
  WiFi.mode(WIFI_AP_STA); // readvdd33 doesn't work currently in WIFI_STA mode
  float vdd = readvdd33() / 1000.0;
  Serial.print("Vdd: ");
  Serial.println(vdd);
  delay(1000);
By gr0b
#19013 Attached is some working example code for using readvdd33() to get an idea of the battery voltage.
Code: Select all//used samples from http://www.esp8266.com/viewtopic.php?f=33&t=2485
//Use a silicone diode to drop the voltage from the Lithium battery to within a safe range for the ESP module (should be between 2.5-3.6v)
//readvdd33() does not return correct values if anything is connect to the ADC pin
extern "C" {
  Serial.print("VCC:");
  Serial.println(readvdd33());      //this is the raw reading in mV, should something like 3300 if powered by 3.3volts
  Serial.print("Battery:");
  Serial.println(readvdd33()+600);  //here we add the voltage drop from the diode back to give us an idea of the battery voltage
