IMHO direct email contact to some generic email relay from IOT s is a bad idea.
It should be a federated design e.g. using some pi as your local hub between iot and the internet.
Cal
Explore... Chat... Share...
cal wrote:Moin,IMHO direct email contact to some generic email relay from IOT s is a bad idea.
It should be a federated design e.g. using some pi as your local hub between iot and the internet.Cal
"It should be a federated design e.g. using some pi as your local hub between iot and the internet."means
tytower wrote:cal wrote:Moin,IMHO direct email contact to some generic email relay from IOT s is a bad idea.
Cal first what does Moin mean ?
Next can you explain more what"It should be a federated design e.g. using some pi as your local hub between iot and the internet."means
Ready. Press 'e' to send.
connected
220 smtp2go.com ESMTP Exim+Smtp2go 4.72 + (2.0) Mon, 08 Jun 2015 11:24:23 +0000
Sending hello
250-smtp2go.com Hello 117-64-351-67. [117.64.351.67]
250-SIZE 28740000
250-PIPELINING
250-AUTH CRAM-MD5 PLAIN LOGIN
250-AUTH=CRAM-MD5 PLAIN LOGIN
250-STARTTLS
250 HELP
Sending auth login
334 VXNlcm5hbWU6
Sending User
334 UGFzc3dvcmQ6
Sending Password
535 Incorrect authentication data
221 smtp2go.com closing connection
disconnected
Email failed
