Timer countdown and countup synchronized with the server
Posted: Wed Jun 15, 2016 1:36 pm
Hello
I want to display on the LCD timer that counts down to zero and then counts up from zero. Timer to be synchronized with the server in the local network via wifi. I want to synchronize every 2-3 seconds. Please help. My code:
This code works, but there are delays and the timer is not displayed smoothly.
#include <ArduinoJson.h>
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
const char* ssid = "net";
const char* password = "password";
const char* host = "192.168.1.8";
byte bar1[8] =
0b11111,
0b11111,
0b11111,
0b00000,
0b00000,
0b00000,
0b00000,
0b00000
byte bar2[8] =
0b00000,
0b00000,
0b00000,
0b00000,
0b00000,
0b11111,
0b11111,
0b11111
byte bar3[8] =
0b11111,
0b11111,
0b00000,
0b00000,
0b00000,
0b00000,
0b11111,
0b11111
byte bar4[8] =
0b11111,
0b11111,
0b11111,
0b11111,
0b11111,
0b11111,
0b11111,
0b11111
byte bar5[8] =
0b00000,
0b00000,
0b00001,
0b00011,
0b00011,
0b00001,
0b00000,
0b00000
byte bar6[8] =
0b00000,
0b00000,
0b10000,
0b11000,
0b11000,
0b10000,
0b00000,
0b00000
byte bar7[8] =
0b00000,
0b00000,
0b00000,
0b00000,
0b00000,
0b00000,
0b00111,
0b00111
byte bar8[8] =
0b11100,
0b11100,
0b00000,
0b00000,
0b00000,
0b00000,
0b11100,
0b11100
Wire.begin(0,2);
// initialize the LCD
lcd.begin();
// Turn on the blacklight and print a message.
lcd.backlight();
lcd.createChar(1,bar1);
lcd.createChar(2,bar2);
lcd.createChar(3,bar3);
lcd.createChar(4,bar4);
lcd.createChar(5,bar5);
lcd.createChar(6,bar6);
lcd.createChar(7,bar7);
lcd.createChar(8,bar8);
delay(100);
lcd.setCursor(0,0);
lcd.print("Lacze z siecia: ");
lcd.setCursor(0,1);
lcd.print(ssid);
WiFi.begin(ssid, password);
delay(2000);
lcd.clear();
lcd.print(".");
lcd.clear();
lcd.setCursor(0,0);
lcd.print("WIFI polaczone");
delay(2000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Twoj adres IP:");
lcd.setCursor(0,1);
lcd.print(WiFi.localIP());
delay(5000);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("lacze z adresem:");
lcd.setCursor(0,1);
lcd.print(host);
delay(3000);
lcd.clear();
void custom0(int col)
{ // uses segments to build the number 0
lcd.setCursor(col, 0);
lcd.write(4);
lcd.write(1);
lcd.write(4);
lcd.setCursor(col, 1);
lcd.write(4);
lcd.write(2);
lcd.write(4);
void custom1(int col) //1
lcd.setCursor(col,0);
lcd.write(1);
lcd.write(4);
lcd.write(32);
lcd.setCursor(col,1);
lcd.write(2);
lcd.write(4);
lcd.write(2);
void custom2(int col) //2
lcd.write(1);
lcd.write(3);
lcd.write(4);
lcd.write(4);
lcd.write(2);
lcd.write(2);
void custom3(int col) //3
lcd.write(1);
lcd.write(3);
lcd.write(4);
lcd.write(2);
lcd.write(2);
lcd.write(4);
void custom4(int col) //4
lcd.write(4);
lcd.write(2);
lcd.write(4);
lcd.write(32);
lcd.write(32);
lcd.write(4);
void custom5(int col) //5
lcd.write(4);
lcd.write(3);
lcd.write(3);
lcd.write(2);
lcd.write(2);
lcd.write(4);
void custom6(int col) //6
lcd.write(4);
lcd.write(3);
lcd.write(3);
lcd.write(4);
lcd.write(2);
lcd.write(4);
void custom7(int col) //7
lcd.write(1);
lcd.write(1);
lcd.write(4);
lcd.write(32);
lcd.write(32);
lcd.write(4);
void custom8(int col) //8
lcd.write(4);
lcd.write(3);
lcd.write(4);
lcd.write(4);
lcd.write(2);
lcd.write(4);
void custom9(int col) //9
lcd.write(4);
lcd.write(3);
lcd.write(4);
lcd.write(2);
lcd.write(2);
lcd.write(4);
void custom11(int col)
lcd.write(5);
lcd.write(6);
lcd.write(5);
lcd.write(6);
void custom12(int col)
lcd.write(4);
lcd.write(4);
lcd.write(32);
lcd.write(32);
void custom13(int col)
lcd.write(32);
lcd.write(32);
lcd.write(32);
lcd.write(32);
void printNumber(int value, int col) {
if (value == 0) {
custom0(col);
} if (value == 1) {
custom1(col);
} if (value == 2) {
custom2(col);
} if (value == 3) {
custom3(col);
} if (value == 4) {
custom4(col);
} if (value == 5) {
custom5(col);
} if (value == 6) {
custom6(col);
} if (value == 7) {
custom7(col);
} if (value == 8) {
custom8(col);
} if (value == 9) {
custom9(col);
if (value == 11) {
custom11(col);
if (value == 12) {
custom12(col);
if (value == 13) {
custom13(col);
void loop()
WiFiClient client;
const int httpPort = 8095;
lcd.clear();
lcd.setCursor(0,0);
lcd.print("connection failed");
return;
// We now create a URI for the request
String url = "/api/v3/timers/0";
//Serial.print("Requesting URL: ");
//Serial.println(url);
client.print("GET " + url + " HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"ApiCode: 8273\r\n" +
"Content-Type: application/json\r\n" +
"Connection: close\r\n\r\n");
delay(400);
unsigned int i = 0; //timeout counter
int n = 1; // char counter
char json[500] ="{";
while (!client.find("{")){}
while (i<600) { //while1
if(client.available()) { //if2
char c = client.read();
json[n]=c;
if(c == '}') break;
n++;
i=0;
} //eo if2
i++;
} //eo
StaticJsonBuffer<400> jsonBuffer;
JsonObject& root = jsonBuffer.parseObject(json);
if (!root.success()) {
lcd.setCursor(0,0);
lcd.print("blad JSON");
return;
String runningIndex = root["runningIndex"];
//Serial.print(runningIndex);
//Serial.println();
//Serial.println("closing connection");
if (runningIndex == "-1")
lcd.setCursor(0,0);
lcd.print("timer zatrzymany");
lcd.setCursor(0,1);
lcd.print(" ");
WiFiClient client;
if (!client.connect(host, httpPort)) { //if1
lcd.clear();
lcd.setCursor(0,0);
return;
} //eo if1
String url = "/api/v3/datetime";
json[n]=c;
if(c == '}') break;
n++;
i=0;
} //eo if2
i++;
} //eo while1
StaticJsonBuffer<500> jsonBuffer;
if (!root.success()) { //if3
return;
} //eo if3
int year = root["year"];
int month = root["month"];
int day = root["day"];
int hour = root["hour"];
int minute = root["min"];
int second = root["second"];
//-------------------------------big size----------------------------------
int m1 , m2 ,s1 , s2;
if (hour > 9) {
m1 = (hour - (hour % 10)) / 10;
hour = hour % 10;
} else {
m1 = 0;
m2 = hour;
if (minute > 9) {
s1 = (minute - (minute % 10)) / 10;
minute = minute % 10;
} else {
s1 = 0;
s2 = minute;
printNumber(m1, 0);
printNumber(13, 3);
printNumber(m2, 4);
printNumber(11, 7); // wyświetlamy dwukropek
printNumber(s1, 9);
printNumber(13, 12);
printNumber(s2, 13);
else
WiFiClient client;
lcd.clear();
lcd.setCursor(0,0);
return;
} //eo if1
String url = "/api/v3/timers/" + runningIndex;
delay(250);
json[n]=c;
if(c == '}') break;
n++;
i=0;
} //eo if2
i++;
} //eo while1
return;
} //eo if3
int displayedMins = root["displayedMins"];
int displayedSecs = root["displayedSecs"];
int dS = displayedSecs;
if (displayedMins > 9) {
m1 = (displayedMins - (displayedMins % 10)) / 10;
displayedMins = displayedMins % 10;
} else {
m1 = 0;
m2 = displayedMins;
if (displayedSecs > 9) {
s1 = (displayedSecs - (displayedSecs % 10)) / 10;
displayedSecs = displayedSecs % 10;
} else {
s1 = 0;
s2 = displayedSecs;
printNumber(m1, 0);
printNumber(13, 3);
printNumber(m2, 4);
printNumber(s1, 9);
if(m1==0 && m2==0 && dS < 31)
delay(250);
lcd.clear();
else
delay(250);
} // end of else
} // end void loop
