Home Control Via Voice, SMS, Web Buttons and 433/315MHz
Posted: Tue Mar 14, 2017 5:59 pm
This Sketch uses an M590 GPRS MCU (£4 from Banggood), SDCard breakout and both 433 + 315 RF modules with LCD for console, running on an ESP8266-12E with 4 way 3v to 5v convertor (I2C and RF).
This has been set to send an Alert SMS to a number from the SDCard on the phrase "Alexa Turn Assistance ON", this and the other "Alexa" Keywords are retrieved from a file along with some other data detailed in the Sketch.
Just search for "Smart Devices" in the Alexa App, this may take a couple of attempts to find all devices if you have more than 4, then say "Alexa 'Keyword' ON".
The commands for SMS are simple #a00 to switch the first device off and #a01 to switch on and so on.
The Webpage has buttons for the Fauxmo but not the SMS.
* Faumox Credit to Ben Hencke, for the Library and examples.....
* ESP9266 WEMO Emulator to Amazon Alexa with Webpage Buttons and SMS Control
* Voice, Mini Remote, Webpage and Text Message control of your Home.........
* Using the SDCard allows the end user to configure Without the need to Flash/Find the ESP, Alexa will find it
* Keeping the data update only from a local source (SD) is very simple for most folk......
* This uses an SDCard attached to SPI to get the Names for the Fauxmo devices, default table setup replaced by file contents
* The Control & Alert GSM Telephone Numbers, SSID and Password are stored on the SDCard in filenames...
* CONTROL.TXT = Mobile Number to allow Control of the device from....e.g. 440000000000 WITH Country Code!!!
* ALERTNO.TXT = Mobile Number to send a HELP text to....e.g. 440000000000 WITH Country Code!!!
* SSID.TXT = Network Name (SSID)
* WIFIPSK.TXT = Network Password
* DEVICES.TXT = FauxMo/Alexa Names List - Each device name terminated with a comma e.g. Beacon One,Beacon Two,
* Make the name 4 chars or greater, HTML will increase the size of the buttons on the webpage to accomodate
* Libraries needed......
* https://github.com/me-no-dev/ESPAsyncTCP/archive/master.zip
* https://github.com/simap/fauxmoesp/archive/master.zip
* https://github.com/fdebrabander/Arduino-LiquidCrystal-I2C-library/archive/master.zip
* Remaining Libraries from the Library Manager or included with ESP IDE addition........
* SPI PINS
* | GPIO NodeMCU Name |
* | 15 D8 SS |
* | 13 D7 MOSI |
* | 12 D6 MISO |
* | 14 D5 SCK |
* RF Pins - 4 - 5
* I2C Pins - 0 - 2
* M590 Pins - 1 - 3 The M590 can be found for less than £4......add a pay as you go sim....It will recieve SMS without additional cost...
#include <SPI.h>
#include <SD.h>
#include "fauxmoESP.h"
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
#include <RCSwitch.h>
// RCSwitch configuration
RCSwitch mySwitch = RCSwitch(); // 433MHz Transmitter on Pin 4
RCSwitch s3Switch = RCSwitch(); // 315MHz Transmitter on Pin 5
// LCD & M590 data
LiquidCrystal_I2C lcd(0x27,16,2); // set the LCD address to 0x27, 16 chars and 2 line display, Check Your LCD Address !!!
int charNo = 0; // track for positioning on LCD
char inchar; // Will hold the incoming character from the M590
String conTrol = ""; // Only allow control from this number.... retrieved from sdcard...control.txt terminate with a comma 440000000000,
String AlertNo = ""; // Send Help Text via SMS to this number.... retrieved from sdcard...alertno.txt terminate with a comma 440000000000,
boolean conTrolF = false; // set true when number verifies ok
String callID = ""; // line of text from gsm
String StrCallID = ""; // command selection
String StrCallID1 = ""; // number being verified
// Use at+cclk? to find the M590 (AT SIM800) time or at+cclk="YY/MM/DD,HR:Min:Sec" to Set....
String LCdLine = ""; // line of text for LCD
int flip = 0; // Flip the display text between number and command....
int LiNe = 0; // I am only using 2 lines 0 + 1 Verify Number ONLY on line 0
unsigned long uldispDelta_ms = 10000; // Display interval 10 Seconds
unsigned long ulNextdisp_ms; // next display time
// List of default Alexa Device Names to be replaced by SDCard names if found - This setup presents 8 devices, "8" is "Send Help SMS"
// This is the contents of my devices.txt as an example......
// Lamp,Hall,Kitchen,Bedroom,Main hall,Livingroom,Coffee,Assistance,
String AlexaName[] = {"Light one","Light two","Light three","Light four","Light five","Light six","Light seven","Assistance"};
boolean state; // On or Off
unsigned char deviceid; // Select the device from above or SDCard
// For SMS Action
boolean HelpTEXT = false; // Set to true to send SMS.....
// Create an instance of the server on Port 80 for webpage
WiFiServer server(80);
WiFiClient client;
unsigned long ulReqcount; // how often has a valid page/button been requested
// Network configuration
fauxmoESP fauxmo;
char ssid[32]; // Storage for your network SSID (name) from SDCard
char pass[32]; // Strorage for your network password from SDCard
// Allow access to ESP8266 SDK calls
extern "C"
#include "user_interface.h"
// This is the Activity of the device, change the action line to whatever you want to control via voice...
// Switch the RF433 Sockets on/off Set this for your type of Sockets these have Rotory Switches to set ID
// Set a flag and send SMS on flag then reset flag....... Any activity can be triggered.........
void SwItchRF( unsigned char deviceid, boolean Mystate){
StrCallID = deviceid;
StrCallID += " ";
StrCallID += Mystate;
StrCallID1 = " Alexa API";
LCdLine = AlexaName[deviceid];
LCdLine += (" Mystate: %s", Mystate ? "ON" : "OFF");
if(deviceid==0){
if(Mystate==true){ // When you tell Alexa Device On
mySwitch.switchOn(1,1); // Activity Line, change to your needs.........
}else{ // When you tell Alexa Device Off
mySwitch.switchOff(1,1);
}else if(deviceid==1){
if(Mystate==true){
mySwitch.switchOn(1,2);
}else{
mySwitch.switchOff(1,2);
}else if(deviceid==2){
if(Mystate==true){
mySwitch.switchOn(1,3);
}else{
mySwitch.switchOff(1,3);
}else if(deviceid==3){
if(Mystate==true){
mySwitch.switchOn(1,4);
}else{
mySwitch.switchOff(1,4);
}else if(deviceid==4){
if(Mystate==true){
s3Switch.send(2839714, 24); // Activity changed to 315MHz, sending raw command
}else{
s3Switch.send(2839721, 24);
}else if(deviceid==5){
if(Mystate==true){
s3Switch.send(2391202, 24);
}else{
s3Switch.send(2391209, 24);
}else if(deviceid==6){
if(Mystate==true){
mySwitch.switchOn(2,1); // Additional RF Group
}else{
mySwitch.switchOff(2,1);
}else if(deviceid==7){ // This is only used from Alexa.....
if(Mystate==true){ // but your use could be different, just add buttons or SMS Commands........
HelpTEXT=true;
}else{
// Nothing todo here but you could do anything......Maybe send an Email or Tweet..or if then else (IFTTT) ........
}else{return;}
// M590 GPRS Module - SMS Send & Recieve using Hardware Serial Pins 1+3 to connect ESP to M590 for SwitchRF()
void smsHelp()
if(AlertNo!=""){
LCdLine = " Sent Alert SMS";
String TesTing = "1234";
Serial.print("AT+CMGS=\"" + AlertNo + "\"\r\n"); // Number to reply to from alert.txt
delay(2000);
Serial.print("Testing ALERT SMS, Help the Problem is: " + TesTing); // message content could include Sensor data, Bio or Env....
delay(1000);
Serial.write(0x1a); // send out SMS
delay(5000);
HelpTEXT=false;
void smsG()
if (LiNe==0 && charNo==0){lcd.clear();}
delay(50);
inchar=Serial.read();
delay(50);
charNo++;
if (flip==0){digitalWrite(16, HIGH);flip=1;}else{digitalWrite(16, LOW);flip=0;} // Flash LED to show M590 activity
if (LiNe==0 && charNo>8 && charNo<21){
lcd.setCursor(charNo-7,0);
lcd.print(inchar);
callID += inchar;
StrCallID1 = callID;
StrCallID = "+CMT";
} // Data +CMT: "+440000000000",,"21/12/21,12:21:12+04"
if (LiNe==1 && charNo<5){
lcd.setCursor(charNo-1,1);
lcd.print(inchar);
callID += inchar;
StrCallID = callID;
} // Data #XYY
if (inchar == '\n'){
charNo = 0; // on newline reset character counter
if (StrCallID =="+CMT"){
if (StrCallID1 == conTrol){
if (LiNe == 0){conTrolF = true;}else{conTrolF = false;}
LiNe++;
}else{
conTrolF = false;
LiNe++;
callID="";
StrCallID ="";
}else if (StrCallID =="#a00"){
deviceid=0;
state=false;
SwItchRF( deviceid, state );
LCdLine = AlexaName[0].c_str();
LCdLine += " Off";
}else if (StrCallID =="#a01"){
deviceid=0;
state=true;
LCdLine += " On";
}else if (StrCallID =="#a10"){
deviceid=1;
state=false;
LCdLine = AlexaName[1].c_str();
LCdLine += " Off";
}else if (StrCallID =="#a11"){
deviceid=1;
state=true;
LCdLine += " On";
}else if (StrCallID =="#a20"){
deviceid=2;
state=false;
LCdLine = AlexaName[2].c_str();
LCdLine += " Off";
}else if (StrCallID =="#a21"){
deviceid=2;
state=true;
LCdLine += " On";
}else if (StrCallID =="#a30"){
deviceid=3;
state=false;
LCdLine = AlexaName[3].c_str();
LCdLine += " Off";
}else if (StrCallID =="#a31"){
deviceid=3;
state=true;
LCdLine += " On";
}else if (StrCallID =="#a40"){
deviceid=4;
state=false;
LCdLine = AlexaName[4].c_str();
LCdLine += " Off";
}else if (StrCallID =="#a41"){
deviceid=4;
state=true;
LCdLine += " On";
}else if (StrCallID =="#a50"){
deviceid=5;
state=false;
LCdLine = AlexaName[5].c_str();
LCdLine += " Off";
}else if (StrCallID =="#a51"){
deviceid=5;
state=true;
LCdLine += " On";
}else if (StrCallID =="#a60"){
deviceid=6;
state=false;
LCdLine = AlexaName[6].c_str();
LCdLine += " Off";
}else if (StrCallID =="#a61"){
deviceid=6;
state=true;
LCdLine += " On";
}else if (StrCallID =="#b00"){
if (conTrolF == true){
LCdLine = " Sent SMS";
Serial.print("AT+CMGS=\"" + StrCallID1 + "\"\r\n"); // Number to reply to from incomming message
delay(2000);
Serial.print("Testing SMS : " + TesTing); // message content is the distance to the door as a string
delay(1000);
delay(5000);
}else if (StrCallID =="#b01"){
LCdLine = " Cleared SMS!";
Serial.println(F("AT+CMGD=1,4")); // delete all SMS, in bank 1, command 4 delete all
delay(5000);
}else{
LCdLine = StrCallID;
StrCallID = "TEXT";
callID="";
Serial.begin(9600);
Wire.begin(0,2);
delay(200);
lcd.init();
delay(200);
lcd.backlight();
delay(50);
if (!SD.begin(15)) {
}else{
File dataFile = SD.open("control.txt");
if (dataFile) {
while (dataFile.available()) {
String RconTrol = (dataFile.readStringUntil(','));
conTrol = RconTrol.substring(0,12);
lcd.clear();
lcd.print(F("Found Cntrl No:"));
lcd.setCursor(0,1);
lcd.print(conTrol);
delay(2500);
dataFile.close();
}else {
lcd.clear();
lcd.print(F("Control error"));
delay(5000);
File dataFile1 = SD.open("alertno.txt");
if (dataFile1) {
while (dataFile1.available()) {
String RAlertNo = (dataFile1.readStringUntil(','));
AlertNo = RAlertNo.substring(0,12);
lcd.clear();
lcd.print(F("Found Alert No:"));
lcd.setCursor(0,1);
lcd.print(AlertNo);
delay(2500);
dataFile1.close();
}else {
lcd.clear();
lcd.print(F("Alertno error"));
delay(5000);
lcd.clear();
lcd.print(F("."));
File myFile = SD.open("devices.txt");
if (myFile) {
int SinGle = 0;
// read from the file until there's nothing else in it:
while (myFile.available()) {
String ReadDevice = myFile.readStringUntil(','); // Terminate each device name in the file with a comma
ReadDevice.trim();
int LengtH = ReadDevice.length();
if (LengtH>=4){
AlexaName[SinGle] = ReadDevice;
SinGle++;
ReadDevice = "";
// close the file:
myFile.close();
lcd.clear();
lcd.print(F("Alexa Devices :"));
lcd.setCursor(7,1);
lcd.print(SinGle);
delay(5000);
} else {
File myFile0 = SD.open("ssid.txt");
if (myFile0) {
String tmsg="";
while (myFile0.available()) {
tmsg=myFile0.readString();
tmsg.trim();
int len = tmsg.length()+1;
ssid[len];
tmsg.toCharArray(ssid, len);
// close the file:
myFile0.close();
} else {
// if the file didn't open, print an error:
File myFile1 = SD.open("wifipsk.txt");
if (myFile1) {
String tmsg1="";
while (myFile1.available()) {
tmsg1=myFile1.readString();
tmsg1.trim();
int len1 = tmsg1.length()+1;
pass[len1];
tmsg1.toCharArray(pass, len1);
// close the file:
myFile1.close();
} else {
WiFi.begin(ssid, pass);
server.begin();
mySwitch.enableTransmit( 4 ); // 433MHz Transmitter
s3Switch.enableTransmit( 5 ); // 315MHz Transmitter
// Fauxmo
fauxmo.addDevice(AlexaName[0].c_str());
fauxmo.addDevice(AlexaName[1].c_str());
fauxmo.addDevice(AlexaName[2].c_str());
fauxmo.addDevice(AlexaName[3].c_str());
fauxmo.addDevice(AlexaName[4].c_str());
fauxmo.addDevice(AlexaName[5].c_str());
fauxmo.addDevice(AlexaName[6].c_str());
fauxmo.addDevice(AlexaName[7].c_str());
// fauxmoESP 2.0.0 has changed the callback signature to add the device_id
// it's easier to match devices to action without having to compare strings.
fauxmo.onMessage([](unsigned char device_id, const char * device_name, bool state) {
SwItchRF( device_id, state );
Serial.print(F("ATE0\r")); // Echo OFF, use AT+CFUN=15 to reset M590 it will return +PBREADY when connected to network
lcd.print(F("."));
delay(500); // AT+CNUM get own number, AT+CCID get SIM ID, useful commands for debug.......
lcd.print(F("."));
Serial.print(F("AT+CMGF=1\r")); // set SMS mode to text
lcd.print(F("."));
delay(1550);
lcd.print(F("."));
Serial.print(F("AT+CSCS=\"GSM\"")); // "Western" or Standard Character Set to use
Serial.print(F("\r"));
lcd.print(F("."));
delay(550);
lcd.print(F("."));
lcd.print(F("."));
delay(550);
lcd.setCursor(0,1);
lcd.print(F("."));
lcd.print(F("."));
Serial.print(F("AT+CNMI=2,2,0,0,0\r"));
lcd.print(F("."));
delay(2550);
lcd.print(F("."));
lcd.print(F("."));
Serial.flush();
while(Serial.available() > 0) {
char t = Serial.read();
lcd.clear();
// Start timer for lcd display
ulNextdisp_ms = millis()+uldispDelta_ms;
lcd.clear();
lcd.print(F("Ready...."));
lcd.setCursor(0,1);
lcd.print(WiFi.localIP());
if(HelpTEXT==true){
smsHelp(); // verify result code from M590 to ensure success......
// Since fauxmoESP 2.0 the library uses the "compatibility" mode by
// default, this means that it uses WiFiUdp class instead of AsyncUDP.
// The later requires the Arduino Core for ESP8266 staging version
// whilst the former works fine with current stable 2.3.0 version.
// But, since it's not "async" anymore we have to manually poll for UDP
// packets
fauxmo.handle();
// if there is a text or Command, flip display every 10 Seconds.....
if (millis()>=ulNextdisp_ms && StrCallID1!="")
lcd.clear();
if (flip==0){
flip=1;
lcd.print(F("No +"));
lcd.print(StrCallID1); // Number Sent from.....
}else{
flip=0;
if (StrCallID!="TEXT"){// Set as the default if no command decoded.....
lcd.print(F("Command "));
lcd.print(StrCallID); // Command decoded from text.....if not a TEXT SMS....
lcd.setCursor(0,1);
lcd.print(F("Act"));
lcd.print(LCdLine);
}else{
lcd.print(F("SMS TEXT"));
lcd.setCursor(0,1);
lcd.print(LCdLine);
// If Serial has data an SMS has arrived
conTrolF = false;
LiNe = 0;
charNo = 0;
while(Serial.available()){
smsG();
if (!client)
return;
// Wait until the client sends some data
unsigned long ultimeout = millis()+250;
while(!client.available() && (millis()<ultimeout) )
delay(1);
if(millis()>ultimeout)
return;
String sRequest = client.readStringUntil('\r');
client.flush();
// stop client, if request is empty
if(sRequest=="")
client.stop();
return;
// get path; end of path is either space or ?
// Syntax is e.g. GET /?show=1234 HTTP/1.1
String sPath="",sParam="", sCmd="";
String sGetstart="GET ";
int iStart,iEndSpace,iEndQuest;
iStart = sRequest.indexOf(sGetstart);
if (iStart>=0)
iStart+=+sGetstart.length();
iEndSpace = sRequest.indexOf(" ",iStart);
iEndQuest = sRequest.indexOf("?",iStart);
// are there parameters?
if(iEndSpace>0)
if(iEndQuest>0)
// there are parameters
sPath = sRequest.substring(iStart,iEndQuest);
sParam = sRequest.substring(iEndQuest,iEndSpace);
else
// NO parameters
sPath = sRequest.substring(iStart,iEndSpace);
// format the html response
if(sPath=="/")
ulReqcount++;
String diagdat="";
String duration1 = " ";
int hr,mn,st;
st = millis() / 1000;
mn = st / 60;
hr = st / 3600;
st = st - mn * 60;
mn = mn - hr * 60;
if (hr<10) {duration1 += ("0");}
duration1 += (hr);
duration1 += (":");
if (mn<10) {duration1 += ("0");}
duration1 += (mn);
duration1 += (":");
if (st<10) {duration1 += ("0");}
duration1 += (st);
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println();
client.println("<!DOCTYPE HTML>");
diagdat+="<html><head><title>Home Monitor</title></head><body>";
diagdat+="<font color=\"#000000\"><body bgcolor=\"#a0dFfe\">";
diagdat+="<meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=yes\">";
diagdat+="<h1>Alexa Voice Control<BR>ESP8266 FauxMo Device</h1>";
diagdat+="<BR> Web Page Requests = ";
diagdat+=ulReqcount;
diagdat+="<BR> Free RAM = ";
client.println(diagdat);
client.print((uint32_t)system_get_free_heap_size()/1024);
diagdat=" KBytes";
diagdat+="<BR> System Uptime =";
diagdat+=duration1;
client.print(diagdat);
diagdat="<BR><hr><BR><table><tr><td>";// Webpage buttons for RF 433 Sockets in HTML Table
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=1-on\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+=AlexaName[0].c_str();
diagdat+=" On\"></FORM><br></td><td>";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=2-on\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+=AlexaName[1].c_str();
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=3-on\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+=AlexaName[2].c_str();
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=4-on\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+=AlexaName[3].c_str();
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=5-on\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+=AlexaName[4].c_str();
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=6-on\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+=AlexaName[5].c_str();
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=7-on\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+=AlexaName[6].c_str();
diagdat+=" On\"></FORM><br></td></tr><tr><td>";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=1-off\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+=" Off\"></FORM><br></td><td>";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=2-off\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=3-off\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=4-off\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=5-off\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=6-off\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+="<FORM METHOD=\"LINK\" ACTION=\"/&socKet=7-off\"><INPUT TYPE=\"submit\" VALUE=\"";
diagdat+=" Off\"></FORM><br></td></tr></table>";
diagdat="<hr><BR>";
diagdat+="<BR><FONT SIZE=-1>environmental.monitor.log@gmail.com<BR><FONT SIZE=-1>ESP8266 With RF 433MHz Sockets <BR> FauxMO (WEMO Clone) to Amazon ECHO Dot Gateway<BR>Using an M590 GPRS SMS Gateway<BR>";
diagdat+="<FONT SIZE=-2>Compiled Using ESP ver. 2.2.3(Arduino 1.6.13), built March, 2017<BR></body></html>";
diagdat = "";
duration1 = "";
// and stop the client
delay(1);
client.stop();
if(hr==12){
ESP.restart();
// React to Button Click from Webpage
if (sPath.startsWith("/&socKet=")){ // Request from webpage buttons
client.println("HTTP/1.1 204 OK"); // No Data response to buttons request
client.println("Connection: close"); // We are done Close the connection
delay(1); // Give time for connection to close
client.stop(); // Stop the client
ulReqcount++; // Tracking counter for page requests
if (sPath.startsWith("/&socKet=1-on")) {
deviceid=0;
state=true;
} else if (sPath.startsWith("/&socKet=1-off")) {
deviceid=0;
state=false;
} else if (sPath.startsWith("/&socKet=2-on")) {
deviceid=1;
state=true;
} else if (sPath.startsWith("/&socKet=2-off")) {
deviceid=1;
state=false;
} else if (sPath.startsWith("/&socKet=3-on")) {
deviceid=2;
state=true;
} else if (sPath.startsWith("/&socKet=3-off")) {
deviceid=2;
state=false;
} else if (sPath.startsWith("/&socKet=4-on")) {
deviceid=3;
state=true;
} else if (sPath.startsWith("/&socKet=4-off")) {
deviceid=3;
state=false;
} else if (sPath.startsWith("/&socKet=5-on")) {
deviceid=4;
state=true;
} else if (sPath.startsWith("/&socKet=5-off")) {
deviceid=4;
state=false;
} else if (sPath.startsWith("/&socKet=6-on")) {
deviceid=5;
state=true;
} else if (sPath.startsWith("/&socKet=6-off")) {
deviceid=5;
state=false;
} else if (sPath.startsWith("/&socKet=7-on")) {
deviceid=6;
state=true;
} else if (sPath.startsWith("/&socKet=7-off")) {
deviceid=6;
state=false;
} else{return;}
StrCallID1 = " Web API";
LCdLine += (" state: %s", state ? "ON" : "OFF");
