By periklis87
#64160 hi ... i am new to the forum but i am into esp8266 for quite some time...
if the question should be in an other area of the forum please move it.
my issue is as follows... when i ran the Basic ESP8266 MQTT example from pubsubclient library and everything else from that library it works flawlessly as long as it can connect my broker.
is i close the broker it crashes with wdt 4 code.... the sketch i use is the following
i also have observed that is i send the message 0 and turn the led on pin 5 on it doesn't crash that often but is i turn the led off it crashes immediately after losing the connection to the broker
my set up is arduino ide 1.6.13 and pubsubclient version 2.6.0
i could realy use your help if you can spare the time
Code: Select all
#include <PubSubClient.h>
// Update these with values suitable for your network.
int gpio1=5;
const char* ssid = ".........";
const char* password = "...........";
const char* mqtt_server = "...........";
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
  pinMode(gpio1, OUTPUT);     // Initialize the gpio1 pin as an output
  setup_wifi();
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback);
void setup_wifi() {
  delay(10);
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
void callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);
  // Switch on the LED if an 1 was received as first character
  if ((char)payload[0] == '1') {
    digitalWrite(gpio1, LOW);   // Turn the LED on (Note that LOW is the voltage level
    // but actually the LED is on; this is because
    // it is acive low on the ESP-01)
  } else {
    digitalWrite(gpio1, HIGH);  // Turn the LED off by making the voltage HIGH
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Attempt to connect
    if (client.connect("ESP8266Client")) {
      Serial.println("connected");
      // Once connected, publish an announcement...
      client.publish("outTopic", "hello world");
      // ... and resubscribe
      client.subscribe("inTopic");
    } else {
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
  if (!client.connected()) {
    reconnect();
  client.loop();
  long now = millis();
  if (now - lastMsg > 2000) {
    lastMsg = now;
    ++value;
    snprintf (msg, 75, "hello world #%ld", value);
    Serial.print("Publish message: ");
    Serial.println(msg);
    client.publish("outTopic", msg);
