By fryguy128
#65780 I bought one of these boards a few months ago, and needed a project. I live in a dorm and the temperature is very much unregulated resulting in large fluctuations. This led me to want to be able to check my room temperature. Enjoying overly complex solutions to simple problems, I decided to pick up this project. With the data that is generated, I am able to view my room temperature directly on my linux laptop using conky, graph the data using gnuplot, and check the temperature in my room using a simple javascript site developed using information in a link @mrburnette provided (https://www.hackster.io/rayburne/nodemc ... team=22106).
If you just want to use FTP to upload files please have a look at my previous post located here: http://www.esp8266.com/viewtopic.php?f=29&t=13956&p=63152#p63152.
If you would like to download my code, please visit my github repo at: https://github.com/fryguy128/esp8266FTP.
Without further ado, here's the ESP8266FTPThermometer sketch code:
Code: Select all/**
 * This sketch reads input from a MAX1820 temperature sensor then saves it to a file
 * which is then uploaded to an FTP server. Once a week, the data file will be renamed
 * and uploaded. This creates a new file for every week's worth of data.
 * Other's sketches that made this possible include:
 *   SurferTim's FTP
 *   Michael Margolis, Tom Igoe, and Ivan Grokhotkov's FTP script
 * Posted 09 May 2017 by Patrick Duensing (fryguy128)
#include <FS.h>
#include <Time.h>
#include <WiFiUdp.h>
#include <OneWire.h>
//Change these variables to meet your needs
//Wifi
//I'm on a school network so I don't have a password,
//you'll have to modify the wifi connection if you have one.
const char* ssid = "YOUR SSID";
//FTP stuff
const char* host = "YOUR FTP HOST";
const char* userName = "YOUR FTP USERNAME";
const char* password = "YOUR FTP PASSWORD";
const int timeZone = 0;     // UTC
//DO NOT CHANGE THESE UNLESS YOU KNOW WHAT YOU'RE DOING
//FTP buffers
char outBuf[128];
char outCount;
//WiFi Clients
WiFiClient client;
WiFiClient dclient;
//NTP Stuff
unsigned int localPort = 2390; //UDP Port
IPAddress timeServer(132, 163, 4, 101); // time-a.timefreq.bldrdoc.gov
const int NTP_PACKET_SIZE = 48; // NTP time stamp is in the first 48 bytes of the message
byte packetBuffer[ NTP_PACKET_SIZE]; //buffer to hold incoming and outgoing packets
WiFiUDP udp; // A UDP instance to let us send and receive packets over UDP
//LED
int led = 2;
//Temperature
OneWire  ds(14);
//Move into setup()
  // Serial setup
  delay(100);
  //Wifi Setup
  Serial.println(ssid);
  WiFi.begin(ssid);
    Serial.print(".");
  Serial.println("");
  //SPIFF setup
  SPIFFS.begin();
  //UDP setup
  Serial.println("Starting UDP");
  udp.begin(localPort);
  Serial.print("Local port: ");
  Serial.println(udp.localPort());
  //led Pin setup
  pinMode(led, OUTPUT);
//Move into loop()
  //This is the filename where your newest data will be stored
  String fileNameData = "/data.txt";
  //This is the filename that contains a single number used to create a new file
  String textVar = "/number.txt";
  //This string will hold the name of the new file to be created at the end of a week
  String newFileName = "";
  //Turn the led on for the entire loop
  digitalWrite(led, HIGH);
  //Get the time from the NTP server
  setSyncProvider(getNtpTime);
  Serial.println("1) NTP GOTTEN");
  //This runs if the time was found. If it wasn't, the date would be set to sometime in 1970.
  if (year() != 1970) {
    Serial.println("2) YEAR NOT 1970");
    //Used to determine if a week has passed
    int count = 0;
    //Opens the data file to read
    File j = SPIFFS.open(fileNameData, "r");
    if (!j) {
      Serial.println("file open failed");
    else {
      //Finds out how many records there are in the main data file
      while (j.available()) {
        count++;
        j.readStringUntil('\n');
      j.close();
      Serial.println(count);
      if (count > 1007) {                                        // 1008 records is equal to a week of recording every 10 minutes
        File h = SPIFFS.open(textVar, "r");                      // Open the file holding the number to read
        if (!h) {
        else {
            int inputVal = h.parseInt();                         // Read the integer from the number file
            //Close the number file
            h.close();
            Serial.println(inputVal);                            // Create the new file name
            newFileName = "/data" + String(inputVal);
            newFileName += ".txt";
            Serial.println("newFileName = " + newFileName);
            SPIFFS.rename(fileNameData, newFileName);           // Rename the data file
            File x = SPIFFS.open(textVar, "w");                 // Reopen the number file in write mode
            if(!x){
            else{
              inputVal++;                                      // Increment the value read in from the number file
              x.println(inputVal);                             // Write the number to the number file
              x.close();                                       // Closes the number file
    File f = SPIFFS.open(fileNameData, "a");                   // Open the data file in append mode
    if (!f) {
    else {
      Serial.println("3) FILE OPENED");
      getTemperature(f);                                       //Call the getTemperature function with the data file as input
      //This section puts the date and time into the data file
      if (hour() < 10) {                                       //For uniformity put a 0 in front of the hour before printing it to the file if it is before 10am (24hr time is used)
        f.print("0");
        f.print(hour());
      else {
        f.print(hour());
      printDigits(minute(), f);
      printDigits(second(), f);
      f.print(" ");
      if (month() < 10) {                                     //For uniformity if it is not yet october, put a 0 in front of the month
        f.print("0");
        f.print(month());
      else {
        f.print(month());
      f.print("/");
      if (day() < 10) {                                       //For uniformity if it is not the 10th of the month yet, put a 0 in front of the day
        f.print("0");
        f.print(day());
      else {
        f.print(day());
      f.print("/");
      f.print(year());
      f.println();
      f.close();                                             //Close the data file, writing is done
      Serial.println("5) FILE PRINTED AND CLOSED");
      if (doFTP(fileNameData)) Serial.println(F("FTP Data OK"));            //Upload the data file using the doFTP function
      else Serial.println(F("FTP Data FAIL"));
      if (newFileName.length() > 0) {                                       //If it has been a week, upload the new data file using the doFTP function
        if (doFTP(newFileName))  Serial.println(F("FTP DataNum OK"));
        else Serial.println(F("FTP DataNum FAIL"));
      Serial.println("6) FTP DONE");
  //This executes if the NTP time was not received
  else {
    Serial.println("2) TIME FAILED");
    for (int i = 0; i < 10; i++) {                        //Blink the led 10 times
      digitalWrite(led, LOW);
  digitalWrite(led, LOW);                                 //Turn off the LED
  Serial.println("3/7) GOING TO SLEEP");
  ESP.deepSleep(600000000);                               //Puts the ESP8266 into sleep mode for 10 minutes
   This is the function where the magic happens.
   all credit goes to SurferTim. This will open
   and write the file to your FTP server
byte doFTP(String fileName)
  File fh = SPIFFS.open(fileName, "r");
  if (!fh) {
    return 0;
  if (client.connect(host, 21)) {
    Serial.println(F("Command connected"));
  else {
    fh.close();
    Serial.println(F("Command connection failed"));
    return 0;
  if (!eRcv()) return 0;
  client.print("USER ");
  client.println(userName);
  client.print("PASS ");
  client.println(password);
  client.println("SYST");
  client.println("Type I");
  client.println("PASV");
  char *tStr = strtok(outBuf, "(,");
  int array_pasv[6];
  for ( int i = 0; i < 6; i++) {
    tStr = strtok(NULL, "(,");
    array_pasv[i] = atoi(tStr);
    if (tStr == NULL)
      Serial.println(F("Bad PASV Answer"));
      return 0;
  unsigned int hiPort, loPort;
  hiPort = array_pasv[4] << 8;
  loPort = array_pasv[5] & 255;
  Serial.print(F("Data port: "));
  hiPort = hiPort | loPort;
  Serial.println(hiPort);
  if (dclient.connect(host, hiPort)) {
    Serial.println("Data connected");
  else {
    Serial.println("Data connection failed");
    client.stop();
    fh.close();
    return 0;
  client.print("STOR ");
  client.println(fileName);
  if (!eRcv())
    dclient.stop();
    return 0;
  Serial.println(F("Writing"));
  byte clientBuf[64];
  int clientCount = 0;
  while (fh.available())
    clientBuf[clientCount] = fh.read();
    clientCount++;
    if (clientCount > 63)
      dclient.write((const uint8_t *)clientBuf, 64);
      clientCount = 0;
  if (clientCount > 0) dclient.write((const uint8_t *)clientBuf, clientCount);
  dclient.stop();
  Serial.println(F("Data disconnected"));
  client.println();
  client.println("QUIT");
  client.stop();
  Serial.println(F("Command disconnected"));
  fh.close();
  Serial.println(F("File closed"));
  return 1;
byte eRcv()
  byte respCode;
  byte thisByte;
  while (!client.available()) delay(1);
  respCode = client.peek();
  outCount = 0;
  while (client.available())
    thisByte = client.read();
    Serial.write(thisByte);
    if (outCount < 127)
      outBuf[outCount] = thisByte;
      outCount++;
      outBuf[outCount] = 0;
  if (respCode >= '4')
    efail();
    return 0;
  return 1;
void efail()
  byte thisByte = 0;
  client.println(F("QUIT"));
  client.stop();
void printDigits(int digits, File f) {
  // utility for digital clock display: prints preceding colon and leading 0
  f.print(":");
  if (digits < 10)
    f.print('0');
  f.print(digits);
/*-------- NTP code ----------*/
time_t getNtpTime()
  while (udp.parsePacket() > 0) ; // discard any previously received packets
  Serial.println("Transmit NTP Request");
  sendNTPpacket(timeServer);
  uint32_t beginWait = millis();
  while (millis() - beginWait < 1500) {
    int size = udp.parsePacket();
    if (size >= NTP_PACKET_SIZE) {
      Serial.println("Receive NTP Response");
      udp.read(packetBuffer, NTP_PACKET_SIZE);  // read packet into the buffer
      unsigned long secsSince1900;
      // convert four bytes starting at location 40 to a long integer
      secsSince1900 =  (unsigned long)packetBuffer[40] << 24;
      secsSince1900 |= (unsigned long)packetBuffer[41] << 16;
      secsSince1900 |= (unsigned long)packetBuffer[42] << 8;
      secsSince1900 |= (unsigned long)packetBuffer[43];
      return secsSince1900 - 2208988800UL + timeZone * SECS_PER_HOUR;
  Serial.println("No NTP Response :-(");
  return 0; // return 0 if unable to get the time
// send an NTP request to the time server at the given address
void sendNTPpacket(IPAddress &address)
  // set all bytes in the buffer to 0
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  // Initialize values needed to form NTP request
  // (see URL above for details on the packets)
  packetBuffer[0] = 0b11100011;   // LI, Version, Mode
  packetBuffer[1] = 0;     // Stratum, or type of clock
  packetBuffer[2] = 6;     // Polling Interval
  packetBuffer[3] = 0xEC;  // Peer Clock Precision
  // 8 bytes of zero for Root Delay & Root Dispersion
  packetBuffer[12]  = 49;
  packetBuffer[13]  = 0x4E;
  packetBuffer[14]  = 49;
  packetBuffer[15]  = 52;
  // all NTP fields have been given values, now
  // you can send a packet requesting a timestamp:
  udp.beginPacket(address, 123); //NTP requests are to port 123
  udp.write(packetBuffer, NTP_PACKET_SIZE);
  udp.endPacket();
 * This function reads the temperature from the MAX1820
 * sensor then prints it to a specified file.
 * Receives: A File object
 * Returns: Nothing
void getTemperature(File fh) {
  byte i;
  byte present = 0;
  byte type_s;
  byte data[12];
  byte addr[8];
  float celsius, fahrenheit;
  //Gets addresses of OneWire sensors
  if ( !ds.search(addr)) {
    Serial.println("No more addresses.");
    ds.reset_search();
    delay(250);
    return;
  //Prints the address of the OneWire sensors to the serial output
  Serial.print("ROM =");
  for ( i = 0; i < 8; i++) {
    Serial.write(' ');
    Serial.print(addr[i], HEX);
  //Checks the validity an address
  if (OneWire::crc8(addr, 7) != addr[7]) {
    Serial.println("CRC is not valid!");
    return;
  // the first ROM byte indicates which chip
  switch (addr[0]) {
    case 0x10:
      Serial.println("  Chip = DS18S20");  // or old DS1820
      type_s = 1;
      break;
    case 0x28:
      Serial.println("  Chip = DS18B20");
      type_s = 0;
      break;
    case 0x22:
      Serial.println("  Chip = DS1822");
      type_s = 0;
      break;
    default:
      Serial.println("Device is not a DS18x20 family device.");
      return;
  ds.reset();
  ds.select(addr);
  ds.write(0x44, 1);        // start conversion, with parasite power on at the end
  delay(1000);     // maybe 750ms is enough, maybe not
  // we might do a ds.depower() here, but the reset will take care of it.
  present = ds.reset();
  ds.select(addr);
  ds.write(0xBE);         // Read Scratchpad
  Serial.print("  Data = ");
  Serial.print(present, HEX);
  Serial.print(" ");
  for ( i = 0; i < 9; i++) {           // we need 9 bytes
    data[i] = ds.read();
    Serial.print(data[i], HEX);
    Serial.print(" ");
  Serial.print(" CRC=");
  Serial.print(OneWire::crc8(data, 8), HEX);
  // Convert the data to actual temperature
  // because the result is a 16 bit signed integer, it should
  // be stored to an "int16_t" type, which is always 16 bits
  // even when compiled on a 32 bit processor.
  int16_t raw = (data[1] << 8) | data[0];
  if (type_s) {
    raw = raw << 3; // 9 bit resolution default
    if (data[7] == 0x10) {
      // "count remain" gives full 12 bit resolution
      raw = (raw & 0xFFF0) + 12 - data[6];
  } else {
    byte cfg = (data[4] & 0x60);
    // at lower res, the low bits are undefined, so let's zero them
    if (cfg == 0x00) raw = raw & ~7;  // 9 bit resolution, 93.75 ms
    else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
    else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
    //// default is 12 bit resolution, 750 ms conversion time
  //Calculate celsius and fahrenheit values then print them to a file
  celsius = (float)raw / 16.0;
  fahrenheit = celsius * 1.8 + 32.0;
  fh.print(celsius);
  fh.print("\t");
  fh.print(fahrenheit);
  fh.print("\t");
