Page 1 of 3
ESP8266 WiFi clever Management question
PostPosted: Wed Dec 13, 2017 6:14 am
by mikekgr
Dear Sirs,
I am trying to implement something and I need your help.
My project will be builded around ESP8266 Arduino 2.4.0 RC2 core.
Well, I need to have a little “WiFi management logic” to my code with the following requirements:
During the initial setup, after ( power on or reboot/reset ), I wanted to check 3 things or possible scenarios in 3 “steps”:
1) To be connected to the last know WiFi AP ( using the Espressif internal way ). If this is not possible/failed or we get timeout ( I will have 10 seconds timeout ) let's continue to step (2)
2) Try for a connection to a pre-setted WiFi AP ( hard coded to my code ). If this connection can be done ( there is also here timeout of let’s say 10 seconds ), everything is ok the setup continuous to the other things not related to WiFi… If not, go to last step, step 3
3) Activate wifimanager ( using this library: https://github.com/tzapu/WiFiManager ) and wait user action for WiFi AP connection based on the available WiFi AP you may have. Also here I need to have a timeout of 180 seconds and if nothing been configured after this period, just do ESP8266 restart
What do you think? What is the best possible implementation? Please give me good ideas...
Thanks a lot.
Best Regards,
Mike Kranidis
Re: ESP8266 WiFi clever Management question
PostPosted: Wed Dec 13, 2017 1:05 pm
by rudy
Have a look at wifiMulti. http://arduino-esp8266.readthedocs.io/e ... mples.html
https://github.com/esp8266/Arduino/blob ... iMulti.ino
Then look to adding in an access point when the above fails.
PostPosted: Wed Dec 13, 2017 5:08 pm
by mikekgr
rudy wrote:Have a look at wifiMulti. http://arduino-esp8266.readthedocs.io/e ... mples.html
Dear @rudy thanks a lot for your reply and suggestions. I know the WiFiMulti but it does n't fit in my particular case.
Again, thanks and best regards,
Mike Kranidis
PostPosted: Thu Dec 14, 2017 3:35 pm
by mikekgr
mikekgr wrote:Dear Sirs,
Thanks a lot.
Best Regards,
Mike Kranidis
Hello there!
No body can help me to fulfil my above mentioned requirements? Is it so much difficult ???
