Question re ESP8266WebServer example
PostPosted: Wed May 23, 2018 5:16 am
by gatoruss
I have successfully flashed the ESP8266WebServer example (found here -->https://github.com/esp8266/Arduino/blob/master/libraries/ESP8266WiFi/examples/WiFiAccessPoint/WiFiAccessPoint.ino):
Code: Select all/*
   Copyright (c) 2015, Majenko Technologies
   All rights reserved.
   Redistribution and use in source and binary forms, with or without modification,
   are permitted provided that the following conditions are met:
 * * Redistributions of source code must retain the above copyright notice, this
     list of conditions and the following disclaimer.
 * * Redistributions in binary form must reproduce the above copyright notice, this
     list of conditions and the following disclaimer in the documentation and/or
     other materials provided with the distribution.
 * * Neither the name of Majenko Technologies nor the names of its
     contributors may be used to endorse or promote products derived from
     this software without specific prior written permission.
   THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
   ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
   WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
   DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR
   ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
   (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
   LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
   ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
   (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
   SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Create a WiFi access point and provide a web server on it. */
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
/* Set these to your desired credentials. */
const char *ssid = "ESPap";
const char *password = "thereisnospoon";
ESP8266WebServer server(80);
/* Just a little test message.  Go to http://192.168.4.1 in a web browser
   connected to this access point to see it.
void handleRoot() {
  server.send(200, "text/html", "<h1>You are connected</h1>");
  delay(1000);
  Serial.print("Configuring access point...");
  /* You can remove the password parameter if you want the AP to be open. */
  WiFi.softAP(ssid, password);
  Serial.println(myIP);
  server.on("/", handleRoot);
  server.begin();
  server.handleClient();
When I run the code on my ESP8266 esp-01, the serial terminal in my Arduino IDE says: AP IP address: 192.168.4.1 -- that is the IP address retruned by Wifi.softAPIP(). However, if I enter that address in my browser, I get a timed out error and cannot connect. But, if I log onto my router and get the local IP address assigned by my router to the esp8266 and enter that in my browser, I get the "You are connected" message in my browser.
Note the local IP address that I get from my router is the IP address that is returned by WiFi.localIP() (when running the "Quick Start" code (found here --> http://arduino-esp8266.readthedocs.io/en/latest/esp8266wifi/readme.html#quick-start):
void setup()
  WiFi.begin("network-name", "pass-to-network");
  Serial.print("Connecting");
  Serial.print("Connected, IP address: ");
void loop() {}
Is wifi.softAPIP() retuning the wrong value?
Re: Question re ESP8266WebServer example
PostPosted: Sun May 27, 2018 7:39 am
by noventix
The top example ix cresting an Access Point. The intent is for you to connect to that from your PC just like any other WiFi network. So before you type in that address, you need to connect to the "ESPap" WiFi network. Then that IP address will work fine.
PostPosted: Tue Jun 05, 2018 5:44 am
by gatoruss
Thank you for your reply. I have been traveling and unable to follow you suggestion until now -- and it worked!
I do have a follow up question, however. I have read that that "soft-AP + station" mode is the default configuration for wifi.softAP. When I flash WiFiAccessPoint/WiFiAccessPoint.ino to the Esp8266, is broadcasts its ssid and allows me to log on using the password that I have established, and it also connects to my home network as a station. However, although my home network is secured (and requires a password to connect) the Esp8266 connects without the ssid or password of my home network being entered!
How is that possible?
I previously connected the Esp8266 to my home network using the "quick start" code referenced above; however, I have since flashed the Esp8266 with other code -- bothe the WiFiAccessPoint.ino code and LED blink code -- yet when I run the WiFiAccessPoint.ino code (which does contains neither the ssid nor the password for my home network), the Esp8266 connects to my home network?
PostPosted: Wed Jun 06, 2018 4:09 am
by QuickFix
gatoruss wrote:How is that possible?
Some things, like WiFi-mode (AP, STA or both) and credentials are stored in EEPROM and in flash memory and stay untouched when you reflash the ESP. :idea:
