By elhamkh
#80810 hi i want to establish communication between two nodemcu esp8266 wifi module as client and server without home router by arduino IDE using UDP protocol . after uploaded codes on two device, only server send packet to client but client is not able to send reply . i want to have bi-directional communication between them . please guide me about this issue
best regards.......
client code is :
#include <Wire.h>
#include <WiFiUdp.h>
const char *ssid = "******";
const char *pass = "******";
unsigned int localPort = 2000; // local port to listen for UDP packets
IPAddress ServerIP(192,168,4,1);
IPAddress ClientIP(192,168,4,3);
// A UDP instance to let us send and receive packets over UDP
WiFiUDP udp;
char packetBuffer[255]; //Where we get the UDP data
char replyBuffer[99] = "Hi there! Got the message "; // a reply string to send back
// Setup
void setup()
WiFi.begin(ssid, pass); //Connect to access point
Serial.println("");
// Wait for connection
Serial.print(".");
Serial.println("");
Serial.println(ssid);
Serial.print("IP address: ");
//Start UDP
Serial.println("Starting UDP");
udp.begin(localPort);
Serial.print("Local port: ");
Serial.println(udp.localPort());
// MAIN LOOP
void loop()
int cb = udp.parsePacket();
udp.beginPacket(ClientIP, 2000);
udp.write(replyBuffer,99); //Send one byte to ESP8266
udp.endPacket();
delay(1000);
// We've received a UDP packet, send it to serial
udp.read(packetBuffer, 255); // read the packet into the buffer, we are reading only one byte
Serial.print(packetBuffer);
delay(2000);
server code is :
#include <Wire.h>
IPAddress ClientIP(192,168,4,2);
WiFiUDP udp;
char packetBuffer[]="this buffer is just for test of server"; //Where we get the UDP data
char replyBuffer[99];
// Setup
void setup()
WiFi.softAP(ssid, pass); //Create Access point
//Start UDP
// MAIN LOOP
void loop()
udp.write(packetBuffer,255); //Send one byte to ESP8266
udp.endPacket();
delay(1000);
udp.read(replyBuffer, 99); // read the packet into the buffer, we are reading only one byte
Serial.print(replyBuffer);
delay(2000);
