Page 1 of 3
mDNS responder doesn't work for esp8266.local
PostPosted: Wed Mar 27, 2019 11:49 am
by nealmartini
I am using the esp8266 web server example in Arduino Examples. I have tried several esp8266 boards and several computer and several browsers. I get the server to work using the DHCP assigned IP address, but can't get esp8266.local to work.
There are myriad responses to this issue that show up in a web search. So far I can't find a solution that works.
Am I missing something? Has this problem been solved?????
Re: mDNS responder doesn't work for esp8266.local
PostPosted: Thu Mar 28, 2019 7:52 am
by QuickFix
PostPosted: Thu Mar 28, 2019 10:25 am
by rudy
nealmartini wrote:I get the server to work using the DHCP assigned IP address, but can't get esp8266.local to work.
I have not had much success with it. Sometimes it work and other times it doesn't. I was hoping that it would work better with version 2.5.0 but I am waiting until the next release before I switch. The mDNS in 2.5.0 is a replacement of what had been previously used.
I use Windows and I wonder if it may also be a part of the problem.
PostPosted: Thu Mar 28, 2019 10:49 am
by nealmartini
I am using the NODE MCU 12E module. I also tried the server examples on an ESP32 new module.
By Rudy, how can I tell if I am using the mDNS 2.5 version? I loaded the latest Arduino board extensions within the past three weeks.
I never got things to work on Windows 10. I did get it to work a few times on a Mac Book computer, but very intermittently.
Have you tried to implement "Update mDNS examples to use HTTP Server instead of TCP Server" that I saw online?
Neal
