I use a WI-FI board ESP8266 12E, Arduino IDE with BLYNK libraries, Usb-serial converter with 340G driver.
I uploaded the BLYNK example, which works fine, but I have a problem configuring the GPIO on the sketch.
When I restart the app, the GPIO starts at a high level, in my project they have to start at a low level, can you help me write the part of the doors of the board?
This is BLYNK example is original with no added code:
Download latest Blynk library here:
https://github.com/blynkkk/blynk-librar ... ses/latest
Blynk is a platform with iOS and Android apps to control
Arduino, Raspberry Pi and the likes over the Internet.
You can easily build graphic interfaces for all your
projects by simply dragging and dropping widgets.
Downloads, docs, tutorials: http://www.blynk.cc
Sketch generator: http://examples.blynk.cc
Blynk community: http://community.blynk.cc
Follow us: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
Blynk library is licensed under MIT license
This example code is in public domain.
This example runs directly on ESP8266 chip.
Note: This requires ESP8266 support package:
https://github.com/esp8266/Arduino
Please be sure to select the right ESP8266 module
in the Tools -> Board menu!
Change WiFi ssid, pass, and Blynk auth token to run
Feel free to apply it to any other example. It's simple!
/* Comment this out to disable prints and save space */
#define BLYNK_PRINT Serial
#include <BlynkSimpleEsp8266.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "YourAuthToken";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "YourNetworkName";
char pass[] = "YourPassword";
void setup()
// Debug console
Serial.begin(9600);
Blynk.begin(auth, ssid, pass);
void loop()
Blynk.run();
