Here is an example sketch that shows how to use PubSubClient on ESP8266:
https://gist.github.com/igrr/7f7e7973366fc01d6393
Explore... Chat... Share...
Arduino: 1.6.1 (Windows 8.1), Board: "Generic ESP8266 board"
[i]esp8266_pubsubclient.ino:1:26: fatal error: PubSubClient.h: No such file or directory
compilation terminated.
Error compiling.
Build options changed, rebuilding all
Using library ESP8266WiFi in folder: D:\ESP8266\tools-utilites\arduino-1.6.1-windows\arduino-1.6.1\hardware\esp8266com\esp8266\libraries\ESP8266WiFi
D:\ESP8266\tools-utilites\arduino-1.6.1-windows\arduino-1.6.1/hardware/tools/esp8266/xtensa-lx106-elf/bin/xtensa-lx106-elf-g++ -D__ets__ -DICACHE_FLASH -ID:\ESP8266\tools-utilites\arduino-1.6.1-windows\arduino-1.6.1/hardware/tools/esp8266/sdk//include -c -Os -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -std=c++11 -MMD -DF_CPU=80000000L -DARDUINO=10601 -DARDUINO_ESP8266_ESP01 -DARDUINO_ARCH_ESP8266 -ID:\ESP8266\tools-utilites\arduino-1.6.1-windows\arduino-1.6.1\hardware\esp8266com\esp8266\cores\esp8266 -ID:\ESP8266\tools-utilites\arduino-1.6.1-windows\arduino-1.6.1\hardware\esp8266com\esp8266\variants\esp01 -ID:\ESP8266\tools-utilites\arduino-1.6.1-windows\arduino-1.6.1\hardware\esp8266com\esp8266\libraries\ESP8266WiFi\src C:\Users\Michael\AppData\Local\Temp\build7464644365248102153.tmp\esp8266_pubsubclient.cpp -o C:\Users\Michael\AppData\Local\Temp\build7464644365248102153.tmp\esp8266_pubsubclient.cpp.o
Error compiling.It takes about 20-25 seconds for home assistant c[…]
