I'm trying to use ESP8266AVRISP example sketch, but without any luck.
https://github.com/esp8266/Arduino/tree/master/libraries/ESP8266AVRISP
Using Arduino IDE v1.8.2 with ESP8266 Core v2.3.0 and Avrdude v6.3 on Windows 7 SP1 64-bit.
After connecting WeMos D1 mini with Arduino Uno over ICSP header like this:
D1 = RESET
D5 = SCK
D6 = MISO
D7 = MOSII'm using Avrdude command like this:
avrdude -v -C avrdude.conf -c arduino -p m328p -P net:192.168.0.230:328 -U flash:w:Blink.hex:iI'm getting this output from Avrdude:
avrdude: Version 6.3, compiled on Feb 17 2016 at 09:25:53
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "avrdude.conf"
Using Port : net:192.168.0.230:328
Using Programmer : arduino
avrdude: ser_drain(): read error: The parameter is incorrect.
AVR Part : ATmega328
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page
Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 00 0x00 0x00
signature 0 0 0 0 no 3 0 0 00 0x00 0x00
Programmer Type : Arduino
Description : Arduino
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10
Hardware Version: 4669920
Firmware Version: 0.2
Topcard : STK502
Vtarget : 1.8 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: stk500_initialize(): (b) protocol error, expect=0x10, resp=0x01
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x10
avrdude done. Thank you.The output from the ESP8266 (WeMos D1 mini):
Arduino AVR-ISP over TCP
IP address: 192.168.0.230
Use your avrdude:
avrdude -c arduino -p <device> -P net:192.168.0.230:328 -t # or -U ...
[AVRISP] connection pending
[AVRISP] programming mode
[AVRISP] now idle
Any help would be greatly appreciated!
Thank You!
