- Sat May 16, 2015 4:10 pm
#17590
Hi rheslip,
Thank you so much for sharing your code. I am attempting a similar setup with a GPS and some other sensors. I tried your code as posted using this release (
https://github.com/sandeepmistry/esp826 ... /tag/0.0.5) of the ESP Arduino setup.
Unfortunately the status of the AP does not seem to change once the station (my phone) connects to it. I modified the portion of the setup() call a bit to get some more debugging from it but can't find a reason for the failure:
Code: Select allvoid setup() {
Serial.begin(4800); // NMEA 0183 speed
delay(10);
// We start by setting up WiFi access point
Serial.print("Setting up AP ");
Serial.println(ssid);
WiFi.mode(WIFI_AP);
WiFi.begin(ssid);//, password);
WiFi.softAP(ssid);//,password,1); // doesn't seem to set up a secure network
Serial.print("Starting AP at: "); Serial.println(WiFi.softAPIP());
WiFi.printDiag(Serial);
int x = 0;
Serial.print(WiFi.status());Serial.print(".");
if(x++ > 80)
x = 0;
Serial.println("");
Serial.print("AP IP address: ");
//Serial.print("Remote IP address: ");
//Serial.println(WiFiClient.remoteIP()); // doesn't work - not sure how you get client's IP
Udp.beginPacket("192.168.4.2", 2000); // seems to always give out the next IP after its own, but this increases as more connections are made
The WiFi.status() method seems to relate to the station mode of the ESP and not the AP mode so it continuously reports a status of 1 (WL_NO_SSID_AVAIL) when waiting for the connection although I can see my reports being connected to humminbird with a valid IP (I can even ping 192.168.4.1).
How did you manage to get the connection working?
Here's a sample debug output of the setup() method:
Code: Select allSetting up AP humminbird
Starting AP at: 192.168.4.1
Mode: STA+AP
PHY mode: N
Channel: 1
AP id: 0
Status: 1
Auto connect: 1
SSID (10): humminbird
Passphrase (0):
BSSID set: 0
6.6.6.6.6.6.6.6.6.6.6.6.6.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.1.
1.1.1.1.1.1.1
