By Zig
#15323 Is there an example sketch on how to implement SPI ( HSPI ) using esp8266 micro ?
By squix78
#15587 Hi Zig
I wrote a little library which talks to a MAX7219 over SPI to drive a 8x8 led matrix. You can find the code here:
https://github.com/squix78/MAX7219LedMatrix
and the explanation/wiring here:
http://blog.squix.ch/2015/04/esp8266arduino-max7219-8x8-led-matrix.html
Please note: the currently released version comes with an incomplete SPI library. So you'll have to patch it with the one from github or build it from scratch in the first place...
By Zig
#15729 Much obliged Squix.
I wish to interrogate a Bosch barometric pressure module.
Hope to be able to replicate Your success.
By Mikejstb
#19693 Could you explain the process to patch the SPI library?
I'm running under Windows, does that matter?
And, is this patch needed for the 1.6.1 Arduino or the 1.6.4 version, or both?
