Page 1 of 2
STORING AND READING SSID/PASS FROM EEPROM
PostPosted: Fri Apr 24, 2015 10:54 am
by kanin03
The idea by esp-arduino-apboot
on Chriscook8 post viewtopic.php?f=29&t=2520
I modified to use ESP8266WebServer.h for handle RestAPI easily
here gist update https://gist.github.com/dogrocker/f998dde4dbac923c47c1
#include <ESP8266mDNS.h>
#include <ESP8266WebServer.h>
#include <EEPROM.h>
MDNSResponder mdns;
ESP8266WebServer server(80);
const char* ssid = "BUBBLES";
const char* passphrase = "BUBBLES";
String st;
String content;
  EEPROM.begin(512);
  delay(10);
  Serial.println("Startup");
  // read eeprom for ssid and pass
  Serial.println("Reading EEPROM ssid");
  String esid;
  for (int i = 0; i < 32; ++i)
      esid += char(EEPROM.read(i));
  Serial.print("SSID: ");
  Serial.println(esid);
  Serial.println("Reading EEPROM pass");
  String epass = "";
  for (int i = 32; i < 96; ++i)
      epass += char(EEPROM.read(i));
  Serial.print("PASS: ");
  Serial.println(epass);
  if ( esid.length() > 1 ) {
      // test esid
      WiFi.begin(esid.c_str(), epass.c_str());
      if (testWifi()) {
          launchWeb(0);
          return;
  setupAP();
bool testWifi(void) {
  int c = 0;
  Serial.println("Waiting for Wifi to connect");
  while ( c < 20 ) {
    if (WiFi.status() == WL_CONNECTED) { return true; }
    Serial.print(WiFi.status());
    c++;
  Serial.println("");
  Serial.println("Connect timed out, opening AP");
  return false;
void launchWeb(int webtype) {
  Serial.println("");
  Serial.print("Local IP: ");
  Serial.print("SoftAP IP: ");
  Serial.println(WiFi.softAPIP());
  if (!mdns.begin("esp8266", WiFi.localIP())) {
    Serial.println("Error setting up MDNS responder!");
    while(1) {
      delay(1000);
  Serial.println("mDNS responder started");
  createWebServer(webtype);
  // Start the server
  server.begin();
void setupAP(void) {
  WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  delay(100);
  int n = WiFi.scanNetworks();
  Serial.println("scan done");
  if (n == 0)
    Serial.println("no networks found");
  else
    Serial.print(n);
    Serial.println(" networks found");
    for (int i = 0; i < n; ++i)
      // Print SSID and RSSI for each network found
      Serial.print(i + 1);
      Serial.print(": ");
      Serial.print(WiFi.SSID(i));
      Serial.print(" (");
      Serial.print(WiFi.RSSI(i));
      Serial.print(")");
      Serial.println((WiFi.encryptionType(i) == ENC_TYPE_NONE)?" ":"*");
      delay(10);
  Serial.println("");
  st = "<ol>";
      st += "<li>";
      st += WiFi.SSID(i);
      st += " (";
      st += WiFi.RSSI(i);
      st += ")";
      st += (WiFi.encryptionType(i) == ENC_TYPE_NONE)?" ":"*";
      st += "</li>";
  st += "</ol>";
  delay(100);
  WiFi.softAP(ssid);
  Serial.println("softap");
  launchWeb(1);
  Serial.println("over");
void createWebServer(int webtype)
  // Check for any mDNS queries and send responses
  mdns.update();
  if ( webtype == 1 ) {
    server.on("/", []() {
        IPAddress ip = WiFi.softAPIP();
        String ipStr = String(ip[0]) + '.' + String(ip[1]) + '.' + String(ip[2]) + '.' + String(ip[3]);
        content = "<!DOCTYPE HTML>\r\n<html>Hello from ESP8266 at ";
        content += ipStr;
        content += "<p>";
        content += st;
        content += "</p><form method='get' action='setting'><label>SSID: </label><input name='ssid' length=32><input name='pass' length=64><input type='submit'></form>";
        content += "</html>";
        server.send(200, "text/html", content);
    server.on("/setting", []() {
        String qsid = server.arg("ssid");
        String qpass = server.arg("pass");
        if (qsid.length() > 0 && qpass.length() > 0) {
          Serial.println("clearing eeprom");
          for (int i = 0; i < 96; ++i) { EEPROM.write(i, 0); }
          Serial.println(qsid);
          Serial.println("");
          Serial.println(qpass);
          Serial.println("");
          Serial.println("writing eeprom ssid:");
          for (int i = 0; i < qsid.length(); ++i)
              EEPROM.write(i, qsid[i]);
              Serial.print("Wrote: ");
              Serial.println(qsid[i]);
          Serial.println("writing eeprom pass:");
          for (int i = 0; i < qpass.length(); ++i)
              EEPROM.write(32+i, qpass[i]);
              Serial.println(qpass[i]);
          EEPROM.commit();
          content = "<!DOCTYPE HTML>\r\n<html>";
          content += "<p>saved to eeprom... reset to boot into new wifi</p></html>";
        } else {
          content = "Error";
          Serial.println("Sending 404");
  } else {
      server.send(200, "text/plain", "this works as well");
      server.send(200, "text/plain", "setting.");
    server.on("/cleareeprom", []() {
      content += "<p>Clearing the EEPROM</p></html>";
      EEPROM.commit();
  server.handleClient();
Re: STORING AND READING SSID/PASS FROM EEPROM
PostPosted: Thu Jan 14, 2016 2:28 pm
by lovelesh
kanin03 wrote:I modified to use ESP8266WebServer.h for handle RestAPI easily
Can you explain the difference between WiFiServer library and ESP8266WebServer library?
Which one performs better?
PostPosted: Thu Jan 14, 2016 3:25 pm
by martinayotte
WiFiServer is plain TCP Socket server, you can use it for creating a Telnet Server for example.
ESP8266WebServer is using WiFiServer internally to received HTTP request, but it does all the arguments parsing and use handlers to dispatch the call according to URL paths, etc.
PostPosted: Tue Jul 12, 2016 12:14 am
by acpilot
Thank you for posting this!
I'm running into a problem though. Using your example, I cannot actually get a page to appear at the IP (192.168.4.1 in this case). What could prevent the esp from hosting a html form using this code?
Again, thank you for the example.
