SDA --- GPIO4
SCL --- GPIO5
#include <Wire.h>
#define MLX90614_TA 0x06
#define MLX90614_TOBJ1 0x07
Serial.begin(9600);
Wire.pins(4,5);
Wire.setClock(100000);
uint16_t read16(uint8_t addr, uint8_t i2c_addr){
uint16_t ret;
Wire.beginTransmission(i2c_addr); // start transmission to device
Wire.write(addr); // sends register address to read from
Wire.endTransmission(false); // end transmission
Wire.requestFrom(i2c_addr, (uint8_t)3);// send data n-bytes read
ret = Wire.read(); // receive DATA
ret |= Wire.read() << 8; // receive DATA
uint8_t pec = Wire.read();
return ret;
float readTemp(uint8_t reg, uint8_t i2c_addr) {
float temp;
temp = read16(reg, i2c_addr);
temp *= .02;
temp -= 273.15;
return temp;
double readObjectTempC(uint8_t i2c_addr) {
return readTemp(MLX90614_TOBJ1, i2c_addr);
double readAmbientTempC(uint8_t i2c_addr) {
return readTemp(MLX90614_TA, i2c_addr);
Serial.print("Ambient = "); Serial.print(readAmbientTempC(0x5A));
Serial.print("*C\tObject = "); Serial.print(readObjectTempC(0x5A)); Serial.println("*C");
delay(1000);
