By oeyhaga
#16699 Having problems with my code. Trying to use code from adafruit to get data from my ThingSpeak app. Does not seem to work. It connects, but returs no data. Im very new at programming so prob a stupid mistake or something... :?
Hope someone can help :)
Code: Select all/*
 *  Simple HTTP get webclient test
const char* ssid     = "MYNET";
const char* password = "123456789";
const char* host = "api.thingspeak.com";
  delay(10);
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
int value = 0;
  delay(5000);
  ++value;
  Serial.println(host);
  WiFiClient client;
  const int httpPort = 80;
    return;
  // We now create a URI for the request
  String url = "/apps/thinghttp/send_request?api_key=PAW43HX9QN9SVOW1";
  Serial.println(url);
    client.print(String("GET ") + url + " HTTP/1.0\r\n" +
               "Host: " + host + "\r\n" +
               "Connection: close\r\n\r\n");
  delay(10);
  while(client.available()){
    Serial.print(line);
By oeyhaga
#16726 Seems that you did'nt copy the entire url.
The url in the code is: http://api.thingspeak.com/apps/thinghttp/send_request?api_key=PAW43HX9QN9SVOW1
If I change host and url to something else like turay.ddns.net/data.php the code works fine.
Maybe ThinkHTTP require something more in the GET command line?
By oeyhaga
#16838 Seem I'v solved the problem. As easy as adding a longer delay after GET command.
Changed delay(10); to delay(500)
Finaly I can continue with the project after many hours scratching my head :P
const char* ssid     = "NAME";
const char* password = "PASSWORD";
int value = 1;
  delay(10);
    Serial.print(".");
  Serial.println("");
}//end setup
  delay(5000);
  WiFiClient Client;
  if (!Client.connect(host, httpPort)) {
    Serial.println("Connection failed");
    return;
  Serial.println(host + url);
  Serial.println(String("TRY: ") + value + ".");
 Client.print(String("GET ") + url + "&headers=false" + " HTTP/1.1\r\n" + "Host: " + host + "\r\n" + "Connection: close\r\n\r\n");
  while(Client.available()){
  String line = Client.readStringUntil('\r');
  Serial.println(line);
  Serial.println("");
  Serial.println(String("Try nr. ") + value + " is finished.");
  Serial.println("Waiting for next try...");
  Serial.println("");
  value = value + 1;
  delay(20000);
