stupid quesion... but what is the portnumber of analog in (TOUT)? If I make:
analog_value = analogread(A0);
I get only jumping values. Connected is a 10k potentiometer.
Thanks, Bernd
Explore... Chat... Share...
extern "C" {
#include "user_interface.h"
int readvdd33(void);
void setup(){
void loop(){
Serial.print("[SDK direct] Chipid : "); Serial.println(system_get_chip_id());
Serial.print("[SDK direct] Heapsize : "); Serial.println(system_get_free_heap_size());
Serial.print("[SDK direct] RTC time : "); Serial.println(system_get_rtc_time());
int vdd33 = readvdd33();
Serial.print("[SDK direct] Vdd33 : "); Serial.println(vdd33);
delay(5000);
