we have just ported Souliss on ESP8266, see below the screenshot of the Android application SoulissApp.
Here a sample sketch to run togheter with the Souliss library, I strongly suggest to download the whole IDE that contains the Arduino cores for ESP8266 that we have tested from this link.
Souliss - Hello World for Expressif ESP8266
This is the basic example, create a software push-button on Android
using SoulissApp (get it from Play Store).
Load this code on ESP8266 board using the porting of the Arduino core
for this platform.
// Configure the framework
#include "bconf/MCU_ESP8266.h" // Load the code directly on the ESP8266
#include "conf/Gateway.h" // The main node is the Gateway, we have just one node
#include "conf/DynamicAddressing.h" // Use dynamic addressing
#include "conf/DisableEEPROM.h"
// Define the WiFi name and password
#define WIFICONF_INSKETCH
#define WiFi_SSID "mywifi"
#define WiFi_Password "mypassword"
// Include framework code and libraries
#include "Souliss.h"
// This identify the number of the LED logic
#define MYLEDLOGIC 0
void setup()
Initialize();
// Connect to the WiFi network and get an address from DHCP
Setup_ESP8266();
SetAsGateway(myvNet_esp8266); // Set this node as gateway for SoulissApp
// This node will serve all the others in the network providing an address
SetAddressingServer();
Set_SimpleLight(MYLEDLOGIC); // Define a simple LED light logic
pinMode(5, OUTPUT); // Use pin 5 as output
void loop()
// Here we start to play
EXECUTEFAST() {
UPDATEFAST();
FAST_50ms() { // We process the logic and relevant input and output every 50 milliseconds
Logic_SimpleLight(MYLEDLOGIC);
DigOut(5, Souliss_T1n_Coil,MYLEDLOGIC);
// Here we handle here the communication with Android
FAST_GatewayComms();
This tiny sketch handle the communication with SoulissApp and control a relay (we have tested on Olimex ESP8266-EVB) on GPIO5.
Is just the simplest example, you can mix multiple ESP and control them from a central point, either SoulissApp or openHAB and have a network that contains also Arduino based on ATmega AVR that use 2.4 GHz radio like nRF24L01 and RFM69 or RS485 communication.
Have a try, and share your ideas!
