- Mon Aug 03, 2015 10:31 pm
#24949
I'd have called you a liar if you had told me this story ....
Since I wasn't seeing any clock signal with my analyzer and had poured through my code and had convinced myself that the signal was toggling (from a logical perspective), I got out my resistance meter and started checking connectivity ... thinking that maybe I had broken a solder joint somewhere/somehow. In the end I traced it to a dupont wire connector with two male pins. Zero connectivity between the ends.
Ive never had this happen to me before ... and it shakes my core trust .... do I now have to actually check every wire in my circuit when something doesn't work!!
Now ... off to test my solution with a new wire ...
Neil
Later ...
Yup ... all now works ...
Code: Select allScanning...
I2C device found at address 0x23 !
Free ESP8266 book available for download
here.
