I'm having trouble trying to upload to ubidots but im'not sure where am i wrong.
on my serial monitor i can view my sensor readings but not online, although it seems esp8266 module is sending the data over.
#include <stdlib.h>
#include <SoftwareSerial.h>
#define SSID "boomgrow"
#define PASS "boom1grow"
#define IP "http://50.23.124.66"
//String GET = "GET /api/postvalue/?token=JTV7TqHW7GmDZuQOmb1KASZiYjel62a1PFz7w1rdW4sMjD8xwPY39h06zpmU&variable=5592c2877625426471f981a1&value=";
String GET = "GET /api/postvalue/?token=JTV7TqHW7GmDZuQOmb1KASZiYjel62a1PFz7w1rdW4sMjD8xwPY39h06zpmU&variable=556ec1737625425fb28692d5&value="; //dust variable ID = 556ec1737625425fb28692d5
//String voc1 = "55399a667625421a969d052d";
SoftwareSerial monitor(0, 1); // RX, TX
//*****DUST SENSOR SETUP
int measurePin = A5; //SIGNAL PIN(ANY ANALOG PIN)
int ledPower = 2; //ANY DIGITAL PIN
int samplingTime = 280;
int deltaTime = 40;
int sleepTime = 9680;
float voMeasured = 0;
float calcVoltage = 0;
float dustDensity = 0;
void setup()
pinMode(ledPower, OUTPUT);
monitor.begin(9600);
Serial.begin(9600);
//**** TEST ESP8266 Module
sendDebug("AT");
delay(5000);
if (Serial.find("OK")) {
monitor.println("RECEIVED: OK");
connectWiFi();
//**VOC loop
int sensorValue = analogRead(A0);
float Vol = sensorValue * 4.95 / 1023;
Serial.print("Vol = ");
Serial.println(Vol);
//**DUST loop
digitalWrite(ledPower, LOW); // power on the LED
delayMicroseconds(samplingTime);
voMeasured = analogRead(measurePin); // read the dust value
delayMicroseconds(deltaTime);
digitalWrite(ledPower, HIGH); // turn the LED off
delayMicroseconds(sleepTime);
// 0 - 5.0V mapped to 0 - 1023 integer values
calcVoltage = voMeasured * (5.0 / 1024);
dustDensity = (0.17 * calcVoltage - 0.1) * 1000;
Serial.print("Raw Signal Value (0-1023): ");
Serial.print(voMeasured);
Serial.print(" - Voltage: ");
Serial.print(calcVoltage);
Serial.print(" - Dust Density [ug/m3]: ");
Serial.println(dustDensity);
float Dust = dustDensity;
delay(1000);
save_value(String(Dust));
delay(1000);
void save_value(String Dust) {
//Set up TCP connection.
String cmd = "AT+CIPSTART=\"TCP\",\"";
cmd += IP;
cmd += "\",80";
Serial.println(cmd);
//sendDebug(cmd);
delay(2000);
if (Serial.find("Error")) {
monitor.print("RECEIVED: Error");
return;
//Send DAta
cmd = GET;
cmd += Dust;
cmd += "\r\n";
Serial.print("AT+CIPSEND=");
Serial.println(cmd.length());
if (Serial.find(">")) {
monitor.print(">");
monitor.print(cmd);
Serial.print(cmd);
} else {
sendDebug("AT+CIPCLOSE");
} else {
monitor.println("RECEIVED: Error");
void sendDebug(String cmd) {
monitor.print("SEND: ");
monitor.println(cmd);
boolean connectWiFi() {
Serial.println("AT+CWMODE=1");
delay(2000);
String cmd = "AT+CWJAP=\"";
cmd += SSID;
cmd += "\",\"";
cmd += PASS;
cmd += "\"";
sendDebug(cmd);
delay(5000);
return true;
} else {
return false;
Assistance would be appreciated to my graveyard and beyond
