to implement the project first start using a standard PC MQTT client to drive MQTTled.ino demo sketch
The demo esp8266 board
Setup the Hardware :
- One button from GPIO2 to Ground
- One led + resistor from GPIO0 to Ground
- Pull Up CH-PD pin
Upload MQTT_led_V1.06 demo sketch to the esp8266, (attached file below)
make sure you use your own router username and pass
const char* ssid = "Livebox-27C2"; // Your specific WiFi network credentials
const char* pass = "23456789";
const char* serverURI = "m20.cloudmqtt.com"; // Your specific MQTT broker parameters
const uint16_t port = 18084;
const char* user_name = "uqkfcjrz";
const char* password = "+++++++++";
const char* clientID = "MQTTkas"; // client ID
MQTT broker
Choose and configure a mqtt broker (I use CloudMQTT)
MQTT test client
To test your setup, download and configure a standard MQTT client (I use MQTT-spy)
Make sure to subscribe to 'led' and 'feedback'
Installing the Android App
Finally get MQTT Commander App, and configure both Connection and Session pages,
You are now ready to go
Android App and ESP8266 led are now fully synchronized
- the App button drives the board led
- a local led state change will be reflected on the Android device screen
I will post the Application on Google Play within a few weeks (as a free App)
In the meantime, to get it NOW, notify me here and drop me a Private Message including your email address.
Again, to make life easier, please make sure to have the system working with MQTT-spy, before trying MQTT Commander
This board is a proof of concept; I plan to replace the led by a 3V Opt coupler insulated relay
I am baffled by this new cute WiFi device, and may end up developing a joystick application similar to Joystick Bluetooth Commander
