By freedom2000
#23629 Hi all,
Here is my latest realization : a eConnected bathroom scale.
[youtube=XOOPPMxXoks][/youtube]
It's using the cheap HX711 which is a load cell amplifier.
The load cell of the original scale is directly connected to HX711
The ESP8266 board is reading this sensor, averaging the raw values and then outputs the weight to LCD and to thingspeak.com.
The Talkbackfuntionnality is used to control the board and perform :
- tare (zero offset)
- weight calibration
- memory of 5 persons
Here is the code to read the sensor :
Code: Select all/*
 HX711 raw reading
by http://freedom2000.free.fr
// the setup function runs once when you press reset or power the board
unsigned long Weight = 0;
unsigned long AverageWeight = 0;
   int Clock = 5; //4 on board
   int Dout = 4; //5 on board
void setup()
  //intialize HX711
  pinMode(Clock, OUTPUT); // initialize digital pin 4 as an output.(clock)
  digitalWrite(Clock, HIGH);
  delayMicroseconds(100);   //be sure to go into sleep mode if > 60µs
  digitalWrite(Clock, LOW);     //exit sleep mode*/
  pinMode(Dout, INPUT);  // initialize digital pin 5 as an input.(data Out)
  Serial.begin(115200); // initialize serial communication at 9600 bits per second:
  Serial.println("ready");
  delay(100);
// the loop function runs over and over again forever
void loop()
  // wait for the chip to become ready
 while (digitalRead(Dout) == HIGH);
 AverageWeight = 0;
  for (char j = 0; j<100; j++)
     Weight =0;
    // pulse the clock pin 24 times to read the data
    for (char i = 0; i<24; i++)
      delayMicroseconds(2);
      Weight = Weight <<1;
      if (digitalRead(Dout)==HIGH) Weight++;
    // set the channel and the gain factor (A 128) for the next reading using the clock pin (one pulse)
    Weight = Weight ^ 0x800000;
    AverageWeight += Weight;
    delayMicroseconds(60);
  AverageWeight = AverageWeight/100;
  Serial.println(AverageWeight);
  Serial.println("");
  delay(1000);
I only give the raw reading of the sensor, all the other stuff to connect to thingspeak has already been several times explained (and thanks for that !)
JP
By churchill
#24522 Parfait, je voulais justement en faire une ! Thank you.
(edit) Juste une question, comment détectes-tu l'allumage de la balance ?
Just a question, how do you detect the start of scale ?
