- Sat Jul 25, 2015 8:33 pm
#24270
Alright I have it responding to broadcast UDP packets
There was some misunderstanding by me of where to send the broadcast packet to, but it's working now.
I'll have to now write up a little java applet or something that can send these out, find the reply, check it's magic packet and launch the web-browser to connect. Code here is very slightly modified from the Arduino example here:
https://www.arduino.cc/en/Tutorial/WiFi ... eUDPStringCode: Select all#include <Time.h>
#include <ESP8266mDNS.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <NeoPixelBus.h>
#include <EEPROM.h>
#include <ntp.h>
#include <Ticker.h>
int status = WL_IDLE_STATUS;
char ssid[] = "SSID"; // your network SSID (name)
char pass[] = "pass"; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0; // your network key Index number (needed only for WEP)
unsigned int localPort = 2390; // local port to listen on
char packetBuffer[255]; //buffer to hold incoming packet
char ReplyBuffer[] = "acknowledged"; // a string to send back
WiFiUDP Udp;
//Initialize serial and wait for port to open:
Serial.println("I'm awake");
// attempt to connect to Wifi network:
WiFi.begin(ssid, pass);
Serial.println("");
// Wait for connection
Serial.print(".");
Serial.println("Connected to wifi");
printWifiStatus();
Serial.println("\nStarting connection to server...");
// if you get a connection, report back via serial:
Udp.begin(localPort);
// if there's data available, read a packet
int packetSize = Udp.parsePacket();
if (packetSize) {
Serial.print("Received packet of size ");
Serial.println(packetSize);
Serial.print("From ");
IPAddress remoteIp = Udp.remoteIP();
Serial.print(remoteIp);
Serial.print(", port ");
Serial.println(Udp.remotePort());
// read the packet into packetBufffer
int len = Udp.read(packetBuffer, 255);
if (len > 0) {
packetBuffer[len] = 0;
Serial.println("Contents:");
Serial.println(packetBuffer);
// send a reply, to the IP address and port that sent us the packet we received
Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
Udp.write(ReplyBuffer);
Udp.endPacket();
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
