for a Projekt I had to submit data from Website to ESP without reloading the page. Normally I would do this by JQuery, but because there is no Internet connection and I didn't want to include the hole Framework I went back to basics.
So here is a lil snippit if somebody else needs this:
void htmlLight() {String site;
/* First part is just for debug */
site+=F("<script>function reqListener () {\n\r");
site+=F(" console.log(this.responseText);\n\r");
site+=F("}\n\r");
/* Function to send data to server */
site+=F("function ajaxValue(newValue, num) {\n\r");
site+=F("var url = \"/a_led?n=\" + num + \"&v=\" + newValue;\n\r"); // Change url to fit your needs
site+=F("var oReq = new XMLHttpRequest();\n\r");
site+=F("oReq.addEventListener('load', reqListener);\n\r"); // Debugging output console
site+=F("oReq.open(\"get\", url, true);\n\r");
site+=F("oReq.send();\n\r");
site+=F("document.getElementById('val' + num).innerHTML = newValue;\n\r");
site+=F("}\n\r</script>");
server.sendContent(site);This makes it possible to send value to ESP, in my case a slider (in Code named sliderVal[] Array of 16 floats):
server.sendContent(F("<table><tr>"));
for (byte i = 0; i < 16; i++) {
site="";
site+=F("<td><input type='range' orient='vertical' min='0' max='100' name='led_sl");
site+= i;
site+=F("' value='");
site+= sliderVal[i];
site+=F("' step='0.1' oninput='ajaxValue(this.value,");
site+= i;
site+=F(")'></td>");
server.sendContent( site);
server.sendContent(F("</tr><tr>"));
site="";
site+=F("<td><span id='val");
site+= i;
site+=F("'>");
site+=F("</span></td>");
server.sendContent(F("</tr></table><a href='/' class='buttonL'>Back</a>"));
// server.send(200, "text/html", site);
To handle the request:
void a_led() {
Serial.println( "Slider Arg: ");
Serial.println( server.args());
for (uint8_t i=0; i<server.args(); i++){
Serial.println(server.argName(i) + ": " + server.arg(i));
setSlider(server.arg("n").toInt(),server.arg("v").toFloat());
}Don't forget:
server.on("/a_led", a_led);Cheers
