It's Aimed at ESP8266-12 Dev Board (the One with Photo Resistors, Leds, and a bunch of GPIOs).
This Project lets you Control 4 Outputs from "buttons" on a web page, as well Continuously Monitor 2 Inputs and the ADC Input.
To monitor Inputs, its uses AJAX (javascript/html), so its hyper-efficient on bandwidt, no need to call to Comcast for Broader Internet, don worry its supported by most Phones and Every PC build from 1995
I'm here learning as you, don't see me as a Guru, just promise me to doit better and share your work.
* I just started with ESP8266 since I have few urgent IoT needs to fulfill, and its ideal for my purposes, but I find no useful samples
* to help me for such simple IoT solution I pursuit.
* then reading here and there I gathered the blocks to build my IoT ESP-12
* I home many people here sharing this need could find this project useful
* Dont give me credits, I Just Improved what I've find puting toghether in an single project which could be an
* start point for many others with similar need
* This work is an improvement on previous tutorials published here ot other webs
* Particular thanks to Rui Santos and its Arduino-Ethernet Shield tutorials from which tis the base for this work (and the CSS styleSheet is used here)
* Visit: http://randomnerdtutorials.com for more details
* Also the "Garage Door Opener V2 by SWilson http://www.esp8266.com/viewtopic.php?f=29&t=2696 provided most of the help
* very useful info needed to handle ajax html and other WEB-Related technologies can be found at http://www.w3schools.com/js/default.asp
* Fell free to copy/improve/etc onle compensation wanted is you share your ESP8266 projects here
* WARNING: this project is released "as is" with no warranty, you are responsible for it, use it as learning tool not as part for a commercial
* or production device.
* LICENSE: MIT (which means you can copy and if you like to share it again as you like, no snake GPL viral clauses.
* this project for testing uses an css style sheet read from Rui Santosś examples "ethernetcss.css" you can find it at its Arduino-Ethernet sample
* my safety suggestion if you decide to use an CSS style sheet derived or no from 'santos, is you should host it at your own controlled server,
* this way minimizes DDoS Attacks or other Attacks on your IoT network.
* Preferable to use ths solution on an Intranet with VPN access from the exterior and not allow the IoT modules to receive externa connexions.
* I'don't speak English natively, I do may best effort to express here, sorry for any error
* Thanks
* J.A. Acosta
#define serverPort 80
// define (map) GPIO to HTML Fields (buttons/Indicators), note: not using 0 as base index deliberately
#define input1 16
#define input2 14
#define statusLEDr 15
#define statusLEDg 12
#define statusLEDb 15
#define output1 4
#define output2 5
#define output3 2
#define output4 0
WiFiServer server(serverPort);
//*-- IoT Information
const char* _SSID = "yourNetworkSSID";
const char* _PASS = "yourNetworkPass";
const char* _passcode = "1234";//note: the field "passcode in the html form "frm1" must match the passcode lenght
char passcodeOK='0';//start Code is blank...
String readString;
int analogReadOut = 0;
// Open serial communications and wait for port to open:
pinMode(output1, OUTPUT);
pinMode(output2, OUTPUT);
pinMode(output3, OUTPUT);
// avoid using pin0 while on development, cause is more difficult to upload code since ESP_COMM must be connected before owncode start
//pinMode(output4, OUTPUT); //uncomment to control output #4
pinMode(statusLEDr, OUTPUT);
pinMode(statusLEDg, OUTPUT);
pinMode(statusLEDb, OUTPUT);
pinMode(input1, INPUT);
pinMode(input2, INPUT);
delay(50);
Serial.println(_SSID);
WiFi.begin(_SSID, _PASS);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected to:");
delay(1000);
ESP.wdtEnable(WDTO_4S);
//Start the server
server.begin();
//Print the IP Address
Serial.print("Use this URL to connect: ");
Serial.print("http://");
Serial.print(WiFi.localIP());
Serial.print(":");
Serial.print(serverPort);
Serial.println("/");
delay(1000);
//reset code for re-validation
passcodeOK='0';
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
// HTTP request has ended
if (c == '\n') {
if (readString.indexOf(String("sensorupdrq"))>0){//this branch purpose is to discriminate ajax update request from standad web request to, if you dont need
Serial.println("\r\najax sensor upd req:"); //comment the entire branch all '//<<<' lines
Serial.print(readString);//<<<
client.println("HTTP/1.1 200 OK\r\nContent-Type: text/html\r\nConnection: keep-alive"); // <<<
readInputs(client);//<<<
else//<<<
Serial.println("web request:");
if (readString.indexOf(String("passcode="))>0){
if (readString.indexOf(String(_passcode))>0) {
passcodeOK='1';
Serial.println("Password OK");
digitalWrite(statusLEDg, HIGH);
digitalWrite(statusLEDr, LOW);
}else{
passcodeOK='0';
Serial.println("Password NotOK");
digitalWrite(statusLEDg, LOW);
digitalWrite(statusLEDr, HIGH);
client.println("HTTP/1.1 200 OK\r\nContent-Type: text/html");
client.println("\r\n<HTML>");
client.println("<HEAD>");
client.println("<meta name=\"viewport\" content=\"width=380\">");
// Important, edit the Following line to match your CSS style sheet location, I suggest you to host at your own controlled server
client.println("<link rel='stylesheet' type='text/css' href='http://--PATH TO YOUR CSS--/ethernetcss.css' />");
client.println("<TITLE>FULL ESP8266-12 CONTROL DEMO</TITLE>");
// simple javascritp code to intercept anchor clientick and trick HREF field with the Button (or action) ID and add the password from the input field
client.println("\r\n<script>\r\nfunction SndCommand( obx,swtchNO ){ \r\nobx.href=\"button\"+swtchNO+\"&passcode=\"+document.getElementById(\"frm1\").elements[0].value;\r\n}\r\n</script>\r\n");
// not so simple script to allow sensor data to be automatically updated
client.println("\r\n<script>\r\nfunction GetSensorUpd() {\r\nnocache = \"&nocache=\" + Math.random() * 1000000;");
client.println("var ajaxreq = new XMLHttpRequest();");
client.println("ajaxreq.open(\"GET\", \"sensorupdrq\" + nocache, true);");
client.println("ajaxreq.onreadystatechange = function() {");
client.println("if (ajaxreq.readyState == 4 && ajaxreq.status == 200) {");
client.println("document.getElementById(\"readX\").innerHTML = ajaxreq.responseText;");
client.println("}\r\n}\r\najaxreq.send();");
client.println("setTimeout('GetSensorUpd()', 5000);\r\n}\r\n</script>\r\n");//updates each half second
client.println("</HEAD>");
client.println("<BODY onload=\"GetSensorUpd()\">");//comment thiss if you do not want automatic sensor update
// client.println("<BODY>");//uncomment this if yoy do not want auto update
client.println("<H1>Demo to Control Output<br />and<br />Sensor Read with ESP8266</H1>");
client.println("<br />");
client.print("<div id=\"passx\"><form id=\"frm1\">Password:<input name=\"passcode\" size=\"5\" maxlength=\"4\" type=\"password\" value=\"");
if (passcodeOK== '1') client.print(_passcode);
client.println("\" style='font-size:24pt'></form></div>");
client.print("<div id=\"readX\">");
readInputs(client);
client.println("</div>");
// first ON/OFF Buttons pair
client.println("<BR /><a href=\"\" onclick=\"SndCommand(this,11)\">Output 1 On</a>");
//SndCommand is a javascript code running on the clientiet (aka ajax) Parameters are outputIDx and State
client.println("<a href=\"\" onclick=\"SndCommand(this,10)\">Output 1 Off</a><br /><br />");
// then repeat for every gpio as output to control
client.println("<a href=\"\" onclick=\"SndCommand(this,21)\">Output 2 On</a>");
client.println("<a href=\"\" onclick=\"SndCommand(this,20)\">Output 2 Off</a><br /><br />");
client.println("<a href=\"\" onclick=\"SndCommand(this,31)\">Output 3 On</a>");
client.println("<a href=\"\" onclick=\"SndCommand(this,30)\">Output 3 Off</a><br /><br />");
client.println("<a href=\"\" onclick=\"SndCommand(this,41)\">Output 4 On</a>");
client.println("<a href=\"\" onclick=\"SndCommand(this,40)\">Output 4 Off</a><br /><br />");
client.println("</BODY>");
client.println("</HTML>");
//Processing client request
// Button0
if (readString.indexOf("button11") >0 && passcodeOK== '1'){
digitalWrite(output1, HIGH);
if (readString.indexOf("button10")>0 && passcodeOK== '1'){
digitalWrite(output1, LOW);
if (readString.indexOf("button21") >0 && passcodeOK== '1'){
digitalWrite(output2, HIGH);
if (readString.indexOf("button20")>0 && passcodeOK== '1'){
digitalWrite(output2, LOW);
if (readString.indexOf("button31") >0 && passcodeOK== '1'){
digitalWrite(output3, HIGH);
if (readString.indexOf("button30")>0 && passcodeOK== '1'){
digitalWrite(output3, LOW);
if (readString.indexOf("button41") >0 && passcodeOK== '1'){
digitalWrite(output4, HIGH);
if (readString.indexOf("button40")>0 && passcodeOK== '1'){
digitalWrite(output4, LOW);
delay(1);
client.stop();
delay(0);
//clean readString for next read
readString="";
// send back GPIO Data Refresh
void readInputs(WiFiClient cl) {
cl.println("\r\n<p>");//dont miss to wrap the request with some tag, mandatory for ajax to work properly
analogReadOut = analogRead(A0);
if (analogReadOut < 50){
cl.print("<p>Analog Reading:<span style='background-color:#00FF00; font-size:18pt'>");
cl.print(analogReadOut);
cl.println("</span></p>");
}else{
cl.print("<p>Analog Reading:<span style='background-color:#FF0000; font-size:18pt'>");
cl.println("<br />");
if (digitalRead(input1)) {
cl.println("<p>Input ONE is: <span style='background-color:#00FF00; font-size:18pt'>ON</span></p>");
}else{
cl.println("<p>Input ONE is: <span style='background-color:#FF0000; font-size:18pt'>OFF</span></p>");
if (digitalRead(input2)) {
cl.println("<p>Input TWO is: <span style='background-color:#00FF00; font-size:18pt'>ON</span></p>");
}else{
cl.println("<p>Input TWO is: <span style='background-color:#FF0000; font-size:18pt'>OFF</span></p>");
cl.println("</p>");//this tag completes the request wrap
Serial.println("ajax sensor upd sent\r\n");
