By GengusKahn
#34196 This will connect to Google and retrieve a string containing the current time and date.
The simple sketch will convert the string to a time stamp and display the result on some Neopixels, the result is contained in an integer and can be used to trigger or display events.
Code: Select all/*
 ___/'¬_         /\
{_-_ ^  \_______//
     \ _  _____  /
            _____
     _-_-_-_ *|* _-_-_-_
    -_-_-_-_-\@/-_-_-_-_-
_____________________________
BadTail Projects ALL RIGHTS GRANTED this is OPEN SOURCE and
without any Implied or Otherwise "Gaurantees" of a
Particular Part in Whole or Function
and free to use in any or all parts.........
Libraries are part of Standard GNU License........
Rod Con ..... The Road to Contentment.............
Use this sketch to set the Neopixels to display the Time from the Web via ESP8266
on a String of 60* WS2812 on pin 12 Plus 12 on pin 13 of ESP8266............
___________________________________________________________________________
!*!*!*! Please note the Libraries Required in the Includes.......!*!*!*!|
// include the library code:
#include <Adafruit_NeoPixel.h>
#define PIXELPIN0 13
#define PIXELPIN 12
#define BRIGHTNESS 32
// WiFi connection
const char* ssid = "Your SSID";
const char* password = "Your PASSWD";
WiFiServer server(80);
WiFiClient client;
extern "C"
#include "user_interface.h"
ADC_MODE(ADC_VCC);
char tDigit;
String TiMeS,TMnow,MyNtP;                                 // The current TimeStamp from Google....
int tIMeh,tIMem,tIMes,newt,newt1,inChar,SCsa,MNsa,HRsa;   // Integer values from Gooogle time reply
int hr,mn,st,st1;                                         // Uptime Duration Counter......
String DsTable;                                           // Discarded parts if the Strings......
String theDate,theDate1,duration1,theDateTr;              // The current TimeStamp Date from Google....
Adafruit_NeoPixel strip0 = Adafruit_NeoPixel(12, PIXELPIN0, NEO_GRB + NEO_KHZ800);
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIXELPIN, NEO_GRB + NEO_KHZ800);
byte dialval, hourval, minuteval, secondval;
byte pixelColorRed, pixelColorGreen, pixelColorBlue;
void setup () {
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
    delay(100);
  server.begin();
  // connect to Google and get time
  WiFiClient client;
  while (!!!client.connect("google.com", 80)) {
  client.print("HEAD / HTTP/1.1\r\n\r\n");
  while(!!!client.available()) {
     yield();
  while(client.available()){
  client.readStringUntil('\n');
   theDate1 = client.readStringUntil('\r'); //Date: Tue, 10 Nov 2015 19:55:38 GMT
    if (theDate1.startsWith("Date:")) {
      TiMeS=theDate1;
      theDate = theDate1.substring(6,23);
          client.flush();
          client.stop();
  inChar = TiMeS.charAt(30);
  newt=inChar-48;             // Convert Numerical Char to int.....
  inChar = TiMeS.charAt(29);
  newt1=inChar-48;
  tIMes=(newt1*10)+newt;
  inChar = TiMeS.charAt(27);
  newt=inChar-48;
  inChar = TiMeS.charAt(26);
  newt1=inChar-48;
  tIMem=(newt1*10)+newt;
  inChar = TiMeS.charAt(24);
  newt=inChar-48;
  inChar = TiMeS.charAt(23);
  newt1=inChar-48;
  tIMeh=(newt1*10)+newt;
  MyNtP=" ";
  MyNtP+=theDate;
  if (tIMeh<10){MyNtP+="0";}
  MyNtP+=tIMeh;
  MyNtP+=":";
  if (tIMem<10){MyNtP+="0";}
  MyNtP+=tIMem;
  MyNtP+=":";
  if (tIMes<10){MyNtP+="0";}
  MyNtP+=tIMes;
  MyNtP+=" GMT";
 duration1 = " ";
   st1 = millis() / 1000;
   st = millis() / 1000;
   mn = st / 60;
   hr = st / 3600;
   st = st - mn * 60;
   mn = mn - hr * 60;
   if (hr<10) {duration1 += ("0");}
   duration1 += (hr);
   duration1 += (":");
   if (mn<10) {duration1 += ("0");}
   duration1 += (mn);
   duration1 += (":");
   if (st<10) {duration1 += ("0");}
   duration1 += (st);
 HRsa=hr+tIMeh;
 MNsa=mn+tIMem;
 SCsa=st+tIMes;
if (SCsa>59){SCsa-=60;MNsa+=1;}
if (MNsa>59){MNsa-=60;HRsa+=1;}
if (HRsa>23){HRsa-=24;}
    TMnow = " ";
    TMnow += theDate;
    if (HRsa<10){TMnow += "0";}
    TMnow += HRsa;
    TMnow += ":";
    if (MNsa<10){TMnow += "0";}
    TMnow += MNsa;
    TMnow += ":";
    if (SCsa<10){TMnow += "0";}
    TMnow += SCsa;
  strip.begin();
  strip.setBrightness(BRIGHTNESS);
  delay(50);
  colorWipe(strip.Color(125, 0, 125), 10);
  colorWipe(strip.Color(0, 255, 0), 10);
  strip0.begin();
  strip0.setBrightness(BRIGHTNESS);
  delay(50);
  colorWipe0(strip0.Color(125, 0, 125), 30);
  colorWipe0(strip0.Color(0, 255, 0), 40);
  colorWipe0(strip0.Color(125, 0, 125), 20);
  colorWipe0(strip0.Color(0, 0, 0), 10);
void loop () {
   mn = st / 60;
   hr = st / 3600;
   st = st - mn * 60;
   mn = mn - hr * 60;
 HRsa=hr+tIMeh;
 MNsa=mn+tIMem;
 SCsa=st+tIMes;
  secondval = SCsa;
  minuteval = MNsa;
  hourval = HRsa;
  dialval = HRsa;
  if(hourval > 11) hourval -= 12; // This clock is 12 hour, if 13-23, convert to 0-11
  if(dialval > 11) dialval -= 12; // This clock is 12 hour, if 13-23, convert to 0-11
  hourval = ((((hourval*60) / 12) - 1)+(minuteval / 12));  //Represent the hour number on dial 12 minute steps.
  minuteval =   minuteval - 1; // Adjust the minute to reflect the dial position
  for(uint8_t i=0; i<strip.numPixels(); i++) {
   if (i <= secondval) {
     pixelColorBlue = 255;
   else {
     pixelColorBlue = 0;
   if (i <= minuteval) {
     pixelColorGreen = 255;
   else {
     pixelColorGreen = 0;
   if (i <= hourval) {
     pixelColorRed = 255;
   else {
     pixelColorRed = 0;
   strip.setPixelColor(i, strip.Color(pixelColorRed, pixelColorGreen, pixelColorBlue));
  for(uint8_t i=0; i<strip0.numPixels(); i++) {
   if (i <= dialval) {
   else {
     pixelColorRed = 0;
       strip0.setPixelColor(i, strip0.Color(pixelColorRed, pixelColorGreen, pixelColorBlue));
  strip.show();
  strip0.show();
  delay(200);
void colorWipe(uint32_t c, uint8_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
   strip.setPixelColor(i, c);
   strip.show();
   delay(wait);
void colorWipe0(uint32_t c, uint8_t wait) {
  for(uint16_t i=0; i<strip0.numPixels(); i++) {
   strip0.setPixelColor(i, c);
   strip0.show();
   delay(wait);
