SPIFFS file read and write example
Posted: Mon Feb 15, 2016 6:03 pm
Today I coded a basic sketch getting to learn to use the SPIFFS filesystem.
The sketch is attached here, maybe it's of use to anyone.
// Very basic Spiffs example, writing 10 strings to SPIFFS filesystem, and then read them back
// For SPIFFS doc see : https://github.com/esp8266/Arduino/blob/master/doc/filesystem.md
// Compiled in Arduino 1.6.7. Runs OK on Wemos D1 ESP8266 board.
#include "FS.h"
Serial.begin(9600);
Serial.println("\nVery basic Spiffs example, writing 10 lines to SPIFFS filesystem, and then read them back");
SPIFFS.begin();
// Next lines have to be done ONLY ONCE!!!!!When SPIFFS is formatted ONCE you can comment these lines out!!
Serial.println("Please wait 30 secs for SPIFFS to be formatted");
SPIFFS.format();
Serial.println("Spiffs formatted");
// open file for writing
File f = SPIFFS.open("/f.txt", "w");
if (!f) {
Serial.println("file open failed");
Serial.println("====== Writing to SPIFFS file =========");
// write 10 strings to file
for (int i=1; i<=10; i++){
f.print("Millis() : ");
f.println(millis());
Serial.println(millis());
f.close();
// open file for reading
f = SPIFFS.open("/f.txt", "r");
if (!f) {
} Serial.println("====== Reading from SPIFFS file =======");
String s=f.readStringUntil('\n');
Serial.print(i);
Serial.print(":");
Serial.println(s);
// wait a few seconds before doing it all over again
delay(3000);
