Yet another esp WiFi config to eeprom ..
Posted: Thu Mar 17, 2016 2:24 pm
Yes out there is the excellent WiFimanager for saving the config of our esp8266 and it's great.
Just wanted to try something quick and dirty on my own (learning process )
Started looking chriscook8's esp-arduino-apboot code and tired to rewrite the heck out of it.
The goal was to have all this in a separate file and not in my main server/project sketch. Instead have it open in another IDE tab and just make a call from the main.
oh and I'm no programming guru also.. check it, hack it or blow it up: https://github.com/nikant/espWiFi2eeprom
- - This is not a library (and it may never become one..)
- You must have the two files "espWiFi2eeprom.h" and "espWiFi2eeprom.ino" in the same directory with your project sketch.
- Has been tested with NodeMCU v1.0 and Arduino IDE 1.6.5-r5 in Windows 7
- Check "example-espWiFi2eeprom.ino" for an example of usage along with another server.
- You can edit "espWiFi2eeprom.h" in order to change parameters.
