https://github.com/DaKaZ/esp8266-restclient
Enjoy...
Explore... Chat... Share...
A - Use Google Chrome
A1. Install Google Chrome
A2. Install Simple Rest Client (https://chrome.google.com/webstore/detail/simple-rest-client/fhjcajmcbmldlhcimfajhfbgofnpcjmb)
A3. Once Simple Rest Client is installed you should a blue globe looking icon to the right of the URL field in Chrome. Click on that icon.
A4. In the URL field of the REST Client, type in http://192.168.168.198/sony/accessControl
where you replace 192.168.168.198 with IP address of your TV.
A5. Click on POST.
A6. In the DATA field paste:
{"id":13,"method":"actRegister","version":"1.0","params":[{"clientid":"iRule:1","nickname":"iRule"},[{"clientid":"iRule:1","value":"yes","nickname":"iRule","function":"WOL"}]]}
A7. Hit SEND. You should see a message on TV pop-up with PIN code and a Username and Password message pop-up in the Browser.
Leave Username blank and in password field put in the PIN code that is displayed on TV.
B -To find out what codes your TV can accept, go to Rest again and:
B1. In the URL field of the REST Client, type in http://192.168.168.198/sony/system
B2. Click on POST.
B3. In the Headers field type:
SOAPAction: "urn:schemas-sony-com:service:IRCC:1#X_SendIRCC"
B4. In the Data field type:
{"method":"getRemoteControllerInfo","params":[],"id":10, "version":"1.0"}
B5. Hit SEND. You should see a big list of codes in the result box, like in the attached picture.
C - To test your codes work, go to REST again, and:
C1. In the URL field of the REST Client, type in http://192.168.168.198/sony/IRCC
C2. Click on POST.
C3. In the Headers field type:
C4. In the Data field type:
<?xml version="1.0"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:X_SendIRCC xmlns:u="urn:schemas-sony-com:service:IRCC:1"><IRCCCode>AAAAAQAAAAEAAAAuAw==</IRCCCode></u:X_SendIRCC></s:Body></s:Envelope>
C5. Replace the code between on the line beginning <IRCCCode>:
with whichever code your TV can accept, that you discovered with the getRemoteControllerInfo method. The one above is the discrete power on, "WakeUP".
There is no WOL with my model, a KDL65W850C.
C6. Hit SEND. Your TV should turn on, and stay on ,if sent again.It takes about 20-25 seconds for home assistant c[…]
