I developing home watering system with ESP8266
1pcs of ESP8266 is a webserver this is the "master" and controlls the other "slave" ESP boards.
3 pcs of ESP8266 are "slave" boards. For saving the battery, theese modules wakes up in every 5minutes from deep sleep, after the wake up:
-measuring the temperature and humidity
-communcating with the "master" modul
-if its it necesery opening watering valve
The maste has a local adress 192.168.1.100, there I can control other slave moduls or I can see the temperature, humidity for previous days, etc.... This webpage has 5-6Kb size, this takes 4-5seconds for ESP to generate it.
I have big problem because when I start the slave modules at the same time and I connect through 192.168.1.100 to the "master" ESP modul its resetting. Maybe this is too many request at same time and it cannot handle. I trying to develop delay(100); yield(); but without success.
Once again, there isnt any problem when theese request happens in different time, but when there is many - many request at once this causing wtd reset. Can anybody helps?
I attach the code for the servers ESP modul (master) and the client (slave) ESP modules, but its is a bit long.
