By krzychb
#34543 Thanks to @brutzler uncovering how customize Arduino IDE and after learning how to update ESP using a web browser, I decided to combine this knowledge and add cURL upload option to Arduino IDE menu.
This is to provide another convenient tool to upload ESP thanks to variety of OTA options developed by esp82666/Arduino team - thank you guys!
Why upload with cURL out of Arduion IDE may be useful? Well, there couple of reasons:
• It is about 3x quicker than serial upload
• It is far quicker and convenient than OTA with web browser
• It is fully interchangeable with web browser’s upload
• Serial Monitor is still available for debug
Here is how to do it in five steps:
1. If not done already, go through all the steps to have OTA with web browser work for you
2. Update configuration of Arduino IDE as below:
a. boards.txt
Code: Select allgeneric.menu.UploadTool.curl=cURL
generic.menu.UploadTool.curl.upload.tool=curl
b. platform.txt
Code: Select alltools.curl.cmd=curl
tools.curl.cmd.windows=curl.exe
tools.curl.upload.protocol=curl
tools.curl.upload.params.verbose=-v
tools.curl.upload.params.quiet=-s
tools.curl.upload.pattern= "{cmd}" {upload.verbose} -F "image=@{build.path}/{build.project_name}.bin" esp8266-webupdate.local/update
c. restart Arduino IDE
3. Install cURL:
a. Open http://curl.haxx.se/download.html
b. Scroll down, contemplate the freaking awesome number of platforms cURL is available for :shock: :shock: and say “Oh, my God” or “Holy crap” depending on if you are a woman or a man ;)
c. Pick file for your O/S, upload and install cURL
4. Upload your ESP with sketch WebUpdater.ino covered in step 1 using serial.
5. Once module restarts and is ready for OTA upload, change “Upload Using:” to cURL and now you should be able to upload module with cURL.
Note: in case of issue with upload go to File > Preferences and for “Show verbose output during:” check out “upload”. You will be able to see details on cURL execution and upload progress.
Above configuration has been validated for:
• Arduino IDE 1.6.5
• 2.0.0-rc1 (of Nov 17, 2015) version of ESP8266 platform package
• Windows 7
• cURL for Win64 – Generic curl-7.33.0-win64-ssl-sspi.zip
Have quick and reliable uploads :D
Krzysztof
By reaper7
#34614 nice but what's happen when You have few active modules and all have the same name?
my proposal:
inside sketch add MDNS.enableArduino(8266);
Code: Select all  MDNS.begin(somehostname);
  MDNS.addService("http", "tcp", 80);
then all esp's will be visible inside IDE->Network Ports
and upload pattern (inside platform.txt) change to:
Code: Select alltools.curl.upload.pattern="{cmd}" -F "image=@{build.path}/{build.project_name}.bin" "http://{serial.port}/update"
By krzychb
#34670 @reaper7 - very nice and creative extension 8-)
To have it available in official Arduino IDE release we need to have this this pull request # 4107 merged
To everybody who likes and needs OTA!
Do not wait - support it on github :D
By reaper7
#34676 it would be cool especially for everyone who regullary get update from github and after update manually improves files :)
